assistants:start
assistants:start [2016-01-08 16:39] – ictbeheer | assistants:start [2024-09-06 08:36] (current) – [What is next?] guy_stewart | ||
- | ====== Assistants | + | ====== |
Line 5: | Line 5: | ||
==== What are Assistants? ==== | ==== What are Assistants? ==== | ||
- | Think of Assistants as apps, as on a smart phone. Assistants are little applications that run inside a VE.Bus Multi, Inverter or Quattro. They reduce the overall cost of a system: in 99% of all installations it will not be necessary to add an additional PLC to get for example load shedding, optimizing use of solar energy or automatically starting and stopping a genset. | + | Think of Assistants as apps, as on a smart phone. Assistants are little applications that run inside a VE.Bus Multi, Inverter or Quattro. They reduce the overall cost of a system: in 99% of all installations it will not be necessary to add an additional PLC (Programmable Logic Controller) |
- | In advanced systems you can also combine multiple assistants, it can even be usefull | + | In advanced systems you can also combine multiple assistants, it can even be useful |
To get a better understanding of the possibilities, | To get a better understanding of the possibilities, | ||
Line 32: | Line 32: | ||
==== What is next? ==== | ==== What is next? ==== | ||
- | * [[assistants: | ||
- | To keep posted on new Assistant | + | * [[: |
+ | * [[:assistants: | ||
+ | * [[dc_coupling: | ||
+ | ==== Combining multiple Assistants ==== | ||
+ | Multiple Assistants can be used in one unit. For example the Programmable Relay is often used multiple times. When doing so; this is how they are evaluated: | ||
+ | - an ON condition always has priority over an OFF condition | ||
+ | - multi criteria in the ON ( or OFF ) list go by the OR principle | ||
assistants/start.1452267592.txt.gz · Last modified: 2016-01-08 16:39 by ictbeheer
