First a short introduction to these chargers. The Skylla-i chargers are our high power and can-bus enabled 24V chargers. There are four models:
- 24V 80A – 1 output
- 24V 80A – 3 outputs
- 24V 100A – 1 output
- 24V 100A – 3 outputs
And there is a remote control panel, the Skylla-i Control GX:
Read the datasheet for more details about all the different features.
Firmware version v2.01 brings one big improvement, suggested to us by Alan Peng, owner of Shenzhen Royal Technology Co, Ltd, our main distributor in China. Besides seven pre-defined battery modes such as gel, agm and lithium, it has two modes where you can set the absorption voltage, float voltage and maximum charger current with three potentiometers. While adjusting one of these, the voltage will now be indicated by the LED bars on the Skylla-i, and on the numeric display (blinking) on the Skylla-i control panel.
You really have to try it yourself to see how simple and fast it is to set up. This is a huge improvement over the old way, thank you again Alan!
The other changes include:
- Lithium float voltage changed from 13.35v to 13.5v
- Improved stability of parallel charging algorithm when disconnecting and reconnecting chargers to the network.
Contact your Victron representative for the necessary files. Updating both the charger and the control panel can be done with VE Power Setup, available for download on our software and downloads page. More information on VE Power Setup is available in the VE Power Setup blog post.
Have a good weekend, Matthijs Vader
