Current Event:
SMM Hamburg
Sep 7th - Sep 10th
Messe Hamburg, Hamburg, Germany
Exibitor:
Latest News:
Victron SAIL 2010
2010 Aug 27th
Victron Energy exists 35 years, a milestone that needs to be celebrated! Therefore, Victron SAIL 2010 was organised, in the middle of SAIL 2010 Amsterdam (The Netherlands). Several boats with a waving Victron-flag sailed through the canals of Amsterdam. In the evening there was a spectacular fireworks show. It was a great day! Read full article
Remote Control Panels
Remotely controlling and monitoring your power equipment has never been easier. Our wide range of Victron remote control panels enables you to monitor your system and adjust its settings. See below for our range of panels.
Documents
Related products
Digital Multi Control 200/200A
This panel is intended both for Multi's and Quattro's. It allows PowerControl and PowerAssist current limit setting for two AC sources: a generator and shore-side current for example.
Setting range: 200 Amps.
The brightness of the LED's is automatically reduced during night time.
VE.Bus Multi Control
Variable setting range (with the rotary knob): up to 16 Amps (VE.Bus Multi Control 16/200A panel) or up 30 Amps (VE.Bust Multi Control 30/200A panel).
Fixed setting range (for both models): 200 Amps.
Phoenix Inverter Control
This panel is intended for Phoenix inverters equipped with a UTP remote monitoring and control socket. It can also be used on a MultiPlus inverter/charger when an automatic transfer switch but no charger function is desired. The brightness of the LEDs is automatically reduced during night time.
Only for models: 12/1200, 12/1600, 12/3000, 12/5000, 24/1200, 24/1600, 24/3000, 24/5000, 48/3000 and 48/5000.
Battery Alarm
An excessively high or low battery voltage is indicated by an audible and visual alarm, and a relay for remote signalling.
Charger Switch
A remote on-off switch
Skylla Control
The Skylla Control allows you to alter the charge current and see the system status.
Phoenix Charger Control
The PCC panel provides remote control and monitoring of the charge process with LED indication of the charger status. In addition, the remote panel also offers output current adjustment that can be used to limit the output current and thus the power drawn from the AC supply. This is particularly useful when operating the charger from limited shore power or small gensets. The panel can also be used to change the battery charging parameters. The brightness of the LED's is automatically reduced during night time. Connection to the charger is with a standard UTP cable.
More Power
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
New Quattro. More power.
Two AC outputs
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
New Quattro. New Multiplus. Two AC ouputs.
