We are excited to announce the launch of the GX Touch 50 and GX Touch 70 Flush Mount Versions! These new versions of the existing 5-inch and 7-inch touch screen displays for the Cerbo GX are designed to be mounted flush on the wall, providing a sleek and modern look for any installation.
Key Features:
1. Sleek, Modern Aesthetic
Achieve a clean, contemporary aesthetic with the new GX Touch Flush Mount versions. These updated versions of the GX Touch displays seamlessly integrate into the wall, offering a sleek and streamlined appearance.
2. Versatile Mounting Options
The GX Touch 50 and 70 Flush Mount Versions come with two different mounting options to suit various installation needs:
Sealed Mount:
A rubber seal is applied to a double-sided tape on the screen, and the GX Touch screen is installed using brackets and rods. This method ensures a secure and stable mount, preventing water from getting behind the screen while also allowing for easy removal if needed. This method can only be used on flat and clean surfaces with rear access.
Glued Mount:
For installations where rear access to the mounting surface is not available, the screen can be glued in place using double-sided tape. This method is straightforward and effective for achieving a flush mount without the need for additional hardware.
3. Durability
With an IP65 rating, the GX Touch 50 and 70 Flush Mount Versions are perfect for a variety of environments, including marine applications. Whether you’re installing on a yacht or an overlander, these models offer the durability and protection needed to withstand humidity and water sprays. The seal ensures no water gets behind the mounting panel, keeping the IP65-rated screen dry regardless of the mounting method.
4. Installation Flexibility
The sealed mount offers an alternative to the glued mount, particularly advantageous if glue is not preferred and there is rear access to the mounting surface. For both mounting options, there are two different intsallation methods:
Standard Installation:
This method involves creating an opening in the wall or panel and then securing the screen using either tape or a rubber seal. With this installation method, the frame of the display will protrude from the wall or panel.
Recessed Installation:
In this installation method, the frame surrounding the screen is embedded into the wall or panel, ensuring the screen surface aligns perfectly with the surrounding surface, resulting in a fully flush appearance.
Ensure the surface is smooth and clean for both installation methods
Full Product Details:
For more detailed information on the GX Touch 50 and GX Touch 70 Flush Mount Versions, visit our product page and experience the perfect blend of functionality and style.
