ac_current_sensor:start
ac_current_sensor:start [2018-11-30 09:23] – [Multi and Quattro hardware requirements] rzijlstra-victronenergyac_current_sensor:start [2019-08-15 12:40] (current) – replace venus-device with GX device guy_stewart
Line 4: Line 4:
 {{ :ac_current_sensor:ac-current-sensor_cse000100000_front-angle.jpg?nolink&300|}} {{ :ac_current_sensor:ac-current-sensor_cse000100000_front-angle.jpg?nolink&300|}}
 ==== Introduction ==== ==== Introduction ====
-The AC Current sensor is a simple external current sensor used to measure AC CurrentPower (VA) and calculate energy of a PV inverter connected to the AC input or output of a Multi or Quattro. These values can then be displayed and sent to the VRM-website by the Color Control. The two measurement wires can be connected to the AUX and/or temperature sense input of Multi or Quattro.+
 +Use the AC Current sensor to measure and visualise the solar production of a PV Inverter. The measurements will be visible on the [[venus-os:start|GX device]] and on the [[https://vrm.victronenergy.com|VRM Portal]].
 +The sensor is a simple external current sensor, which measures AC Current. Together with the voltage measurements is calculated into Apparent Power (VA) and Energy (kWh). The sensor can be wired to either the AUX input or the Temperature-input of Multi and Quattro inverter/chargers.
 +The AC Current Sensor is one out of multiple options to visualise the solar yield in a Victron system. See [[ccgx:start#measuring_pv_inverter_output|here]] for an overview.
 +==== Specifications ====
 +^Power range ^  1.5 kW  ^  3 kW  ^  5 kW  ^  7 kW  ^  unit  ^
 +|Power step size Approx depends on input voltage (230V AC) |  9  |  17  |  30  |  35  |  W  |
 +|Power step size Approx depends on input voltage (120V AC) |  4.5  |  8.5  |  15  |  17.5  |  W  |
 +|Max measured Current |  8  |  16  |  25  |  30.5  |  A  |
 +|Max Input current |  9  |  18  |  30  |  40  |  A  |
 +|Dipswitch         |  all off  |  1  |  1,2  |  1,2,3  | |
 +|Max # of sensors in one system    9  |||||
 +|Protection category |  IP54  |||||
 ==== Multi and Quattro hardware requirements ==== ==== Multi and Quattro hardware requirements ====
Line 10: Line 27:
   - The TEMP-sense input of all Multi’s and Quattro’s is suitable for the AC Current Sensor.   - The TEMP-sense input of all Multi’s and Quattro’s is suitable for the AC Current Sensor.
   - The AUX-input however is not, see serial number list below to check your hardware.   - The AUX-input however is not, see serial number list below to check your hardware.
-  - The Multiplus-II  until hardware revison 8 uses the RJ12 connector between pin 1 and 5. Refer to appendix A of the manual +  - The Multi or Quattro needs to be connected on the VE.Bus port of the Color Control GX: readout will __not__ work when connected on the VE.Can port using a [[https://www.victronenergy.com/accessories/ve-can-to-ve-bus-interface|VE.Bus to VE.Can interface cable]]
-  - the Multi or Quattro needs to be connected on the VE.Bus port of the Color Control GX: readout will __not__ work when connected on the VE.Can port using a [[https://www.victronenergy.com/accessories/ve-can-to-ve-bus-interface|VE.Bus to VE.Can interface cable]].+
 +  - On the Multiplus-II hardware revision 0 to 8, the AUX input is on the RJ12 connector, pin 1 and 5. Refer to appendix A of the Multiplus-II manual. In later revisions the AUX input is available as a normal terminal again.
 +  - This AC Current sensor (CSE000100000) should not be confused with the specific Current Transformer 100A:50mA accessory for MultiPlus-II (part number CTR110000500).
 ==== Installation ==== ==== Installation ====
 {{ :ac_current_sensor:image1.jpg?nolink&400|}} {{ :ac_current_sensor:image1.jpg?nolink&400|}}
-  - Put one of the AC wires of the PV inverter through the AC Current sensor.+  - Pull one of the AC wires of the PV inverter through the AC Current sensor.
   - Connect the sensor to the AUX or TEMP-sense input of an Inverter, Multi or Quattro in the same phase as being measured by that current sensor.   - Connect the sensor to the AUX or TEMP-sense input of an Inverter, Multi or Quattro in the same phase as being measured by that current sensor.
   - Configure the power range with the dipswitches. Select the power equal or higher than the maximum expected power. For example, with a 4kW PV installation, the correct dipswitch setting is 5kW.   - Configure the power range with the dipswitches. Select the power equal or higher than the maximum expected power. For example, with a 4kW PV installation, the correct dipswitch setting is 5kW.
Line 22: Line 41:
 ==== Configuration ==== ==== Configuration ====
-  - Upgrade the Multi or Quattro firmware to the latest version (2xx). Instructions are in the VEConfigure3 requirements document. Download fromwww.victronenergy.com/support-and-downloads/software+  - Make sure the firmware in the inverter/charger is 2xx or later. Instructions [[updating_firmware:updating_ve.bus_products|here]].
   - Parallel and three-phase systems: configure parallel or three-phase operation first.   - Parallel and three-phase systems: configure parallel or three-phase operation first.
   - Then use the VEConfigure3 to add and configure the 'AC Current sensor’ assistant.   - Then use the VEConfigure3 to add and configure the 'AC Current sensor’ assistant.
   - Parallel and three-phase systems: add the assistant to each Multi or Quattro that has an AC Current sensor connected to it.   - Parallel and three-phase systems: add the assistant to each Multi or Quattro that has an AC Current sensor connected to it.
-  - Make sure that the Color Control is running firmware version v1.11 or newer+  - Whilst the minimum required firmware in the [[venus-os:start|GX device]] is v1.30, we require running on a more recent version.
-  - Select the correct profile on the Color Control: Settings -> System setup.+  - Select the correct profile on the [[venus-os:start|GX device]]: Settings -> System setup.
-==== FAQ ==== +==== Compatibility list ====
-===How many AC Current Sensors can I connect in one VE.Bus system?=== +
-The current maximum is four sensors. Note that each need to be configured separately with an assistant in the Multi or Quattro to which it is wired. The maximum of four will be increased to 9, in CCGX version v1.30, planned for December 2015+
-==Specification==
-^Power range ^1.5kW ^3kW ^5kW ^7kW ^Not used^^
-|Power step size Approx depends on input voltage (230V AC) |9 |17 |30 |35 |- |W|
-|Power step size Approx depends on input voltage (120V AC) |4.5 |8.5 |15 |17.5 |- |W|
-|Max measured Current |8 |16 |25 |30.5 |- |A|
-|Max Input current |9 |18 |30 |40 |- |A|
-|Dipswitch |- |1 |1,2 |1,2,3 |1,2,3,4| ON|
-|Protection category |IP54||||||
 ^Supported models ^^AUX input ^TEMP input ^ ^Supported models ^^AUX input ^TEMP input ^
 ^Product code ^Description ^Minimum SN# ^Minimum SN# ^ ^Product code ^Description ^Minimum SN# ^Minimum SN# ^
Line 73: Line 79:
 |PMP485021014 |Multi-G 48/5000/70-100 |All serial numbers |All serial numbers| |PMP485021014 |Multi-G 48/5000/70-100 |All serial numbers |All serial numbers|
 |_||||  |_||||
-|Other models ||Not yet implemented. |All serial numbers|+|Other models ||All serial numbers |All serial numbers|
 ~~DISQUS~~ ~~DISQUS~~
ac_current_sensor/start.1543566194.txt.gz · Last modified: by rzijlstra-victronenergy
