How to add dimming functionality to a solar lighting system
Benefits of dimming
Energy consumption can be substantially reduced by light-dimming when appropriate.
Lower energy consumption will reduce overall system cost, and increase light availability even when the battery has only been partially charged due to bad weather.
Cable required for dimming
Use the VE.Direct TX digital output cable ASS030550500 (previously called PWM light dimming cable) which can then be used together with an MPPT 75/10, 75/15 or 100/15.
This cable is intended for solar lighting applications (more applications may follow later).
The TX cable connects the TX pin on the VE.Direct connector of an MPPT 75/15 or 100/15 to the PWM light dimming input of a LED driver.
Firmware and software requirements
The MPPT solar charge controller must have firmware version V1.15 or higher.
An MPPT with an older version can be upgraded with VE Power Setup.
