battery_compatibility:bluenova [2021-07-22 17:18] – dirkbluenova | battery_compatibility:bluenova [2022-04-07 10:40] (current) – dirkbluenova |
==== 3. Wiring of Can.Bus cable between BlueNova Energy and GX device. ==== | ==== 3. Wiring of Can.Bus cable between BlueNova Energy and GX device. ==== |
{{https://www.victronenergy.com/live/_media/battery_compatibility:bn52v-77-4k_ng.jpg}} | |
| {{:battery_compatibility:bn52v-240-12.5k_hc.gif?400|}} |
No RJ45 cable is supplied for this connection . | No RJ45 cable is supplied for this connection . |
Plug the GX device side of the cable into one of the VE.Can sockets on the back of the GX device or "BMS Can" . Plug the other end into the battery at one of the RJ45 CANbus ports. A VE.Can terminator is not nescessary for the other VE.Can socket on the GX device.( This is applicable for the BlueNova Energy "SSS" range of batteries. The RacPower( BP(with CANbus...) & DU range of BlueNova Energy batteries need to have CANbus terminations done, supplied as per each RacPower unit) | Plug the GX device side of the cable into one of the VE.Can sockets on the back of the GX device or "BMS Can" . Plug the other end into the battery at one of the RJ45 CANbus ports. A VE.Can terminator is not nescessary for the other VE.Can socket on the GX device.( This is applicable for the BlueNova Energy "SSS" range of batteries. The RacPower( BP & DU )range of BlueNova Energy batteries need to have CANbus terminations done, supplied as per each RacPower unit |
For BlueNova Energy RacPower batteries(latest "DU" and "BP" models) with CANbus and RS485, please contact BlueNova Energy Technical Support for correct interlink comms cable configurations, especially where a BlueNova Energy BMAC Online units is present. | For BlueNova Energy RacPower batteries(latest "DU" and "BP" models) with CANbus and RS485, please contact BlueNova Energy Technical Support for correct interlink comms cable configurations, especially where a BlueNova Energy BMAC Online units is present. |
Without properly connecting this cable, the battery will stop charging/discharging after several minutes. Also, the battery will not show up on the display of the GX device. | Without properly connecting this cable, the battery will stop charging/discharging after several minutes. Also, the battery will not show up on the Menu/display of the GX device. |
| To view more information on the RacPower BP, see [[http://www.bluenova.co.za/wp-content/uploads/2022/04/BN%20User%20Manual%20-%20RacPower%20BN52V-100-5.2k%20BP%20with%20CAN_v103.pdf|User Manual here]]. |
| To view more information on the RacPower DU, see [[http://www.bluenova.co.za/wp-content/uploads/2022/04/BN-UserManual_52V-5.2k%20DU%20RacPower_v104.pdf|User Manual here]]. |
=== 4.1 Charge parameters === | === 4.1 Charge parameters === |
{{:battery_compatibility:battery_volteges_2021_03_29_victron_energy.jpg |}} | {{:battery_compatibility:battery_voltages_2022_01_14_c.png?400 |}} |
