battery_compatibility:byd_b-box [2021-04-14 09:31] – [4. VEConfigure settings] boekel | battery_compatibility:byd_b-box [2022-09-01 04:25] – [12. High voltage warning or alarm shown on battery status] guystewart | ||
====== Victron & BYD ====== | ====== Victron & BYD ====== | ||
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ |
- | | Appearance | {{ : | + | | Appearance | {{ : |
- | | ESS | yes| yes| yes| yes| yes| | + | | ESS | yes| yes| yes| yes| yes| yes| |
- | | Grid Backup| | + | | Grid Backup| |
- | | Off-Grid| | + | | Off-Grid| |
- | | Module capacity| | + | | Module capacity| |
- | | Module limit | 32| 32| 12| 64| 64| | + | | Module limit | 32| 32| 12| 64| 64| 64| |
- | | Max capacity| | + | | Max capacity| |
Line 24: | Line 24: | ||
=== 1.2 A GX device is required, eg Cerbo GX, etc === | === 1.2 A GX device is required, eg Cerbo GX, etc === | ||
- | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: | + | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: |
When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | ||
- | === 1.3 All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
Line 60: | Line 60: | ||
| B-BOX Premium LVL 15.4 | | | B-BOX Premium LVL 15.4 | | ||
| B-BOX Premium LVS 4.0 | | | B-BOX Premium LVS 4.0 | | ||
BYD also releases firmware update for their BMU and BMS. | BYD also releases firmware update for their BMU and BMS. | ||
Line 89: | Line 90: | ||
| Multiplus & Multiplus II & MP-II GX 48/ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
Line 103: | Line 105: | ||
Line 116: | Line 119: | ||
Line 134: | Line 138: | ||
Line 148: | Line 153: | ||
Line 156: | Line 162: | ||
* Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | * Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | ||
+ | === Battery Modules Required - Premium LV Flex 5.0 === | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/500 & 48/ | ||
+ | | Multiplus 48/1200 & 48/ | ||
+ | | Multiplus 48/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
+ | | Quattro 48/ | ||
The specification for these minimum battery sizes was obtained from [[http:// | The specification for these minimum battery sizes was obtained from [[http:// | ||
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
Line 295: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 362: | Line 394: | ||
[[https:// | [[https:// | ||
==== User contributed installation guide ==== | ==== User contributed installation guide ==== | ||
Line 450: | Line 488: | ||
+ | The 'high voltage' | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. | ||
+ | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual cell level data), or assist with other potential solutions. | ||
- | ===== 12. Further Information ===== | + | ===== 13. Further Information ===== |
