You’ll find a warm welcome and a chance to get ‘hands on’ with our latest products when you visit us on stand B4. 160 at Intersolar Europe on 14th – 16th June.
For almost fifty years we’ve been building the world’s largest range of Inverter/Chargers, Transformers, Solar Charge Controllers and related power devices for industrial, mobile, leisure, off-grid, and remote-site working applications.
Our power installations have user and engineer-access straight from your phone, or from the other side of the world.
We’re always adding exciting new products to provide you with power – anywhere – a selection of which we are highlighting at Intersolar Europe 2023.
Exhibition Highlights
- Multi RS Solar 48/6000 MPPT450/100 – this two MPPT tracker version replaces the former Multi RS that had one tracker. The two, fully independent, trackers are 3kW each. High efficiency, low standby, quiet in operation – it includes an on-board display together with Bluetooth for connection to a mobile device.
- Multi HS19 15kW is a rack mountable three-phase Inverter/Charger with 4 x Multi Power Point Tracking Solar Charge Controllers 800VDC from an (up to) 1000VDC, 32kWp solar array. The units can be paralleled to provide large industrial processes with power from an entirely sustainable energy supply. (This product is not yet available to order, but coming soon).
- Ekrano GX – our latest and most powerful GX communication and control device incorporates a 7 inch touch screen, an extensive range of communication ports and has twice the processing power of the Cerbo GX. Combining the advantages of visually-pleasing touch-control at the front, at the rear it offers extensive system connectivity: USB/VE.Direct/VE.Can/VE.Bus/Digital inputs/Resistive tank sender/Temp sensor together with Ethernet/WiFi/Bluetooth and a MicroSD card slot.
- Lynx Smart BMS 1000 is a Battery Management System especially designed for our Lithium Smart Batteries with greater current handling ability than the 500A version already available. Lynx BMS’s are part of our Lynx Distributor series of products offering Busbars with monitored fuses. (This product is not yet available to order, but coming soon).
- EV Charger NS is our new redesigned Electric Vehicle charger. The new style allows the charging cable to be coiled around the device which is now also available with a Black and a White fascia. It has no display – being entirely controlled from your phone using our VictronConnect app which allows you to set output charging current, charge your vehicle using only ‘surplus’ energy, configure scheduled charging and to monitor the charging progress.
- Energy Meter 3P offers faster measurements allowing three phase ESS (Energy Saving Systems) to respond more quickly. Featuring split-coil transformers for current measurement, rather than having to be wired in series with the distribution board, the new Energy Meter saves significantly on the installation time. Units are supplied with Current Transformers. (This product is not yet available to order, but coming soon).
Hybrid Generator
If your work includes the use of Site Generators come along and talk us about our extensive research into Hybrid Power Generation and our product configurations which result in up to 80% of on-site energy costs.
Hybrid power generation brings a new age of greener, quieter, and worry-free power for construction sites, remote industry, security/surveillance, and temporary power utilities – with cost savings you won’t quite believe.
We look forward to seeing you in Munich!
Exhibition location
Messe München
Messegelände
81823 Munich, Germany
Photo Credit. The image used at the head of this articles is © Solar Promotion
