This document is an add-on to our Datacommunication whitepaper. That whitepaper contains a list of PGNs transmitted by each product type. This document defines the bit definitions of the switch banks.
Download the main document, the Datacommunication whitepaper, from the whitepapers section on our website.
Note that besides the standard NMEA2000 PGNs, Victron devices also transmit proprietary messages, called VREGs. VREGs are used for all parameters cannot be sent with standard NMEA 2000 PGNs. The VREG PGN number is 61184 (0xEF00), and it is sent to the broadcast address 61439 (0xEFFF).
See the document “VE.Can registers - public.docx” for detailed VREG information and examples. It is available for download on the whitepaper section on our website..
This message is no longer transmitted and has been replaced by PGN 127501.
This applies to products with versions as specified in the table below or newer.
Product | Version |
BlueSolar MPPT 150/70 & 150/85 | v2.00 |
Lynx Shunt VE.Can | v1.00 |
Skylla-i (all models) | v1.08 |
VE.Direct to VE.Can\NMEA 2000 interface | v1.06 |
VE.Bus to VE.Can\NMEA 2000 interface | v0.12 |
This PGN is sent out by multiple products, however the details differ per product.
Signal | Meaning |
Bank Instance | Instance of the message, default value 0 |
Status 1 - Relay | “On” - The relay on the charger is active, the contact is closed |
Status 2 - Alarm | “On” - There is an alarm condition |
Status 3 - Low voltage | “On” - Battery voltage is too low |
Status 4 - High voltage | “On” - Battery voltage is too high |
Status 5 - Solar activity* | “On” - Solar panel irradiated (can be used for day/night detection) |
Status 6 … 28 | Not used, reports as “Unavailable” |
* Since v2.01
When the Alarm status bit is set to “On”, the alarm reason can be queried using Victron propietary register 0xEDDA (Charger error code).
Since v1.07 the Lynx Shunt also transmits PGN 127501 for the relay trigger reason next to the PGN with the alarm reason.
The mapping of the status bits is identical to the alarm message.
The default instance of the alarm message is 0, as the default instance for the relay message is 1.
Signal | Meaning |
Bank Instance | Instance of the message Default value for alarm message is 0 Default value for relay message is 1 |
Status 1 – Low voltage | “On” – Battery voltage is too low |
Status 2 – High voltage | “On” – Battery voltage is too high |
Status 3 – Low SOC | “On” – The Battery state of charge is too low |
Status 4 – Low fused voltage | “On” – Fused voltage is too low |
Status 5 – High fused voltage | “On” – Fused voltage is too high |
Status 6 – Fuse blown | “On” – The fuse is blown |
Status 7 – High battery temperature | “On” – Battery temperature is too high |
Status 8 – Low battery temperature | “On” – Battery temperature is too low |
Status 9 – High internal temperature | “On” – Internal temperature is too high |
Status 10 … 28 | Not used, report as “Unavailable” |
The alarm and relay thresholds can be configured using Victron proprietary registers.
Signal | Meaning |
Status 5 … 28 | Not used, reports as “Unavailable” |
See the manual of the VE.Direct to VE.Can interface: https://www.victronenergy.com/accessories/ve-direct-to-ve-can-interface
See the manual of the VE.Direct to VE.Can interface: https://www.victronenergy.com/accessories/ve-bus-to-nmea2000-interface
