The GX-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. Monitoring can be carried out locally and remotely - via our free-to-use Victron Remote Management portal (VRM). The GX device also provides Remote firmware updates and allows inverter/charger settings to be changed remotely.
Lastly, there is a GX device built into our MultiPlus-II GX and EasySolar-II GX Inverter/chargers.
User interface | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX | MultiPlus-II GX and EasySolar-II GX | |||
Appearance | ![]() | ![]() | ![]() | ![]() | ![]() | ![]() | ![]() | |||
Display | ![]() 1024 x 600 LCD built-in 7“ touchscreen | ![]() GX Touch optional touch display (16) GX Touch 50: 800 x 480 GX Touch 70: 1024 x 600 | 480 x 272 LCD Display & 7 buttons | no display | 4.3” touch-screen | ![]() | ||||
Remote Console | yes | |||||||||
Buzzer | yes | no | ||||||||
Product detail page & manual download | Ekrano GX | Cerbo GX | CCGX | Venus GX | CANvu GX | MP-II & ES-II GX | ||||
Victron comm. ports | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX(12) | MultiPlus-II GX and EasySolar-II GX | |||
VE.Direct ports (always isolated) | 3 (1) | 2 (1) | 3 (1) | 1 | ||||||
VE.Bus (always isolated) | 2 paralleled RJ45 sockets | |||||||||
VE.Can | yes VE.Can 1 isolated VE.Can 2 non-isolated | yes - non-isolated | yes VE.Can 1 isolated VE.Can 2 non-isolated | 2 paralleled RJ45 sockets – isolated | depends (14, 23) 2 paralleled RJ45 sockets – isolated | depends (14, 23) | ||||
Other comm. ports | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX | MultiPlus-II GX and EasySolar-II GX | |||
USB | 2 USB Host ports | 2 USB Host ports & 1 power only port (21) | 3 USB Host ports | 2 USB Host ports | 1 USB Host port | |||||
Ethernet | 10/100 RJ45 socket - isolated except shield | 10/100 RJ45 socket (12) | 10/100 RJ45 socket | |||||||
WiFi | built-in | optional (2) | built-in, but see (3) | optional (2) | built-in | |||||
Bluetooth Smart | yes (17) | no | depends (23) | |||||||
Micro SDcard slot | SDHC cards up to max. of 32GB (5) | no | no | |||||||
Second CAN bus port (18) | yes - see VE.Can | BMS-Can only (15) | yes - see VE.Can | no | yes - non-isolated | no | no | |||
Built-in RS485 | no | |||||||||
IO | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX(12) | MultiPlus-II GX and EasySolar-II GX | |||
Programmable relay (7) | 2 x NO/NC (8) DC up to 30VDC: 3A AC: 1A, 125VAC | 2 x NO/NC (8) DC up to 30VDC: 6A DC up to 70VDC: 1A AC: 6A, 125VAC | 1 x NO | 1 x NO/NC (8) | 1x NO / NC | n/a | ||||
Resistive tank level inputs | 3 (9) | 4 (9) | no | 3 (9) | no | |||||
Temperature sense inputs | 2 (10) | 4 (10) | no | 2 (10) | no | |||||
Digital Inputs | 2 (22) | 4 (22) | no | 5 (22) | 1 (22) | no | ||||
Third party compatibility | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX | MultiPlus-II GX and EasySolar-II GX | |||
Canbus-BMS batteries | Many battery brands. See here for details | |||||||||
Fronius PV Inverters | See here for details | |||||||||
SMA PV Inverters | See here for details | |||||||||
ABB/FIMER PV Inverters | See here for details | |||||||||
SolarEdge PV Inverters | See here for details | |||||||||
Marine MFD App Support | Generic MFD Manual, Navico, Garmin, Raymarine, Furuno | |||||||||
Mopeka Pro Check LPG & Water Bluetooth tank sensor (24) | See here for details | |||||||||
RuuviTag Bluetooth temperature sensor (24) | See here for details | |||||||||
Performance | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX | MultiPlus-II GX and EasySolar-II GX | |||
CPU | quad core | dual core | single core | quad core | ||||||
RAM | 1GB | 256MB | 512MB | 256MB | 512MB | |||||
Max. VE.Direct devices (1) | 25 | 15 | 5 | 6 | 4 | 25 | ||||
Other | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX | MultiPlus-II GX and EasySolar-II GX | |||
Supply voltage | 8 - 70 VDC | 8 - 32 VDC | powered internally, no external supply | |||||||
Power draw | 2,6 to 7.4 W (25) | 2,5 to 5 W (19) | tbd | |||||||
Mounting | Flush panel mounting or blind hole mounting | Wall or DIN rail (35mm)(20) | Panel Integration | Wall mounting | Panel | Built-in | ||||
Outer dimensions ( h x w x d ) | 124 x 187 x 29.8 mm | 78 x 154 x 48 mm | 130 x 120 x 28 mm | 45 x 143 x 96 mm | tbd | |||||
Operating temperature | -20 to +50°C | -20 to +70°C | ||||||||
Battery backup clock | yes | no | yes | |||||||
5V output | no | 1 A (13) | no | |||||||
Standards | Ekrano GX | Cerbo GX | Cerbo GX MK2 | CCGX | Venus GX | CANvu GX | MultiPlus-II GX and EasySolar-II GX | |||
Safety | IEC 62368-1 | EN 60950 | IEC 62368-1 | IEC 62109-1 IEC62109-2 IEC62040-1 | ||||||
EMC | EN 301489-1, EN301489-17 | |||||||||
Automotive | ECE R10-6 | E4-10R-053535 | ECE R10-6 | no |
