Sep 7th - Sep 10th
http://www.hamburg-messe.de/smm/smm_de/
Messe Hamburg, Hamburg, Germany
2010 Aug 27th
Victron Energy exists 35 years, a milestone that needs to be celebrated! Therefore, Victron SAIL 2010 was organised, in the middle of SAIL 2010 Amsterdam (The Netherlands). Several boats with a waving Victron-flag sailed through the canals of Amsterdam. In the evening there was a spectacular fireworks show. It was a great day! Read full article
Modular System PanelsFive standard panel sizes offer maximum flexibility to design and assemble a custom switchboard. The Pros panels match perfectly with the Victron Energy product control panels. |
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
