Sep 7th - Sep 10th
http://www.hamburg-messe.de/smm/smm_de/
Messe Hamburg, Hamburg, Germany
2010 Aug 27th
Victron Energy exists 35 years, a milestone that needs to be celebrated! Therefore, Victron SAIL 2010 was organised, in the middle of SAIL 2010 Amsterdam (The Netherlands). Several boats with a waving Victron-flag sailed through the canals of Amsterdam. In the evening there was a spectacular fireworks show. It was a great day! Read full article
BMV-600S and BMV-602SThe BMV-600S and BMV-602S are our newest high precision battery monitors. The essential function of a battery monitor is to calculate ampere-hours consumed and the state of charge of a battery. Ampere-hours consumed are calculated by integrating the current flowing in or out of the battery.
The BMV-602 has a second voltage measurement input. This input can for example be used to measure the voltage of a starter battery. |
BMV-602 Data Link RS232 with softwareThe Data-Link kit consists out of a communications cable (galvanically isolated), a converter and the Data-Link software. With this kit you can connect: • Your BMV-602 Battery Monitor to your Global Remote. This connection allows the Global Remote to log data from the BMV-602 Battery Monitor to a website through a GPRS connection. The usage of this website is free of charge. • Your BMV-602 Battery Monitor to a computer. The free software which is supplied with the Data-Link kit enables you to download and process just about any aspect of your battery and system performance, including charge/discharge curves. |
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
