battery_compatibility:discover [2020-08-17 09:22] – [4.2 VE.Configure Settings] mvader | battery_compatibility:discover [2024-12-02 19:14] (current) – dettingale | ||
- | ====== Victron Energy and Discover AES Batteries ====== | + | ====== Victron Energy and Discover AES Rackmount |
- | The Discover AES range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | + | {{: |
- | These instructions are intended to be used in conjunction with the product manual(s) supplied by Discover Battery. | ||
- | These instructions are current as of 2019-07-23. More recent updates | + | The Discover Lithium Iron Phosphate batteries are compatible with Victron products in various systems. |
+ | These instructions are intended | ||
+ | For the latest product details, installation, | ||
- | For the latest product details, installation and operation manuals, visit the Discover Battery website [[https:// | ||
+ | The Discover LiFePO< | ||
+ | These instructions provide information about integrating Discover Lithium batteries with Victron Energy devices in a closed-loop configuration using the LYNK II Communication Gateway set to communicate with Victron devices. The AES RACKMOUNT batteries can be used in an Energy Storage System (ESS) for self-consumption, | ||
- | The Discover AES LiFePO4 Battery includes a Battery Management System (BMS) within each battery pack. The BMS interfaces with the Victron GX device | + | Configuration, |
+ | * Installing electrical equipment | ||
+ | * Applying applicable installation codes | ||
+ | * Analyzing and reducing hazards involved in performing electrical work | ||
+ | * Installing and configuring batteries | ||
+ | * Installing and configuring systems activated by relays | ||
- | These instructions provide information about the integration of Discover | + | **//No responsibility is assumed by Discover |
+ | Read the AES RACKMOUNT Installation and Operation Manual and safety instructions before installing the battery. | ||
+ | Read Victron manuals | ||
- | **NOTE:** In a Victron networked system the charging variables will be managed automatically by the AES battery BMS and the Venus GX / Color Control GX device. Discharging variables are managed by the set up of the Victron inverter. | + | **WARNING: ELECTRIC SHOCK AND FIRE HAZARD** |
- | ===== 2. Documentation ===== | + | * This equipment must only be installed as specified. |
+ | * Do not disassemble or modify the battery. | ||
+ | * If the battery case has been damaged, do not touch exposed contents. | ||
+ | * There are no user-serviceable parts inside. | ||
+ | **Failure to follow these instructions can result in death or serious injury.** | ||
- | Victron Energy Reference Documents: | ||
- | * Quattro Inverter Charge Manual | ||
- | * MultiPlus Inverter Charge Manual | ||
- | * SmartSolar / BlueSolar Charge Controller Manual | ||
- | * Venus GX (VGX) / Color Control GX (CCGX) Manual | ||
- | Discover Reference Documents: | + | **CAUTION: ELECTRIC SHOCK HAZARD** |
- | * Discover Energy 805-0015 AES LiFePO4 Battery 44-24-2800 42-48-6650 Manual | + | |
- | Certain configuration, | + | |
- | | + | * Before servicing the battery, follow all procedures to fully de-energize the battery system. |
- | * Applying applicable installation codes | + | |
- | * Analyzing and reducing hazards involved | + | |
- | * Installing and configuring batteries | + | |
- | **//No responsibility is assumed by Discover for any consequences arising out of the use of this material. | + | **Failure |
- | Read AES Battery Manual and Safety instructions before installing the battery. | + | |
- | Read Victron manuals for guidance on product features, functions, parameters and how to use the product safely.//** | + | |
- | **WARNING: HAZARD OF ELECTRICAL SHOCK AND FIRE** | ||
- | * Connect LYNK to only Safety Extra Low Voltage (SELV) circuits and power sources. | ||
- | * All wiring must be completed by qualified personnel to ensure compliance with applicable installation codes and regulations. | ||
- | **Failure to follow these instructions can result in death or serious injury.** | ||
**CAUTION: HAZARD OF EQUIPMENT DAMAGE** | **CAUTION: HAZARD OF EQUIPMENT DAMAGE** | ||
- | * Do not connect any port of the LYNK to a network with power over Ethernet (POE) or to a public telecommunication network. | + | |
- | * Do not run CAT5 cables or other cables connected to LYNK through conduit that could be exposed to lightning strikes. | + | * Do not connect any port of the LYNK II to a network with power over Ethernet (POE) or to a public telecommunication network. |
+ | * Do not run CAT5 cables or other cables connected to LYNK through | ||
**Failure to follow these instructions can damage equipment** | **Failure to follow these instructions can damage equipment** | ||
- | ===== 3. Overview ===== | ||
+ | ===== 2. Documentation ===== | ||
+ | The LYNK II Communication Gateway is compatible with the following: | ||
+ | **Discover Power Batteries** | ||
+ | * AES RACKMOUNT 48-48-5120 / 48-48-5120-H | ||
+ | **Victron Products** | ||
+ | Control Panels | ||
+ | * Cerbo GX | ||
+ | * Color Control GX | ||
+ | * Ekrano GX | ||
+ | * Venus GX | ||
+ | Inverter-Chargers | ||
+ | * Quattro/ | ||
+ | * Multiplus/ | ||
+ | * SmartSolar MPPT | ||
+ | **Victron Energy Reference Documents: | ||
+ | * Quattro Inverter Charger Manual | ||
+ | * MultiPlus Inverter Charger Manual | ||
+ | * SmartSolar / BlueSolar Charger Controller Manual | ||
+ | * GX device (Cerbo GX) Manual | ||
+ | **Discover Power Reference Documents: | ||
+ | * 808-0039 48-48-5120 AES RACKMOUNT Data Sheet | ||
+ | * 808-0040 48-48-5120-H AES RACKMOUNT (Heated) Data Sheet | ||
+ | * 805-0043 AES RACKMOUNT Installation and Operation Manual | ||
+ | * 805-0033 LYNK II Installation and Operation Manual | ||
+ | * 805-0040 LYNK II Victron (Solar) Manual | ||
+ | * 805-0051 LYNK II Victron (Mobile) Manual | ||
+ | * 805-0059 LYNK LITE Victron (Mobile) Manual | ||
+ | ===== 3. Overview ===== | ||
==== 3.1 System Overview ==== | ==== 3.1 System Overview ==== | ||
- | The AES LYNK Communication Gateway unlocks the full potential of a Discover AES LiFePO4 Battery by enabling the internal Battery Management System (BMS) to optimize the charge and discharge configurations of the world’s best inverter chargers and solar charge controller systems in a closed loop configuration. | + | {{: |
- | **AES LiFePO4 | + | The LYNK II Communication Gateway unlocks the full potential of a Discover Lithium battery by enabling the internal Battery Management System (BMS) to provide real-time data in a closed-loop configuration to other devices. This configuration allows hybrid inverter-chargers and solar charge controller systems to optimize control over the charging process in solar applications. LYNK II also enables the remote monitoring of Discover Lithium battery SOC and data logging of multiple sites using the data monitoring services offered by off-grid inverter systems. |
+ | Discover Lithium | ||
- | AES LiFePO4 battery | + | In an open-loop configuration, |
- | In a Closed Loop configuration the battery | + | In a closed-loop |
- | To connect with the communication | + | If communication |
==== 3.2 Minimum Battery Capacity ==== | ==== 3.2 Minimum Battery Capacity ==== | ||
+ | Battery charge and discharge rates are managed automatically by the Discover Lithium battery and Victron Energy device. Using large solar arrays with battery banks that are too small can exceed the operating limits of the battery to charge and possibly lead to the BMS triggering over-current protection. Either curtail the charging below the operational limit of installed batteries, or the battery capacity must accept the maximum charge current of the system. This value is derived by adding the charge capacities of all inverter-chargers and solar charge controllers in the system. Additionally, | ||
- | Battery charge and discharge rates are managed automatically by the AES LiFePO4 Battery and Victron CCGX device. Using very large solar arrays with battery banks that are too small can exceed the operating limits of the battery to charge and possibly lead to the BMS triggering over-current protection. Battery capacity must be sized to accept the maximum charge current of the system, or the the charging devices must be curtailed to charge below the operating limit of the installed batteries. This value is derived by adding together the charge capacities of all inverter/ | + | ^ 120 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ 48-48-5120-H ^ |
+ | ^ Quattro 48/3000/35 < | ||
+ | ^ Quattro 48/5000/70 < | ||
+ | ^ Quattro 48/ | ||
+ | ^ MultiPlus-II 48/3000/35 < | ||
+ | ^ MultiPlus-II 48/5000/70 < | ||
- | ^ Model^ Inverter Peak* ^ Charger ^ 1-Phase Min 42-48-6650 ^ 3-Phase Min 42-48-6650 ^ | + | <sup>2</sup> Calculated based on max 10000W at 120 VAC peak output, 4000W at 120VAC continuous output, efficiency 95.0 %, and 70A DC max charging, as published in Victron Data Sheet as of 24-05-01. |
- | ^ MultiPlus 48/3000/35 | 136 Adc | 35 Adc |1 |2| | + | |
- | ^ MultiPlus | + | |
- | ^ Quattro 48/8000/110 |362 Adc| 110 Adc |2 |4| | + | |
- | ^ Quattro 48/ | + | |
- | *92% Efficiency at 48V | + | |
- | ^ Model^ Inverter Peak* ^ Charger ^ 1-Phase Min 44-44-2800 ^ | + | < |
- | ^ MultiPlus / Quattro 24/ | + | |
- | *92% Efficiency at 24V | + | |
- | ===== 4 Configuring | + | <sup>4</ |
- | ==== 4.1 Powering Up Equipment ==== | + | < |
- | * Make sure none of the Discover AES communication cables are installed. | ||
- | * Connect MultiPlus/ | ||
- | * Connect all Victron communication cables at this time. | ||
- | * Turn ON the Discover AES Battery press and hold switch on the battery/ | ||
- | * Turn on Multi/ | ||
- | If this is the initial set up of the MultiPlus or Quattro apply power to Victron Equipment and update firmware to the devices listed to: | ||
- | | + | ^ 230 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ 48-48-5120-H ^ |
- | | + | ^ Quattro 48/5000/70 < |
- | * VE.Direct | + | ^ Quattro 48/8000/110 < |
+ | ^ Quattro-II 48/5000/70 < | ||
+ | ^ MultiPlus 48/2000/25 < | ||
+ | ^ MultiPlus 48/3000/35 < | ||
+ | ^ MultiPlus 48/5000/70 < | ||
+ | ^ MultiPlus-II (GX) 48/3000/35 < | ||
+ | ^ MultiPlus-II (GX) 48/5000/70 < | ||
+ | ^ MultiPlus-II 48/8000/110 < | ||
+ | ^ MultiPlus-II 48/ | ||
+ | ^ Multi RS Solar 48/6000 Dual Tracker < | ||
+ | ^ EasySolar-II 48/ | ||
+ | ^ EasySolar-II 48/5000/70 MPPT 250/100 GX < | ||
- | This will also presume the VE Bus has already set up if required, such as: | + | < |
- | * Dual Phase/Split Phase 180 degrees out | + | |
- | * 3 Phase | + | |
- | ==== 4.2 VE.Configure Settings ==== | + | < |
- | This section presumes familiarity with VEConfigure software. These settings are for an off-grid application. These parameters once set will become the default values used if communication with the AES battery is interrupted for some reason. During normal operation the charge characteristics are governed automatically by the CCGX via DVCC, with instructions from the connected AES battery. However it is necessary to set the discharging parameters for DC input low shut-down found under the Inverter Tab. After setting the parameters, ‘send’ all parameters to the inverter and CCGX. Restart the CCGX after completion. | + | < |
- | Also keep in mind the settings below are for 1 unit only. If the system is a multiple inverter/charger configuration, determine the max charge current for all units installed does not exceed the Discover battery charge current limit . | + | < |
- | ^ General Tab ^44-24-2800 ^42-48-6650^ | + | < |
- | ^ Overruled by remote (1) |Enable| Enable| | + | |
- | ^ Enable battery monitor |Enable |Enable| | + | |
- | ^ SoC when Bulk finished (2) |95% |95%| | + | |
- | ^ Total battery capacity (per battery installed) |installed x 110 Ah |installed x 130 Ah| | + | |
- | Charge efficiency (2)| 95% |95%| | + | |
- | ^ Inverter Tab ^ 44-24-2800 ^ 42-48-6650^ | + | < |
- | ^ DC input low shut-down (3) |24.0 V |48.0 V| | + | |
- | ^ DC Input low restart (4) |26.0 V |52.0 V| | + | |
- | ^ DC input low pre-alarm (5) |25.5 V |51.0 V| | + | |
- | ^ Enable AES (6) |Disable| Disable| | + | |
- | ^ Charger Tab ^ 44-24-2800 ^ 42-48-6650^ | + | <sup>8</sup> Calculated based on max 6000W at 230 VAC peak output, 2400W at 230VAC continuous output, efficiency 95.0 %, and 25A DC max charging, |
- | ^ Enable charger |Enable |Enable| | + | |
- | ^ Battery Type (2) |Blank| Blank| | + | |
- | ^ Lithium batteries (2) |Enable |Enable| | + | |
- | ^ Charge curve (2) |Select: Fixed| Select: Fixed| | + | |
- | ^ Absorption voltage |(2) 27.2 V |54.4 V| | + | |
- | ^ Float voltage (2)| 26.8 V| 53.6 V| | + | |
- | ^ Charge current per battery installed (Recommended | + | |
- | ^ Repeated absorption time (2) (7) |1.0 < 3.0 Hr| 1.0 < 3.0 Hr| | + | |
- | ^ Repeated absorption interval (2) |7.0 Days |7.0 Days| | + | |
- | ^ Absorption time (2) (7) |1.0 < 3.0 Hr |1.0 < 3.0 Hr| | + | |
- | (1) Enabled is recommended. | + | |
- | (2) Precautionary setting as they are ignored during normal operation and communication with AES Battery. | + | |
- | (3) The lowest operating voltage allowed, increase voltage as required. | + | |
- | (4) Restart voltage after DC input low shut-down, recommended to be set to the minimum value (minimum varies according to the DC Input low shut-down value). | + | |
- | (5) 51.0 V value (approximately 15% SoC) will trigger low battery warning, increase or decrease | + | |
- | (6) ‘Enable AES’ has no relation to the AES Battery, refer to Victron | + | |
- | (7) The recommended minimum is 1.0 hour. A longer period | + | |
- | **NOTE:** Confirm the Float Voltage after completing the installation of any Victron ‘Assistants’, and if necessary reset the Float Voltage back to 26.8 V / 53.6 V. | + | < |
- | ==== 4.3 VE.Direct MPPT Settings ==== | + | < |
- | During normal operation the MPPT charge characteristics are governed by the CCGX via DVCC, with instructions from the connected AES battery. | + | < |
- | The settings below are precautionary. This section presumes familiarity with VictronConnect (Bluetooth App) used to configure, monitor | + | |
- | **NOTE:** VE.Can MPPTs cannot be used and are not yet supported | + | |
- | The max charge current is dictated by the size of MPPTs installed. If multiple MPPTs are installed verify all combined controllers would not exceed the battery limit. | + | < |
- | ^MPPT Charge Controller Settings ^44-24-2800 ^42-48-6650^ | + | <sup>13</sup> Calculated based on max 18000W at 230 VAC peak output, 8000W at 230VAC continuous output, efficiency 96.0 %, and 35A DC max charging, as published in Victron Data Sheet as of 24-05-01. |
- | ^Battery voltage|24 V|48 V| | + | |
- | ^Max current per battery installed (Recommended | + | |
- | ^Charger enabled|Enabled|Enabled| | + | |
- | ^Battery preset |User Defined|User Defined| | + | |
- | ^Absorption voltage |27.2 V|54.8 V| | + | |
- | ^Maximum absorption time (10)|v 1.0 < 3.0 Hr|1.0 < 3.0 Hr| | + | |
- | ^Float voltage|26.8 V|54.0 V| | + | |
- | ^Equalization voltage|26.8 V|54.0 V| | + | |
- | ^Auto equalization|Disabled|Disabled| | + | |
- | ^Temperature compensation |Disabled |Disabled| | + | |
- | ^Low temperature cut off |5 C|5 C| | + | |
- | (9) May be set to lower value if necessitated by charger controller size. | + | |
- | (10) Duration | + | |
- | period of time may be required to compensate for multiple batteries to achieve a smooth completion of charge. | + | |
- | Turn OFF all Victron equipment. Turn OFF the Discover AES Battery press and hold switch on the battery/ | + | < |
- | ===== 5. Installing LYNK and Connecting LYNK to the Victron | + | < |
- | ==== 5.1 Installing the LYNK Edge Card ==== | + | < |
- | The LYNK Edge Card for Victron is a Slot 0 Type which only inserts into the left side slot on the bottom of the LYNK Communication Gateway. | ||
- | **NOTE:** The LYNK Edge Card type to be used is determine by the brand of power conversion equipment. | + | ^ 277 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ 48-48-5120-H ^ |
- | * If LYNK Edge Card is in the wrong slot, it will not function. | + | ^ Quattro 48/ |
- | * If LYNK Edge Card is not firmly seated, it will not function. | + | |
- | Choose a clean, dry, easily accessible indoor location. All the communication ports on the LYNK are accessible from the bottom of the device when mounted on a wall or DIN rail. Clearance of at least 50 mm (2 inches) below the device is needed to allow for the bend radius | + | < |
- | With LYNK disconnected from all devices remove cover and insert the LYNK Edge Card in the correct slot. This card has a RJ45 terminal built into the card. Ensure it is firmly seated into the internal connecting slot. Replace with provided slotted Edge Card cover after mounting LYNK Edge Card. | ||
- | Install and network the AES LiFePO4 batteries as described in the 805-0015 AES LiFePO4 Battery Manual. Connect the AES LYNK Communication Gateway to the AES LIFePO4 Battery and power up as described in the 805-0017 LYNK Communication Gateway Users Manual. | ||
- | **CAUTION: HAZARD OF EQUIPMENT DAMAGE** | + | ===== 4 Configuring Discover Products ===== |
- | * Do not plug the AEBus RJ-45 cable terminator into the 10/100 Ethernet port of the LYNK. | + | |
- | * Do not connect a CAT5 cable from the 10/100 Ethernet port of the LYNK to the WAN or MODEM port of a network router. | + | |
- | * Turn OFF all devices before connecting cables or inserting an Edge Card. | + | |
- | **Failure to follow these instructions can damage equipment.** | + | |
- | **NOTE:** Power electronics are not AEBus devices and should not be connected | + | ==== 4.1 Configuring the LYNK II ==== |
- | to AEBus. | + | |
- | ==== 5.2 Connecting LYNK to the Victron Network ==== | ||
- | Before connecting | + | **LYNK II: Setting Up Jumpers** |
- | Insert one end of a CAT5 communication cable into the LYNK Edge Card port and the other end into one of the two VE.Can ports on the back of the Color Control GX (CCGX). Use the terminator provided | + | Jumpers configure termination for the LYNK Network |
+ | Detailed pin configurations are included in the LYNK II manual and are repeated here for convenience. | ||
- | **NOTE:** Discover DC Power Converter and Lynk Gateway are internally terminated | ||
- | ===== 6. System Set Up ===== | + | **NOTE:** |
+ | * Disconnect power and all LYNK II Communication Gateway connections before configuring header boards and jumpers. | ||
+ | * The LYNK II Communication Gateway terminates the LYNK Network by default. Unless instructed, do not remove the termination jumper inside the LYNK II Communication Gateway. | ||
- | ==== 6.1 Synchronizing | + | Adjust |
- | * Turn the Discover AES battery to ON press and hold switch on the battery/ | ||
- | * Turn on all Victron equipment. | ||
- | Through the VRM or a physical CCGX access the System Setup menu in the Remote Console. Scroll down to select each item and then set as indicated. | + | {{: |
- | * **Select “CAN-bus (1)”** | ||
- | ;#; | + | ^ CAN Out RJ45 Pin ^ Header Jumper ^ RJ45 Pin ^ |
- | *** Select “CAN-bus Profile” to edit** | + | ^ CAN L | H1 - 6-8 | 8 | |
- | ;#; | + | ^ CAN H | H1 - 7-9 | 7 | |
- | {{ : | + | ^ CAN GND | H3 - 1-3 | 3 | |
- | *** Within the “CAN-bus Profile” choose “VE CAN & CAN-bus”** | + | |
- | ** * “VE CAN-bus & CAN-bus BMS (250 kbit/s)” should appear on the “CAN-bus(1) menu** | ||
+ | **LYNK ACCESS Software** | ||
- | Return to the Device List and the CCGX should display Discover AES as one of the devices along with the battery SoC, Voltage and Amps. If you have multiple batteries a single entry will show up, which represents all batteries. | ||
- | **NOTE:** If Discover does not appear on the Device List, confirm that the CAT5 communication cable is a normal patch type and not a cross over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor | + | {{:battery_compatibility: |
- | connection. | + | |
- | The parameters option within the battery page shows the actual battery charge limits. If you have multiple batteries a single entry will show up, which represents all batteries. | ||
- | **NOTE:** Battery Low Voltage value displayed | + | LYNK ACCESS software for 64-bit Windows 10 / 11 is required to configure |
+ | - Download the current version of LYNK ACCESS software from the Discover Energy Systems website to get the most up-to-date suite of available protocol configurations. | ||
+ | - Using a USB cable with a Type-B mini-plug, connect | ||
+ | - Open LYNK ACCESS and confirm that only one LYNK device is connected to the computer. | ||
+ | - Select the LYNK tab for optional configuration and settings. Select the blue gear icon in the upper right area of the CAN Settings tile. | ||
+ | - Select the pre-configured Victron protocol and the baud rate (250 or 500 kbps) to complete the closed-loop configuration for LYNK II, then click SAVE. | ||
- | Once the VE.Can and CAN-bus bit rate is set, communication of the AES battery parameters will be automatic. | ||
- | During normal operation, the charge parameter limits are set by the BMS of the AES battery and communicated through the system by the CCGX to the inverter/ | + | **NOTE:** In most cases, the communication speed for the Victron protocol should be 250 kbps to match the networked Victron devices. However, if communication cannot be established at that speed, the Victron device may require a communication speed of 500 kbps. |
- | Navigate from the Device List screen > Settings > System Setup> | ||
- | From the System Setup menu scroll down to select each item and verify the system automatically updated in the DVCC. Note this was accomplished by the v2.40 Venus OS firmware upgrade to include. | ||
- | * DVCC - Distributed Voltage and Current Control is forced “ON” | + | ==== 4.2 Connecting LYNK II to the VE.CAN Network ==== |
- | Within the DVCC menu verify: | + | **Setting up the Battery** |
- | * Max charge current: Installed number of AES batteries x (42-48-6650: | + | |
- | * SVS - Shared voltage sense: Forced “OFF” | + | |
- | * STS - Shared temperature sense: Forced “OFF” | + | |
- | * SCS - Shared Current Sense: ' | + | |
- | * SCS Status - Should show " | + | |
- | (8) Limit charge current works across | + | |
- | **NOTE:** To avoid conflicting network information and data, do not use a Victron BMV battery monitor when using AES LYNK Communication Gateway. | + | |
- | | + | For instructions on network layouts and connections, |
- | * Reboot the GX device after completion | + | |
- | ** | + | * No more than one network |
- | {{ : | + | * Proper system function requires network termination – some batteries and devices may auto-terminate. |
+ | * LYNK II requires power from one of three possible sources (13-90 VDC power supply, a USB device, or AEbus Port or LYNK Port enabled Discover Lithium battery). | ||
+ | * Discover Lithium batteries must be set to ON to supply power and communicate with LYNK II. | ||
+ | LYNK II and AES RACKMOUNT battery modules are both internally terminated. No external termination is required when installing LYNK II with AES RACKMOUNT battery modules. | ||
+ | Before connecting LYNK II to the VE.Can network, ensure that the Victron GX device uses firmware version 2.89 or later. Also, ensure the CAN out pins on the LYNK II are configured correctly. | ||
+ | Insert one end of a CAT5e or higher communication cable into the LYNK II CAN out port and the other end into one of the two VE.Can ports (A-B) on the back of the Victron device. As the LYNK II is internally terminated, the external terminator provided with the GX is not required. | ||
+ | - VE.Bus: RJ45 socket for connecting to the Victron inverter. | ||
+ | - VE.Can: RJ45 socket for connection to LYNK II CAN Out. | ||
+ | * Insert a terminator in the other VE.Can port to terminate the CAN network. | ||
+ | ===== 5 Configuring Victron Products ===== | ||
+ | When the LYNK II is in a closed-loop network using the CANopen protocol, LYNK II will transmit real-time parameters from the Discover Lithium battery, including voltage, current, temperature, | ||
+ | If there is a break in communication between the Victron Energy device and the LYNK II, the Victron device stops charging. Charging only resumes after communication between the Victron device and the LYNK II communication gateway is restored. If communication cannot be restored, you may have to set the system to open loop until an installation professional is available. | ||
+ | As a precautionary measure, it is recommended that the inverter-charger be programmed with the correct voltage-based parameters before setting up the system to operate in a closed-loop configuration. If closed-loop communication fails, after the open loop parameters have been configured, turn the Victron device OFF and ON with the On/ | ||
+ | ==== 5.1 Setting Up Open-Loop Configuration ==== | ||
+ | Whenever possible, using a closed-loop configuration with Discover batteries and Victron devices is recommended. However, an open-loop configuration may be required if the closed-loop communication system encounters an issue, such as a failure of the LYNK II gateway, cables or connections, | ||
+ | In such cases, you may have to set the system to open loop until the issue is resolved. The following describes how to set up open-loop on Victron devices. | ||
+ | You will need the latest firmware on all connected devices. The following presumes familiarity with VE Configure software. After setting the voltage-based open-loop parameters using the VE Configure 3 software, ‘send’ all parameters to the inverter-charger and GX device and then restart the GX device. | ||
+ | **Procedure** | ||
+ | - Set the Discover Lithium batteries to ON and the inverter to ON. | ||
+ | - Connect your computer to the Victron GX device or inverter. | ||
+ | - On the computer, start the VE Configure 3 software configuration tool. | ||
+ | - Enable and disable parameter values according to the tables below. | ||
+ | - Send the parameters in the following tables to the Victron inverter-charger and GX device. | ||
+ | - Toggle the On/ | ||
+ | VE Configure 3 > General Tab | ||
+ | ^ General Tab ^ 48-48-5120 / 48-48-5120-H ^ | ||
+ | ^ [AC1] Overruled by remote < | ||
+ | ^ [AC2] Overruled by remote < | ||
+ | ^ Dynamic current limiter | Enable | | ||
+ | ^ External current sensor connected | Disable | | ||
+ | ^ Enable battery monitor | Enable | | ||
+ | ^ State of charge when Bulk finished < | ||
+ | ^ Battery capacity | Number of batteries x 100 Ah| | ||
+ | ^ Charge efficiency < | ||
+ | VE Configure 3 > Inverter Tab | ||
+ | ^ Inverter Tab ^ 48-48-5120 / 48-48-5120-H ^ | ||
+ | ^ DC input low shutdown < | ||
+ | ^ DC input low restart < | ||
+ | ^ DC input low pre-alarm < | ||
+ | ^ Enable AES < | ||
+ | VE Configure 3 > Charger Tab | ||
+ | ^ Charger Tab ^ 48-48-5120 / 48-48-5120-H ^ | ||
+ | ^ Enable Charger | Enable | | ||
+ | ^ Battery Type < | ||
+ | ^ Lithium batteries < | ||
+ | ^ Charge curve < | ||
+ | ^ Absorption Voltage < | ||
+ | ^ Float Voltage < | ||
+ | ^ Charge Current | Installed x 95 Ah| | ||
+ | ^ Repeated absorption time < | ||
+ | ^ Repeated absorption interval < | ||
+ | ^ Absorption time < | ||
+ | ==== 5.1 Setting Up Closed-Loop Configuration ==== | ||
+ | Refer to the latest Discover Energy Systems documentation for battery values and the latest Victron documentation for menu navigation and details on the setup procedure. | ||
+ | - Set the Discover Lithium batteries to ON and the Victron GX device to ON. | ||
+ | - Using a touch screen or other user interface of the GX device, set the VE.Can port and CAN-Bus BMS communication rate to 250 kbit/s to match the communication speed set up on the LYNK II communication gateway. | ||
+ | **Device List > Settings > Services > VE.Can port > CAN-bus profile** | ||
+ | * Select **VE.Can & CAN-bus BMS (250 kbit/s)** | ||
+ | * Return to the Device List, and the Discover Lithium Battery should now appear as one of the devices. | ||
+ | **Device List** | ||
+ | **NOTE:** If **Discover AES** does not appear on the Device List, confirm that the CAT5e or higher communication cable is a normal patch type, not a cross-over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor connection. | ||
+ | === 5.1.1 Configurable Closed-Loop Settings === | ||
+ | During regular operation, the BMS sets the battery’s charge parameter limits, which the Victron GX device communicates to the inverter-charger and MPPT. | ||
+ | To optimize the performance of a Victron system, manually set the following DVCC menu items using the Victron GX device and reboot the system. | ||
+ | **Device List > Settings > DVCC** | ||
+ | ^ DVCC Menu ^ Setting ^ | ||
+ | ^ DVCC (Distributed Voltage and Current Control | Forced on | | ||
+ | ^ Limit charge current | ON < | ||
+ | ^ Maximum charge current < | ||
+ | ^ Limit managed battery charge voltage | Disabled | | ||
+ | ^ SVS - Shared voltage sense | Forced off < | ||
+ | ^ STS - Shared temperature sense | Forced off | | ||
+ | ^ SCS - Shared current sense | ON | | ||
+ | ^ SCS status | (Displays the current status) | | ||
+ | ^ Controlling BMS | Automatic Selection | | ||
+ | === 5.1.2 Saving the Configurable Closed-Loop Settings === | ||
+ | **Device List > Settings > General > Reboot?** | ||
+ | After the DVCC menu items have been set, reboot the system to complete the closed-loop configuration. | ||
+ | **NOTE:** To avoid conflicting network information and data, do not use a Victron BMV battery monitor when using the LYNK II Communication Gateway. | ||
+ | ===== 6.0 Powering Up Equipment ===== | ||
+ | * Make sure none of the Discover communication cables are attached. | ||
+ | * Safely connect MultiPlus/ | ||
+ | * Connect all Victron communication cables at this time. | ||
+ | * Turn ON the AES RACKMOUNT battery. | ||
+ | * Turn on Multi/ | ||
+ | If this is the initial set up of the MultiPlus or Quattro apply power to Victron Equipment and update firmware to the devices listed to: | ||
+ | * MultiPlus / Quattro - version 459 or later. | ||
+ | * GX device (Cerbo GX, Venus GX, etc) to include version 2.40 or later. | ||
+ | * VE.Direct MPPT - version 1.42 or later. |
battery_compatibility/discover.1597648937.txt.gz · Last modified: 2020-08-17 09:22 by mvader
