Professional installations which meet client needs and exceed expectations are good for business.
Whether your customer is price conscious or quality-driven, our Training Videos are designed to empower you to easily select the most appropriate product for your customers needs.
They will help you install tidy, well-considered systems, optimally configured for the task.
They will guide you to enabling the appropriate product features that achieve excellent performance – and result in a power system with which your customer will be really happy.
Digital Training Manager Guy Stewart is working on new videos all the time – so why not take a look and see what’s new?
Even if you’ve watched some of these easy-to-follow videos before, a refresher might offer that elusive solution you’ve been looking for!
Training Video Library
At the time of writing there are 19 videos in the Training Library available in seven languages. On land or sea; isolated or connected to the grid, generator back-up or remote stand-alone, large or small, three-phase, parallel, daisy chained, cross-manufacture installation – you’ll find a solution for every circumstance.
The videos, and any presentation slides used in them, can be downloaded for later viewing. Each video is followed by a test. Completion certificates can be downloaded after achieving successful test results.
Here’s a round-up of what to expect from each of them. You will need to be signed in to your Victron Professional account to follow these links to the desired content.
The series begins with MultiPlus Inverter/Chargers as power conversion lies at the heart of everything we do.
Basic Training – Introduction to MultiPlus: Guy Stewart (31 mins)
Providing an overview of our range of inverters from 500VA to 15kVA, expandable to 180kVA – the largest range on the market – this video explains:
- sizing advice and guidance on correct product selection
- a breakdown of the product features
- a comparison of the features of our ‘apparently similar’ inverters
- simple schematics showing essential switching/wiring topography and their importance
- Grounding features for different applications
- Frequency shifting / Three phase / Parallel installation
- A few words on back up Generators
- and some commonly used accessories
Using Generators with Victron – Webinar Margreet Leeftink (40 mins)
In this video Margreet outlines the types of Generators available on the market and discusses:
- the automatic Generator Start/Stop feature
- programming options/parametres available when programming auto start/stop on a BMV; a MultiPlus; and on a GX device
- triggering by SOC, low voltage, and current
- Power Assist
- Reporting to VRM
- 3 Phase special conditions – phase matching and balancing
- Generator to Inverter sizing
Basic Training – Introduction to MPPTs: Guy Stewart (31 mins)
With PWM and MPPT stand-alone and all-in-one solar charge controllers capable of handling charge currents between 10A and 100A, with or without Bluetooth – plus an ability to daisy-chain up to 25 solar charge controllers, this video guides you through:
- Sizing calculations
- Product selection informed by PV array / battery voltage
- PV input connections / cable sizing / temperature and open-circuit voltage
- Product Configuration on VictronConnect / Smart networking
- VE Can devices
- Settings BMV / Temperature Compensation
- Features DVCC / Streetlight / Current limiting
Basic Training for MPPT RS: Guy Stewart (15 mins)
This powerful new galvanically isolated solar charge controller has its own training video, discussing:
- Significance of Galvanic Isolation / test for ground / application examples
- 450V extra cautions / 48VDC only application
- Two PV string input / 25 device daisy-chain capability / temperature sense
- Wiring examples / programming
Basic Training – Color Control GX: Guy Stewart (42 mins)
When used, the GX family of communication devices sit at the heart of an installation controlling and monitoring power harvest, storage and supply; harmonising third party devices, and storing and reporting system data. This hands on video takes us from unboxing, through making connections, to a full consideration of the many available features:
- Guide to ports / updating firmware /accessories
- VRM setup / remote console
- connection to MPPT with VE.Direct, and MultiPlus with VE.Bus
Basic Training – Using Victron Remote Management (VRM): Guy Stewart (24 mins)
This video explains how to get the most out of the VRM platform, using its powerful data-rich features to analyse the performance of installations as used by customers in the real world. Such analysis allows ‘fine-tuning’ decisions to be made, or additional product purchase with the absolute certainty that it will result in a perfect match between customer need and system build. The video includes:
- Adding/Deleting monitored installations
- Dashboard overview explained / Advanced data overview
- Drag and drop/range selection by data-type, and by historic date
- Export to spreadsheet
- Remote Console change system programme settings
- Multiple Alarms – setting audible or email notifications
- Remote firmware check and update
- Device Memory clear
- Setting Geofence for out-of-area warnings
Batteries and Battery Monitoring – Webinar with Margreet Leeftink (54 mins)
This video provides an insight into battery types and chemistries and, focussing on Lead Acid batteries, discusses:
- Discharge cycles – affect from Depth of discharge
- Rated capacity – affect from size of load
- Charge efficiency and temperature
- Battery idle
- Battery bank configuration
- Battery Protect, Low voltage disconnect, Mid Point monitoring, Balancing
- Generator Auto Start
Maximising Lead Acid Battery Life – 55 page PDF instruction
This presentation offers a comprehensive investigation into battery types and the jobs they were designed to do. Common errors and misconceptions. How batteries can become damaged, shortening their design life. Correct installation, management of charging, periodic maintenance, and testing. It is followed by an exam.
Basic Training – Connecting MultiPlusII GX to a BYD managed Battery – Guy Stewart (26 mins)
This video includes a practical demonstration, and discusses:
- Overview of the BYD battery unit
- Wiring between the Battery and Inverter
- Installing fuses
- Communication connections
- Pre-commissioning checks
- Connecting the installation to VRM
Installation Example VW vehicle narrated by Jono – (4 videos – 36 mins – links below)
This video follows Lucian Popescu and his team as they install a comprehensive power system in a VW van. The instruction is divided into four videos: Solar panel installation; alternator charging provision; mains charging capability; connecting a Color Control GX.
1 Solar (7 mins)
- Mounting the panels
- Wiring
- connections to Lithium battery
- Wiring diagram
2 Alternator charging (6 mins)
- Cabling
- Buck Boost DC-DC conversion for battery charging
- BMS
- Software downloads
- Programming the Buck Boost
3 Mains Charging (14 mins)
- Installing an AC inlet
- Consumer unit
- Lynx Distributor and megafuses
- Battery Protect
- Mains Detection
- Programming
4 Install a Color Control GX (9 mins)
- BMV wiring/control
- House/Starter battery voltage monitoring
- GX GSM – reporting to VRM and geofencing
- Full installation schematics
MultiPlus Assistants – Webinar with Margreet Leeftink (47 mins)
This talk-through video familiarises us with the use of programming assistants. Many of the more specialised features of the MultiPlus have been added in response to requests from customers. This video demonstrates the way in which question and answer assistants work for programming:
- Safety switch
- Charge Current Control
- Input Current
- VE.Bus BMS
- Generator Start Stop
- Energy Storage Systems
- Self Consumption Hub
- …and more
MultiPlus: How it Works – Technical training with Johannes Boonstra (19 mins)
In this instructional video Johannes opens the casing of a MultiPlus and takes us on a tour of the components, providing the technology behind power inversion and battery charging. Learn about:
- Field-Effect Transistors (FETs) and their role in AC to DC, and DC to AC power conversion
- Grid/Generator frequency sine-wave synchronisation
- The control board
- Parallel operation
- Sizing Inverter according to typical use and battery bank
- Stand-by power reduction options
Introduction to AC PV Basic Training with Guy Stewart (33 mins)
AC PV Inverters offer efficient daytime power, but are invariably part of a larger installation offering 24 hour electricity. This video discusses:
- Off-grid and Grid-ties installations
- The significance of where the AC PV is installed in the system topography
- AC PV or DC PV – how to choose
- The 1:1 ratio for PV array and Inverter sizing
- Victron Brand compatibility
- Using an Energy Metre/ESS assistant/Fronius zero feed-in
- Advanced system schematics
Introduction to ESS – Basic Training with Guy Stewart (15 mins)
Energy Saving Systems maximise the economies of Solar Energy harvesting and offer some of the neatest solutions to customer needs. This video discusses:
- The main components of an ESS system
- When to use ESS
- Grid conditions improved by ESS
- Battery bank sizing – analysing performance on VRM
- When not to use ESS
Three-Phase and Parallel System theory – Webinar with Margreet Leeftink (44 mins)
In this webinar Margreet describes the observations necessary for setting up three-phase, parallel and split phase power systems. Among the topics discussed in detail – along with relevant hints, advice and cautions are:
- Victron Inverters capable of three-phase configuration
- Star configuration and Delta configuration topography
- Parallel configuration – maximum strings and output
- Single phase in – three phase out
- Physical arrangement of mounted devices
- Rules on wiring and fusing, and the importance of built-in AC resistance
- Three-phase rotation – mobile power supply
- Communication cabling – rules and wiring sequence
- The value of including a GX device
- Programming and settings
Three-Phase and Parallel System Installation – Advanced Training with Guy Stewart (27 mins)
Three Phase and parallel private power systems offer robust electricity for industrial use – even in the remotest locations. This video demonstrates:
- Victron Inverters suitable for use in three-phase systems
- Wiring/cabling sizing and advice
- Order of works during installation – Cautions
- Making VE.Bus connections
- VE.Bus System Configurator vs Quick Configure
- 3-phase – verifying installed unit to ‘Line out’ association
- Special notes about ‘Current Limit’ and unexpected cumulative results
- Connecting GX devices / confirming settings
