battery_compatibility:byd_b-box [2021-11-09 16:27] – guystewart | battery_compatibility:byd_b-box [2022-09-01 04:25] – [12. High voltage warning or alarm shown on battery status] guystewart | ||
Line 2: | Line 2: | ||
^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ | ||
- | | Appearance | {{ : | + | | Appearance | {{ : |
| ESS | yes| yes| yes| yes| yes| yes| | | ESS | yes| yes| yes| yes| yes| yes| | ||
| Grid Backup| | | Grid Backup| | ||
Line 90: | Line 90: | ||
| Multiplus & Multiplus II & MP-II GX 48/ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
Line 104: | Line 105: | ||
Line 117: | Line 119: | ||
Line 135: | Line 138: | ||
Line 149: | Line 153: | ||
Line 157: | Line 162: | ||
* Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | * Note for 7 units two stacks are required. One stack is 4 battery modules, the other is 3. | ||
+ | === Battery Modules Required - Premium LV Flex 5.0 === | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/500 & 48/ | ||
+ | | Multiplus 48/1200 & 48/ | ||
+ | | Multiplus 48/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
+ | | Quattro 48/ | ||
The specification for these minimum battery sizes was obtained from [[http:// | The specification for these minimum battery sizes was obtained from [[http:// | ||
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
Line 296: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 363: | Line 394: | ||
[[https:// | [[https:// | ||
==== User contributed installation guide ==== | ==== User contributed installation guide ==== | ||
Line 451: | Line 488: | ||
+ | The 'high voltage' | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. | ||
+ | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual cell level data), or assist with other potential solutions. | ||
- | ===== 12. Further Information ===== | + | ===== 13. Further Information ===== |
