battery_compatibility:axistorage
battery_compatibility:axistorage [2018-02-07 10:51] – martijncoster | battery_compatibility:axistorage [2019-08-15 12:18] (current) – replace venus-device with GX device guy_stewart | ||
Line 7: | Line 7: | ||
- | All 48V Multis and Quattros. A Venus device is necessary in the system, since that has the canbus port which is used for the (required!) communication between the ESS battery and the Victron system. | + | All 48V Multis and Quattros. A [[venus-os: |
Line 21: | Line 21: | ||
- | ==== 2. Venus device needed ==== | + | ==== 2. GX device needed ==== |
To use the AXIstorage ESS in Victron system, it is necessary to use a ColorControlGX or a VenusGX. The controller takes care of sending the necessary canbus keep-a-live message to the ESS battery. Without it, the battery will open its internal emergency relay after 10 minutes. | To use the AXIstorage ESS in Victron system, it is necessary to use a ColorControlGX or a VenusGX. The controller takes care of sending the necessary canbus keep-a-live message to the ESS battery. Without it, the battery will open its internal emergency relay after 10 minutes. | ||
==== 3. Wiring of communication cables ==== | ==== 3. Wiring of communication cables ==== | ||
- | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the AXIstorage BMS. Plug the side labeled Victron VE.Can into the Venus-device. | + | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the AXIstorage BMS. Plug the side labeled Victron VE.Can into the [[venus-os: |
- | Without properly connecting this cable, the battery will stop charging/ | + | Without properly connecting this cable, the battery will stop charging/ |
Line 62: | Line 62: | ||
- | ==== 5. Venus device Configuration ==== | + | ==== 5. GX device Configuration ==== |
- | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the Venus device. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: |
* After properly wiring and setting up, the AXIstorage will be visible as a battery in the device list:{{ : | * After properly wiring and setting up, the AXIstorage will be visible as a battery in the device list:{{ : | ||
battery_compatibility/axistorage.1517997065.txt.gz · Last modified: 2018-02-07 10:51 by martijncoster
