battery_compatibility:cegasa
battery_compatibility:cegasa [2022-05-20 15:10] – guystewart | battery_compatibility:cegasa [2025-04-01 01:40] (current) – [Victron & Cegasa] guy_stewart | ||
====== Victron & Cegasa ====== | ====== Victron & Cegasa ====== | ||
- | ^ Battery ^ | + | ^ Battery ^ |
- | | Appearance | {{ : | + | | Appearance | {{ : |
- | | ESS | yes| yes| | + | | ESS | yes| |
- | | Grid Backup| yes| yes| | + | | Grid Backup| |
- | | Off-Grid| yes| yes| | + | | Off-Grid| |
- | | Module capacity| 13.5 kWh | 13.5 kWh | | + | | Module capacity| |
- | | Module limit | | + | | Module limit | |
- | | Max capacity| | + | | Max capacity| |
Line 50: | Line 50: | ||
The following batteries are supported: | The following batteries are supported: | ||
^ Cegasa series type ^ | ^ Cegasa series type ^ | ||
- | | eBick Ultra 175 | + | | EBick LV | |
- | | eBick Pro 280 | | + | |
- | The Ultra 175 module | + | The EBick LV has an external BMS (MCS master box) which connects to the Victron GX device. |
- | The Pro 280 model has an external BMS cabinet | + | |
Victron is not compatible with the Cegasa high voltage configuration where battery voltage is increased beyond 48V nominal. The Cegasa eBick 280 Pro product documentation mentions up 2-3 MWh capacity, this is due to the ability of the eBick 280 Pro to be able to be installed in series as well as parallel, HOWEVER Victron systems do NOT support the series connection configuration, | Victron is not compatible with the Cegasa high voltage configuration where battery voltage is increased beyond 48V nominal. The Cegasa eBick 280 Pro product documentation mentions up 2-3 MWh capacity, this is due to the ability of the eBick 280 Pro to be able to be installed in series as well as parallel, HOWEVER Victron systems do NOT support the series connection configuration, | ||
Line 74: | Line 71: | ||
The table below shows the minimum number of battery modules required for the specified inverter/ | The table below shows the minimum number of battery modules required for the specified inverter/ | ||
- | === Battery Modules Required - Ultra 175 === | + | === Battery Modules Required - Ebick LV === |
|Phases| | |Phases| | ||
- | | Multiplus & Multiplus II & MP-II GX 48/ | + | | Multiplus & Multiplus II & MP-II GX 48/ |
| Inverter RS & Multi RS 48/ | | Inverter RS & Multi RS 48/ | ||
- | | Quattro 48/ | + | | Quattro 48/ |
- | | EasySolar & EasySolar-II 48/ | + | | EasySolar & EasySolar-II 48/ |
- | === Battery Modules Required - Pro 280 === | + | |
- | |Phases| | + | |
- | | Inverter/ | + | |
- | | Inverter RS & Multi RS 48/ | + | |
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
- | Step 1: Configure inverter type in the Cegasa BMS - See Cegasa documentation for details. | + | Step 1: Configure inverter type in the Cegasa BMS via Cegasa EViewer WebApp |
Step 2: Connect normal CAT5e or CAT6 network cable (*) between the Cegasa BMS and the BMS-Can port of the GX device | Step 2: Connect normal CAT5e or CAT6 network cable (*) between the Cegasa BMS and the BMS-Can port of the GX device | ||
Step 3: Connect VE.Can terminator (supplied with GX device) to the other BMS-Can port of the GX device | Step 3: Connect VE.Can terminator (supplied with GX device) to the other BMS-Can port of the GX device | ||
Line 145: | Line 127: | ||
^VEConfigure Inverter Parameter | ^VEConfigure Inverter Parameter | ||
|DC input low shut-down | 44V| | |DC input low shut-down | 44V| | ||
- | |DC input low restart | + | |DC input low restart |
|DC input low pre-alarm* | 45V| | |DC input low pre-alarm* | 45V| | ||
Line 162: | Line 144: | ||
^ ESS Parameter ^ Settings ^ | ^ ESS Parameter ^ Settings ^ | ||
- | |Battery Capacity | + | |Battery Capacity |
- | |Sustain voltage. | + | |Sustain voltage. |
|Dynamic cut-off values | Voltage | | |Dynamic cut-off values | Voltage | | ||
- | |0.05 | 47V | | + | |0.05 | 46V | |
|0.2 | 44V | | |0.2 | 44V | | ||
|0.7 | 43.5V | | |0.7 | 43.5V | | ||
Line 198: | Line 180: | ||
2. After properly wiring and setting up, the battery will be visible as a battery in the device list: | 2. After properly wiring and setting up, the battery will be visible as a battery in the device list: | ||
=== Confirm Connection === | === Confirm Connection === | ||
- | Confirm the parameters option within the battery page shows the actual battery charge and discharge limits. In normal working conditions, the charge | + | Confirm the parameters option within the battery page shows the actual battery charge and discharge limits. In normal working conditions, the discharge |
- | Note these for the Ultra 175 model, these charge current limits are non-linear. 1 module | + | {{ : |
+ | Reporting of additional cell level details (e.g. Lowest and Highest cell voltages etc) to the GX device | ||
=== GX Device with multiple CAN-bus port configuration === | === GX Device with multiple CAN-bus port configuration === | ||
Line 248: | Line 233: | ||
=== Step 1. If the Inverter/ | === Step 1. If the Inverter/ | ||
- | As a safety precaution, the inverter/ | + | Low voltage and deeply discharged behaviour |
+ | When the grid is connected there are two software controls to sustain voltage. The Minimum SOC (while grid is connected) set in the GX device, and the sustain voltage (set in the ESS assistant). | ||
+ | The GX device | ||
+ | If instead | ||
- | You can then start the inverter/ | + | If you then reconnect a DC charge source, or AC input supply (grid or generator), after approximately 2 minutes |
=== Step 2. Check that the battery is visible on the GX device list === | === Step 2. Check that the battery is visible on the GX device list === | ||
If its not visible, check: | If its not visible, check: |
battery_compatibility/cegasa.1653052201.txt.gz · Last modified: 2022-05-20 15:10 by guystewart
