ac_coupling:fronius
ac_coupling:fronius [2023-09-01 11:47] – Fix MicroGrid flyer link sloges | ac_coupling:fronius [2024-10-09 07:42] (current) – guy_stewart | ||
Line 264: | Line 264: | ||
To update earlier and/or already installed PV Inverters, contact Fronius Tech Support for the file. The required file is fro29130.upd. Which works for all snap-inverter models (Primo, Symo and Eco). There is no, and will be no, fix available for Fronius Galvos. | To update earlier and/or already installed PV Inverters, contact Fronius Tech Support for the file. The required file is fro29130.upd. Which works for all snap-inverter models (Primo, Symo and Eco). There is no, and will be no, fix available for Fronius Galvos. | ||
- | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter | + | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter, or Multiphase, or cannot be configured as 3-phase? ==== |
Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
Line 272: | Line 272: | ||
* Set Data export via Modbus to tcp. | * Set Data export via Modbus to tcp. | ||
* set Sunspec Model Type to int + SF | * set Sunspec Model Type to int + SF | ||
- | ~~DISQUS~~ | ||
ac_coupling/fronius.1693561670.txt.gz · Last modified: 2023-09-01 11:47 by sloges
