The CCGX has a relay - switch - which can automatically start a pump. The switch is triggered by 'tank level' data, received from a tank-sender. The level at which the switch is automatically tripped is user-definable.
An additional Overview page is available which shows at-a-glance status information from all tanks connected to the CCGX. To enable the tank overview page from the main menu go to: Settings → Display and language → Show boat and motorhome overview. You will now find that 'Mobile' has been added to CCGX 'homepage showing: 'Overview' and 'Tiles'.
It is also posible to change Multi/Quattro AC current limit and mode when those functions are available.
To enable the pump start/stop functionality go to Settings →Relay; and set the function to “Tank pump”.
Start level: When the tank level reaches this value the pump will be started.
Stop level: When the tank level reaches this value the pump will be stopped.
