Current Event:
North Wales Boat Show
Jul 30th - Aug 1st
Vaynol Estate, Bangor, UK
Exibitor:
Latest News:
'Whisper Balls' for FIFA
2010 Jul 1st
The Whisper Boat Building Academy from South Africa developed a unique concept: the ‘Floating Whisper Balls’. These ‘Whisper Balls’ are especially made for the FIFA World Cup 2010 and they offer companies an interesting new way to promote themselves with 10 m2 of advertising space on each ball. The Whisper Balls are equipped with Blue Power Chargers from Victron Energy. Read full article
Enclosure Dimensions
  • Cut Out Dimensions Remote Panels
  • Dimensions - Blue Power Charger GX IP20
  • Dimensions Argofet 200-2 / 200-3
  • Dimensions Battery Gel / AGM 12-130
  • Dimensions Battery Gel / AGM 12-165
  • Dimensions Battery Gel / AGM 12-220
  • Dimensions Battery Gel / AGM 12-90
  • Dimensions Battery Gel 2-1000
  • Dimensions Blue Power Charger 12/17 and 24/12 IP67
  • Dimensions Blue Power Charger 12/7 and 24/3 IP67
  • Dimensions Blue Power Charger IP20
  • Dimensions Blue Power Panel
  • Dimensions Centaur Charger 24100
  • Dimensions Centaur Charger 2416 / 1230
  • Dimensions Centaur Charger 2430 / 1260
  • Dimensions Charger 12/24
  • Dimensions Compact
  • Dimensions Isolation Transformer 3600 / 7000
  • Dimensions Isolation Transformers 3600 7000
  • Dimensions Phoenix Charger 12/24
  • Dimensions Phoenix Inverter 12/24/48 5000 Quattro 12/24/48 5000
  • Dimensions Phoenix Inverter 12/24/48 Phoenix Multiplus 12/24/48
  • Dimensions Phoenix Inverter 12/24/48 Phoenix MultiPlus 12/24/48
  • Dimensions Shunt 1000A 50mV
  • Dimensions Shunt 2000A 50mV
  • Dimensions Skylla GMDSS 2430 / 2450 dwg
  • Dimensions Skylla GMDSS 2430 / 2450 pdf
  • Dimensions Skylla GMDSS panel dwg
  • Dimensions Skylla GMDSS panel pdf
  • Dimensions Skylla TG 2480 / 24100
  • Dimensions Skylla TG Chargers 2430 / 2450 / 4825 / 4850
  • Dimensions Skylla TG Chargers 2480 / 24100
  • More Power
    Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
    New Quattro. More power.
    Two AC outputs
    All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
    New Quattro. New Multiplus. Two AC ouputs.
