1. Charge & Convert
  2. EV Charging
EV Charging Station
The EV Charging Station has three-phase and single-phase capabilities. It delivers a maximum of 22kW AC in three-phase or 7.3kW in single-phase mode.
It has a built-in LCD touch screen for monitoring and control directly from the charging station. Initial setup, configuration and monitoring is done from VictronConnect via Bluetooth and/or the integrated web interface via a WiFi Access Point or a WiFi LAN.
The EV Charging Station can be fully integrated with and remotely controlled via a Victron Energy GX Device and VRM.
Not only does this EV Charging Station fully integrate with a Victron Energy GX device and VRM, if you have solar (within the Victron ecosystem), it can also be set up to allow excess energy from the sun to directly charge your vehicle. Manual and scheduled modes offer even more flexibility to respond to the needs of the EV depending on the system.
It has a fully programmable RGB light ring around the charging port that displays different light effects depending on the current status (disconnected, charging, charged, etc.) to quickly determine the device status.
EV Charging Station
EV Charging Station
background
Year warranty
World-wide support
About this
product
Downloads
and support
Datasheets
  • EV Charging Station
    .PDF
Manuals
  • EV Charging Station (HTML5)
    .HTML
  • EV Charging Station (PDF)
    .PDF
Enclosure Dimensions
    .PDF
  • EV Charging Station (3D)
    .PDF
  • EV Charging Station (stp)
High Quality Photos
  • EV Charging Station (back)  thumbnail
    .PNG
  • EV Charging Station (front-angle)  thumbnail
    .PNG
  • EV Charging Station (front-angle-open)  thumbnail
    .PNG
  • EV Charging Station (left) thumbnail
    .PNG
  • EV Charging Station (right)  thumbnail
    .PNG
  • EV Charging Station (side) thumbnail
    .PNG
  • EV Charging Station (side-angle) thumbnail
    .PNG
  • EV-Charging-Station-(top)  thumbnail
    .PNG
  • EV-Charging-Station-(top_)  thumbnail
    .PNG
  • EV-Charging-Station-(top1)  thumbnail
    .PNG
Videos
  • EV Charging Station Victron Energy - Technical Guide
Technical Information
  • Modbus TCP register list EVCS
    .XLSX
Certificates
  • Certificate - EN/IEC 61851-1 EV Charging Station
    .PDF
  • Declaration of Conformity - EV Charging Station
    .PDF
  • ISO9001 certificate
    .PDF
Support
Warranty
Read more about our industry leading 5 year standard warranty service.
Warranty
Stay informed
Subscribe to our newsletter
Socials
Victron Energy
Victron Energy
©Victron Energy 2025
