New and ever improving products are a feature of the Victron Energy brand. Personally speaking it’s often hard to keep up with this continually evolving product range, so I thought it would be handy to let you know what’s hot, what’s new, in stock and available now – just in case you’ve missed anything on the pricelist or e-order.
High Voltage
- MPPT 250/100
- MPPT 250/85 (shown in the blog headline image with optional plug-in LCD display)
That’s a lot of kVA
15kVA is now available in the uprated inverter/charger Quattro range. This can save paralleling smaller units, as you may have done previously to get a larger power output.
This new 2 x 230V input, 48/15000/200-100/100 Quattro model (if we break down the model notation ) is 15kVA continuous output power at 25°C , 200 Amps battery charge current at 25°C ambient, with a maximum feed through current of 2 x 100 Amps.
New marine charger – IP67 rated
The new IP65 Skylla marine charger (dust and water jet resistant) accepts 120 and 230 volts input in the 90-265 volt range and is available in the following configurations – ( 12/60 (1+1), 12/60 (3), 24/30 (1+1), 24/30 (3).
The (1+1) features 2 isolated outputs. The second output, limited to approximately 3A and with a slightly lower output voltage, is intended to top up a starter battery.
The Skylla-IP44 (3) features 3 isolated outputs. All outputs can supply the full rated output current.
Besides its IP44 rating, the charger is further able to withstand the rigours of the marine environment such as heat, humidity and salt air. The circuit boards are also protected by an acrylic coating for maximum corrosion resistance. Additionally temperature sensors ensure that power components will always operate within specified limits – if needed by automatic reduction of output current in extreme environmental conditions.
Other new products now in stock
Although the new 15kVA Quattro is already awaiting restock, the IP44 Skylla marine charger is currently in stock – as are these other new products listed below:
- Solar Panel 150W-12V Mono 1480×673×35mm series 3a
- 12V/220Ah AGM Deep Cycle Battery
- 12V/60Ah Gel Deep Cycle Battery
- 12V/66Ah AGM Deep Cycle Battery
- 12V/110Ah AGM Deep Cycle Battery (M8)
- 12V/130Ah AGM Deep Cycle Batt. (M8)
- Blue Smart IP65 Charger 12/7(1) 230V
- Blue Smart IP65 Charger 12/10(1) 230V
- Blue Smart IP65 Charger 12/15(1) 230V
- Blue Smart IP65 Charger 12/4(1) 230V
- 12V/265Ah GEL Deep Cycle Batt. (M8)
- 12V/230Ah AGM Super Cycle Batt. (M8)
- Blue Power IP22 Charger 24/12(1) 230V CEE 7/7
Conclusion
As if all the above were not enough I also learned, as we were going to press, there are some new Smart Lithium batteries too. These include improved balancing, second generation BMS with Bluetooth Smart built-in – which means the information you get is that which you see in the screenshots in the VictronConnect manual.
More on the above and other new products as the information becomes available…
John Rushworth
