The updated Victron Toolkit app version 2.3 has now been released.
What’s new?
- Supports more products: MPPT (2 & 3 LED models), plus all Phoenix Inverters up to 1200VA.
- Improved the LED definitions functionality.
- Improved interface to help you find the correct LED definition quickly.
- Any changes to product definitions are retrieved/pushed to the app automatically on start up!
Download the updated Victron Toolkit app
Search for Victron Toolkit in the appropriate iPhone or Android app store on your phone, or go to the link below which also includes Android APK files:
https://www.victronenergy.com/support-and-downloads/software#victron-toolkit-app
What does Victron Toolkit do?
For those not familiar with Victron Toolkit, here is what it can do:
- Calculate cable size and voltage drop. Easily select cable length, amperes and cable cross section to determine the voltage drop over the cable.
- Understand all LED codes from a range of Victron Energy products. Scroll through the list of all possible codes. The app contains normal operation codes, warnings, alarms and error codes.
- Temperature derating. Calculate output power derating for inverters and chargers for the expected ambient temperature.
- Includes a QR code (Quick Response code) scanner. Using the built in scanner you can read the QR code printed on Victron Energy products, which will take you directly to a webpage giving detailed product information. See this earlier blog for more:
https://www.victronenergy.com/blog/2016/03/15/victron-toolkit-app-now-with-qr-scanner/
Example screenshots from Victron Toolkit:
Cable calculations:
Choose a product for LED definitions:
Temperature derating:
Feel free to post any feedback you may have below, and do enjoy the updated Victron Toolkit.
