ac_coupling:start
ac_coupling:start [2017-10-26 23:41] – [4 Software configuration] mvader | ac_coupling:start [2022-04-12 06:47] (current) – [1.1 What is AC-coupling?] bob | ||
Line 2: | Line 2: | ||
===== 1. Introduction to the AC-Coupling concept ===== | ===== 1. Introduction to the AC-Coupling concept ===== | ||
- | Already familiar with the concepts of AC-coupling and regulating PV inverter output power by frequency shifting? Skip to [[: | + | Already familiar with the concepts of AC-coupling and regulating PV inverter output power by frequency shifting? Skip to the requirements and limitations: |
Line 16: | Line 24: | ||
+ | * To read out SMA inverters, see [[ccgx: | ||
Line 26: | Line 35: | ||
- | ===== 2. The 1.0 rule: Max PV power must be equal or less than the VA rating of the Multi ===== | + | ===== 2. The Factor |
+ | **The max PV power must be equal or less than the VA rating of the inverter/ | ||
- | In both grid-connected and off-grid systems with PV inverters installed on the output of a Multi, Inverter or Quattro, there is a maximum of PV power that can be installed. This limit is called the __factor 1.0 rule__: 3.000 VA Multi = 3.000 Wp installed solar power. So for a 8.000 VA Quattro the maximum is 8.000 Wp, for two paralleled 8000 VA Quattros the maximum is 16.000 Wp, etcetera. | + | In both grid-connected and off-grid systems with PV inverters installed on the output of a Multi, Inverter or Quattro, there is a maximum of PV power that can be installed. This limit is called the __factor 1.0 rule__: 3.000 VA Multi >= 3.000 Wp installed solar power. So for a 8.000 VA Quattro the maximum is 8.000 Wp, for two paralleled 8000 VA Quattros the maximum is 16.000 Wp, etc. |
Line 42: | Line 52: | ||
Line 51: | Line 61: | ||
Line 62: | Line 72: | ||
- | 1 kWp installed PV power requires: | + | 1 kWp installed PV power requires |
+ | Each additional 1 kWp of AC PV will require an additional proportional 5 kWh increase in lead acid battery storage. | ||
- | 1,5 kWp installed PV power requires: | + | 1,5 kWp installed |
- | ==== 4 Software configuration | + | Each additional 1.5 kWp of AC PV will require an additional proportional 4.8 kWh increase in battery storage. |
+ | ===== 4 Requirement of adding DC-Coupling - MPPT Solar Chargers ===== | ||
- | Multis and Quattros with factory settings will not shift the AC output frequency to regulate charge current. When setting up an AC Coupled system, install either the [[ess: | + | Not required |
- | Other options, | + | Required for offgrid systems as well as backup systems that need to overcome extended grid failures. |
+ | Reason: recover from deadlock situation of AC-Coupling only situation. | ||
+ | There is no Factor 1.0 limit that applies for DC coupled PV through a Victron MPPT. Nor is there a specific minimum amount of battery storage capacity, though please follow battery manufacture specifications for maximum charge rates. A rule of thumb is C10 (10% of Ah capacity in A) for lead acid batteries, and C2 (50% of Ah capacity in A) for lithium batteries. | ||
+ | ===== 5 Software configuration ===== | ||
+ | Multis and Quattros with factory settings will not shift the AC output frequency to regulate charge current. When setting up an AC Coupled system, install either the [[ess: | ||
+ | The Inverter RS will automatically shift frequency without any additional configuration required when a surplus/ | ||
+ | Other options, | ||
- Self-consumption Hub-2 v3 assistant | - Self-consumption Hub-2 v3 assistant | ||
+ | See [[https:// | ||
ac_coupling/start.1509054102.txt.gz · Last modified: by mvader
