assistants:how_to_add_and_configure_an_assistant
assistants:how_to_add_and_configure_an_assistant [2014-08-03 18:48] – [How to add an Assistant from start to finish] mvader | assistants:how_to_add_and_configure_an_assistant [2021-09-17 09:11] (current) – mvader | ||
Line 4: | Line 4: | ||
Note for three-phase and parallel systems: some Assistants need to be configured in in all Multis or Quattros in the system, others only in the master of L1 or in all phase-masters. Carefully read the instructions in the Assistant pages while configuring. | Note for three-phase and parallel systems: some Assistants need to be configured in in all Multis or Quattros in the system, others only in the master of L1 or in all phase-masters. Carefully read the instructions in the Assistant pages while configuring. | ||
+ | ==== Prerequisite ==== | ||
+ | To work with Assistants, VE.Bus Multis, Inverters and Quattros must be loaded with a a different firmware first. More information about which firmware type to choose for an installation, | ||
Line 17: | Line 20: | ||
- | The assistant will appear in the ‘Used assistants’ box but it will be Italic since it has not been configured yet. | + | The assistant will appear in the ‘Used assistants’ box and it will be in italics, as it has not been configured yet. |
Now Click on Start assistant | Now Click on Start assistant | ||
Line 69: | Line 72: | ||
assistants/how_to_add_and_configure_an_assistant.1407084526.txt.gz · Last modified: by mvader
