battery_compatibility:byd_b-box [2021-02-19 08:33] – [2. Minimum Battery Sizing] guystewart | battery_compatibility:byd_b-box [2022-05-23 15:40] – [8. Troubleshooting] guystewart | ||
====== Victron & BYD ====== | ====== Victron & BYD ====== | ||
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ |
- | | Appearance | {{ : | + | | Appearance | {{ : |
- | | ESS | yes| yes| yes| yes| yes| | + | | ESS | yes| yes| yes| yes| yes| yes| |
- | | Grid Backup| | + | | Grid Backup| |
- | | Off-Grid| | + | | Off-Grid| |
- | | Module capacity| | + | | Module capacity| |
- | | Module limit | 32| 32| 12| 64| 64| | + | | Module limit | 32| 32| 12| 64| 64| 64| |
- | | Max capacity| | + | | Max capacity| |
Line 22: | Line 22: | ||
For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, | For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, | ||
- | === 1.2 A GX device is required, eg Cerbo GX, Color Control GX (CCGX), Venus GX (VGX), etc === | + | === 1.2 A GX device is required, eg Cerbo GX, etc === |
- | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: | + | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: |
When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | ||
- | === 1.3 All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
Line 60: | Line 60: | ||
| B-BOX Premium LVL 15.4 | | | B-BOX Premium LVL 15.4 | | ||
| B-BOX Premium LVS 4.0 | | | B-BOX Premium LVS 4.0 | | ||
BYD also releases firmware update for their BMU and BMS. | BYD also releases firmware update for their BMU and BMS. | ||
Line 89: | Line 90: | ||
| Multiplus & Multiplus II & MP-II GX 48/ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
Line 103: | Line 105: | ||
Line 116: | Line 119: | ||
Line 134: | Line 138: | ||
Line 148: | Line 153: | ||
Line 156: | Line 162: | ||
* Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | * Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | ||
+ | === Battery Modules Required - Premium LV Flex 5.0 === | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/500 & 48/ | ||
+ | | Multiplus 48/1200 & 48/ | ||
+ | | Multiplus 48/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
+ | | Quattro 48/ | ||
The specification for these minimum battery sizes was obtained from [[http:// | The specification for these minimum battery sizes was obtained from [[http:// | ||
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
Line 193: | Line 216: | ||
+ | | Float voltage | ||
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === | ||
Line 236: | Line 263: | ||
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the GX device. Menu path: //Settings -> Services -> CAN-profile// |
Line 247: | Line 274: | ||
Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | ||
- | === Color Control GX Configuration === | ||
- | The CCGX only has one available VE.Can interface. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery BMS-Can CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
=== GX Device with multiple CAN-bus port configuration === | === GX Device with multiple CAN-bus port configuration === | ||
Line 259: | Line 282: | ||
+ | === Color Control GX Configuration - Not Recommended === | ||
+ | The CCGX only has one available VE.Can interface. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery BMS-Can CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
+ | For this reason it is recommended to use the Cerbo GX instead. | ||
===== 6. Solar Charging ===== | ===== 6. Solar Charging ===== | ||
Line 289: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 356: | Line 394: | ||
[[https:// | [[https:// | ||
==== User contributed installation guide ==== | ==== User contributed installation guide ==== |
