We’re looking forward to seeing you on stand B4.150 at InterSolar 2024 in Munich between June 19th and 21st.
Allow us to show you the power that could be in your hands!
For almost fifty-years we’ve been known for building reliable inverter/chargers, solar charge controllers, DC-DC converters; and for our world-class monitoring and control apps for the Industrial, Marine, Mobile, Off-grid, Backup and Energy Storage markets.
At this year’s show we’re putting the spotlight on some ground-breaking solutions which become possible with our products and software.
Hybrid Generators
Learn how Hybrid Generators can save a remarkable 80% on fuel costs.
Also, the peak power shaving ability of our powerful inverters allows a smaller generator to be specified – cutting the cost of fixed assets. By sizing the site generator for the typical or average power demand, and allowing our powerful inverters to meet peak power demands there will be huge savings on the cost of plant.
Next Generation Storage is here
Take a look at our new generation Lithium Smart NG batteries. Available in 12.8V, 25.6V and 51.2V formats, up to 50 batteries can be configured into a single battery bank offering up to 384kWh of energy storage.
- remote read-out of cell voltages and other battery-level data
- increased maximum system size for each BMS, further extended by our new parallel BMS feature.
- improved balancing
Our new NG range of Lithium batteries deliver lots of power and have a very useful IP65 rating. Consumed power is also replaced super-fast using our dedicated Battery Management System the Lynx Smart BMS NG which is available in 500A and 1000A models. Up to 5 managed battery banks can be included in the same installation providing a lot of stored energy and deliverable power. And for installations where power absolutely MUST be available at all times, it’s reassuring to know there’s a lot of redundancy.
Lynx Class-T Power In
Our Lynx Distribution System range now includes a Power In model for Class-T fuses. The device provides M10 busbar connection for two battery strings with two mounts for T-Class fuses which can be 225A, 250A, 350A or 400A – to be purchased from your usual supplier.
Off-grid and Backup storage systems – including Multi HS19 and Multi RS19
Learn about our Inverter/Chargers for off-grid and energy storage systems – including our new rack mountable ‘Multi’ models which have MPPT Solar Charge Controllers on board.
The Multi HS19 is a new series of high voltage hybrid inverters. The first model to become available is the (800VDC) 3-phase 15kVA model with four MPPT trackers (which have a voltage range of 80 to 1000VDC). A 30kVA model will be available shortly thereafter. The range is designed for 19 inch rack mounting.
Similarly the Multi RS19 is a 48VDC single-phase 6kVA unit with two MPPT trackers built in, and is also designed for 19 inch rack mounting.
These multi-function, charge-controller, inverter/chargers are quick and easy to install in 19″ racks.
Headphone Audience – Live Presentation
Join one of our scheduled presentations for deeper learning about:
- Dynamic Energy Storage System algorithm which saves money on your energy bills by learning your amortisation costs, forecasting your energy use …and harvest, and making a cost comparison to live ‘day-ahead’ grid prices.
- Victron/Other manufacturer product compatibility – for seamless integration.
- Hybrid Generators – save up to 80% on fuel costs.
- Fleet Management – control hundreds or thousands of installations effortlessly with VRM.
Monitoring and Control
Learn about the latest features available straight to your phone from our world beating app VictronConnect; and how you can tailor the Victron Remote Management Platform VRM to your needs whether you follow a single system or you’re responsible for thousands…
MPPT Wall
Come and see the world’s largest range of Solar Charge Controllers. No one makes more MPPT and PWM charge controllers than we do. Learn how to choose a solar charge controller which is exactly right for the job, and what our range allows you to achieve.
Come and meet us on stand B4.150 and learn how our latest innovations are designed to help you keep control.
Intersolar Europe takes place in Germany at the Messe München on June 19th, 20th and 21st.
