assistants:how_to_add_and_configure_an_assistant
assistants:how_to_add_and_configure_an_assistant [2014-08-03 11:56] – mvader | assistants:how_to_add_and_configure_an_assistant [2021-09-17 09:11] (current) – mvader | ||
====== How to add an Assistant from start to finish ====== | ====== How to add an Assistant from start to finish ====== | ||
- | Note: this example refers to an assistant | + | Note: below screenshots are just an example. The same procedure works for other Assistants as well. The used example refers to an Assistant |
+ | Note for three-phase and parallel systems: some Assistants need to be configured in in all Multis or Quattros in the system, others only in the master of L1 or in all phase-masters. Carefully read the instructions in the Assistant pages while configuring. | ||
+ | ==== Prerequisite ==== | ||
+ | To work with Assistants, VE.Bus Multis, Inverters and Quattros must be loaded with a a different firmware first. More information about which firmware type to choose for an installation, | ||
- | Open VEConfigure3 on your computer, connect to the Victron product and open the assistants | + | Open VEConfigure3 on your computer, connect to the Victron product and open the Assistants |
Then, from the drop down menu select the Grid Converter support | Then, from the drop down menu select the Grid Converter support | ||
Line 15: | Line 20: | ||
- | The assistant will appear in the ‘Used assistants’ box but it will be Italic since it has not been configured yet. | + | The assistant will appear in the ‘Used assistants’ box and it will be in italics, as it has not been configured yet. |
Now Click on Start assistant | Now Click on Start assistant | ||
Line 67: | Line 72: | ||
assistants/how_to_add_and_configure_an_assistant.1407059806.txt.gz · Last modified: by mvader
