Good morning!
Last night we released version Venus v2.10. It contains two fixes:
- Fix Remote VEConfigure not working with VE.Bus firmware version 418. Note that Remote VEConfigure does not work for 416 and 417, and also will never work. Have you recently installed or updated a system where you need the option to remotely change settings in the Inverter, Multi or Quattro? In that case do check if they are running 416 or 417, and if so update to 418.
- Fix rounding of battery ‘Time To Go’ and ‘Time since last full charge’ values for systems where the battery monitor is connected via VE.Can. Such as the Lynx Shunt VE.Can, the Lynx Ion BMS, or a BMV connected via a VE.Direct to VE.Can interface cable. The error caused the values to be rounded to full hours, losing the minutes.
See update instructions for how to update.
Have a good day, Matthijs
