battery_compatibility:byd_b-box [2020-04-20 14:52] – [9. Step by Step Installation Guide] guy_stewart | battery_compatibility:byd_b-box [2022-09-01 04:25] – [12. High voltage warning or alarm shown on battery status] guystewart | ||
====== Victron & BYD ====== | ====== Victron & BYD ====== | ||
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 3.8 ^ | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ |
- | | Appearance | {{ : | + | | Appearance | {{ : |
- | | ESS | yes| yes| yes| yes| yes| | + | | ESS | yes| yes| yes| yes| yes| yes| |
- | | Grid Backup| | + | | Grid Backup| |
- | | Off-Grid| | + | | Off-Grid| |
- | | Module capacity| | + | | Module capacity| |
- | | Module limit | 32| 32| 12| 64| 64| | + | | Module limit | 32| 32| 12| 64| 64| 64| |
- | | Max capacity| | + | | Max capacity| |
- | === 1.1 Offgrid, Backup and Energy Storage Systems | + | === 1.1 Offgrid, Backup and Energy Storage Systems |
Line 18: | Line 18: | ||
* Off-grid | * Off-grid | ||
- | === 1.2 A GX device is required, eg Cerbo GX, Color Control GX (CCGX), Venus GX (VGX), etc === | + | __Special note for Off-Grid systems__ |
- | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: | + | For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, |
+ | === 1.2 A GX device is required, eg Cerbo GX, etc === | ||
When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | ||
- | === 1.3 All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
Line 55: | Line 59: | ||
| B-BOX Premium LVL 15.4 | | | B-BOX Premium LVL 15.4 | | ||
- | | B-BOX Premium LVS 3.8 | | + | | B-BOX Premium LVS 4.0 |
+ | | B-BOX LV Flex 5.0 | ||
BYD also releases firmware update for their BMU and BMS. | BYD also releases firmware update for their BMU and BMS. | ||
Line 65: | Line 70: | ||
BYD B-Box Premium batteries firmware should be no less than V1.4, and the BMS firmware should be no less than V1.3. If necessary, this can be updated automatically via the ethernet port on the BMU when connected to the internet. | BYD B-Box Premium batteries firmware should be no less than V1.4, and the BMS firmware should be no less than V1.3. If necessary, this can be updated automatically via the ethernet port on the BMU when connected to the internet. | ||
Line 82: | Line 88: | ||
|Phases| | |Phases| | ||
- | | Multiplus 48/ | + | | Multiplus |
Line 96: | Line 103: | ||
Line 109: | Line 117: | ||
Line 127: | Line 136: | ||
- | === Battery Modules Required - Premium LVS 3.8 === | + | === Battery Modules Required - Premium LVS 4.0 === |
- | | | + | | Multiplus |
* Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | * Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | ||
+ | === Battery Modules Required - Premium LV Flex 5.0 === | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/500 & 48/ | ||
+ | | Multiplus 48/1200 & 48/ | ||
+ | | Multiplus 48/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
+ | | Quattro 48/ | ||
The specification for these minimum battery sizes was obtained from [[http:// | The specification for these minimum battery sizes was obtained from [[http:// | ||
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
Line 188: | Line 216: | ||
+ | | Float voltage | ||
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === | ||
Line 231: | Line 263: | ||
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the GX device. Menu path: //Settings -> Services -> CAN-profile// |
Line 242: | Line 274: | ||
Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | ||
- | === Color Control GX Configuration === | ||
- | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
=== GX Device with multiple CAN-bus port configuration === | === GX Device with multiple CAN-bus port configuration === | ||
Line 254: | Line 282: | ||
+ | === Color Control GX Configuration - Not Recommended === | ||
+ | The CCGX only has one available VE.Can interface. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery BMS-Can CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
+ | For this reason it is recommended to use the Cerbo GX instead. | ||
===== 6. Solar Charging ===== | ===== 6. Solar Charging ===== | ||
Line 271: | Line 305: | ||
In a correctly configured system, the inverter will shut itself down before the batteries enter a self protective shut down state. | In a correctly configured system, the inverter will shut itself down before the batteries enter a self protective shut down state. | ||
- | If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. Therefore it is strongly recommended that there is also either a generator or DC MPPT charge controller to provide DC bus power to bring the inverter back online to allow normal recharging to resume. | + | Therefore it is essential that there is also either a generator or DC MPPT charge controller for overall system stability. |
- | Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down. | + | Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down. |
Line 284: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 351: | Line 394: | ||
[[https:// | [[https:// | ||
==== User contributed installation guide ==== | ==== User contributed installation guide ==== | ||
Line 439: | Line 488: | ||
+ | The 'high voltage' | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. | ||
+ | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual cell level data), or assist with other potential solutions. | ||
- | ===== 12. Further Information ===== | + | ===== 13. Further Information ===== |
