Victron & BSL
Product & System compatibility
The integration with Victron and BSL batteries has been tested, complies with Victron's BMS-Can specification, and is supported by both companies.
Offgrid, Backup and Energy Storage Systems (ESS)
Victron + BSL can be used for the following system types:
- Grid Backup
- Off-grid
Special note for Off-Grid systems
For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, and factor 1.0 are always important to adhere to, and even more so in case of Off-grid systems. Both BSL and Victron will be reluctant or even refusing to give support to systems that are not sized according to the minimum specified configurations.
A GX device is required, eg Cerbo GX, etc
It is essential to use the BMS-Can (or CAN-bus) connection of a GX device with the BSL batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge.
The minimum supported firmware version for the GX device is v2.52. It is recommended to use the latest firmware version on new installations and when trouble shooting issues.
All 48V Multis, MultiPlusses, MultiGrids and Quattros are compatible
The minimum supported firmware version is 469. Updating to the latest firmware is recommended for new installations, and troubleshooting issues.
In off-grid systems, the control functions of the BSL Battery Management System (BMS) are built into the latest version of the GX device using DVCC.
Solar Charger compatibility
All 48V BlueSolar and SmartSolar VE.Direct MPPT Chargers are compatible (*).
When planning to use the VE.Can communications port to connect the Solar Charger(s), make sure to select a GX Device that has sufficient CAN-Bus ports. The Color Control GX has only one such port, its VE.Can port, and is therefor not suitable. All other GX Devices can be used, since they have two ports. One can then be used to connect the BSL battery, and the other to connect the Solar Charger.
(*) with exception of the models “BlueSolar MPPT 150/70 CAN-bus” and “BlueSolar MPPT 150/85 CAN-bus” which are end-of-life since 2019. Legacy systems, historically installed with this configuration using the allow to charge contacts may be possible, speak to your dealer for more information.
Battery compatibility
The following batteries are supported:
BSL type |
B-LFP48-100E |
B-LFP48-120E |
BSLBATT-5000U |
Configuration settings
Integration instructions for Victron and BSL is described in this manual - victron_bsl_manual_-_2021-04-14.pdf
Here is a series of screenshots showing the result:
Installation image courtesy of 'Get Off Grid' South Africa.
Further Information
Further community discussion about installing and using BSL and Victron can found at Victron Community, use the topic label 'BSL'.
