battery_compatibility:discover [2024-11-01 19:20] – Update batteries and LYNK II hardware dettingale | battery_compatibility:discover [2024-12-02 19:14] (current) – dettingale | ||
- | ====== Victron Energy and BLOOM AES Rackmount Batteries ====== | + | ====== Victron Energy and Discover |
- | **UNDER CONSTRUCTION - PLEASE VISIT LATER** | ||
- | The BLOOM Lithium Iron Phosphate batteries are compatible with Victron products in various systems. | + | The Discover |
- | These instructions are intended to be used in conjunction with the product manuals supplied by BLOOM Power. | + | These instructions are intended to be used in conjunction with the product manuals supplied by Discover Energy Systems. |
+ | For the latest product details, installation, | ||
- | For the latest product details, installation, | ||
- | The BLOOM LiFePO4 | + | The Discover LiFePO< |
- | These instructions provide information about integrating | + | These instructions provide information about integrating |
Configuration, | Configuration, | ||
Line 24: | Line 24: | ||
* Installing and configuring systems activated by relays | * Installing and configuring systems activated by relays | ||
- | **//No responsibility is assumed by BLOOM for any consequences arising from using this material. | + | **//No responsibility is assumed by Discover |
Read the AES RACKMOUNT Installation and Operation Manual and safety instructions before installing the battery. | Read the AES RACKMOUNT Installation and Operation Manual and safety instructions before installing the battery. | ||
Read Victron manuals for guidance on product features, functions, and parameters and for using the product safely.//** | Read Victron manuals for guidance on product features, functions, and parameters and for using the product safely.//** | ||
- | **WARNING: | + | **WARNING: |
- | Qualified personnel | + | * This equipment |
+ | * Do not disassemble or modify the battery. | ||
+ | * If the battery case has been damaged, do not touch exposed contents. | ||
+ | * There are no user-serviceable parts inside. | ||
**Failure to follow these instructions can result in death or serious injury.** | **Failure to follow these instructions can result in death or serious injury.** | ||
+ | **CAUTION: ELECTRIC SHOCK HAZARD** | ||
+ | * Do not touch the energized surfaces of any electrical component in the battery system. | ||
+ | * Before servicing the battery, follow all procedures to fully de-energize the battery system. | ||
+ | **Failure to follow these instructions can damage equipment** | ||
**CAUTION: HAZARD OF EQUIPMENT DAMAGE** | **CAUTION: HAZARD OF EQUIPMENT DAMAGE** | ||
* Do not install the LYNK II outdoors. | * Do not install the LYNK II outdoors. | ||
* Do not connect any port of the LYNK II to a network with power over Ethernet (POE) or to a public telecommunication network. | * Do not connect any port of the LYNK II to a network with power over Ethernet (POE) or to a public telecommunication network. | ||
* Do not run CAT5 cables or other cables connected to LYNK through a conduit that could be exposed to lightning strikes. | * Do not run CAT5 cables or other cables connected to LYNK through a conduit that could be exposed to lightning strikes. | ||
**Failure to follow these instructions can damage equipment** | **Failure to follow these instructions can damage equipment** | ||
Line 46: | Line 59: | ||
The LYNK II Communication Gateway is compatible with the following: | The LYNK II Communication Gateway is compatible with the following: | ||
- | **BLOOM Power Batteries** | + | **Discover |
* AES RACKMOUNT 48-48-5120 / 48-48-5120-H | * AES RACKMOUNT 48-48-5120 / 48-48-5120-H | ||
Line 70: | Line 83: | ||
- | **BLOOM Power Reference Documents: | + | **Discover |
* 808-0039 48-48-5120 AES RACKMOUNT Data Sheet | * 808-0039 48-48-5120 AES RACKMOUNT Data Sheet | ||
* 808-0040 48-48-5120-H AES RACKMOUNT (Heated) Data Sheet | * 808-0040 48-48-5120-H AES RACKMOUNT (Heated) Data Sheet | ||
Line 84: | Line 97: | ||
==== 3.1 System Overview ==== | ==== 3.1 System Overview ==== | ||
- | The LYNK II Communication Gateway unlocks the full potential of a BLOOM Lithium battery by enabling the internal Battery Management System (BMS) to provide real-time data in a closed-loop configuration to other devices. This configuration allows hybrid inverter-chargers and solar charge controller systems to optimize control over the charging process in solar applications. LYNK II also enables the remote monitoring of BLOOM Lithium battery SOC and data logging of multiple sites using the data monitoring services offered by off-grid inverter systems. | + | |
+ | The LYNK II Communication Gateway unlocks the full potential of a Discover | ||
Discover Lithium batteries must be set up to work with power conversion and monitoring devices in either an open-loop or closed-loop configuration. | Discover Lithium batteries must be set up to work with power conversion and monitoring devices in either an open-loop or closed-loop configuration. | ||
In an open-loop configuration, | In an open-loop configuration, | ||
- | In a closed-loop configuration, | + | In a closed-loop configuration, |
If communication between the BMS and Victron inverter-charger is interrupted, | If communication between the BMS and Victron inverter-charger is interrupted, | ||
Line 95: | Line 112: | ||
==== 3.2 Minimum Battery Capacity ==== | ==== 3.2 Minimum Battery Capacity ==== | ||
- | Battery charge and discharge rates are managed automatically by the BLOOM Lithium battery and Victron Energy device. Using large solar arrays with battery banks that are too small can exceed the operating limits of the battery to charge and possibly lead to the BMS triggering over-current protection. Either curtail the charging below the operational limit of installed batteries, or the battery capacity must accept the maximum charge current of the system. This value is derived by adding the charge capacities of all inverter-chargers and solar charge controllers in the system. Additionally, | + | Battery charge and discharge rates are managed automatically by the Discover |
- | ^ 120 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ | + | ^ 120 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ 48-48-5120-H ^ |
^ Quattro 48/3000/35 < | ^ Quattro 48/3000/35 < | ||
^ Quattro 48/5000/70 < | ^ Quattro 48/5000/70 < | ||
Line 116: | Line 133: | ||
- | ^ 230 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ | + | ^ 230 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ 48-48-5120-H ^ |
^ Quattro 48/8000/110 < | ^ Quattro 48/8000/110 < | ||
Line 169: | Line 186: | ||
- | ^ 277 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ | + | ^ 277 V Models ^ Inverter Peak ^ Max Continuous Discharge ^ Max Continuous Charge ^ AES RACKMOUNT Min 48-48-5120/ 48-48-5120-H ^ |
^ Quattro 48/ | ^ Quattro 48/ | ||
Line 175: | Line 192: | ||
- | ===== 4 Configuring | + | |
+ | ===== 4 Configuring | ||
==== 4.1 Configuring the LYNK II ==== | ==== 4.1 Configuring the LYNK II ==== | ||
- | **Setting Up Jumpers** | + | **LYNK II: Setting Up Jumpers** |
Jumpers configure termination for the LYNK Network and the CAN Out pin assignments. Follow the instructions in the LYNK II Installation and Operation Manual (805-0033) for accessing and configuring the header board with jumpers. | Jumpers configure termination for the LYNK Network and the CAN Out pin assignments. Follow the instructions in the LYNK II Installation and Operation Manual (805-0033) for accessing and configuring the header board with jumpers. | ||
Line 192: | Line 210: | ||
Adjust the jumpers on the header board to assign CAN signals (CAN H, CAN L, CAN GND) to the pins of the RJ45 connector. | Adjust the jumpers on the header board to assign CAN signals (CAN H, CAN L, CAN GND) to the pins of the RJ45 connector. | ||
^ CAN Out RJ45 Pin ^ Header Jumper ^ RJ45 Pin ^ | ^ CAN Out RJ45 Pin ^ Header Jumper ^ RJ45 Pin ^ | ||
Line 198: | Line 220: | ||
^ CAN GND | H3 - 1-3 | 3 | | ^ CAN GND | H3 - 1-3 | 3 | | ||
- | <Image of LYNK II Pin assignments for communication with Victron Energy devices> | ||
**LYNK ACCESS Software** | **LYNK ACCESS Software** | ||
- | LYNK ACCESS software for 64-bit Windows 10 / 11 is required to configure the LYNK II settings for closed-loop CAN communication with Victron Energy devices. | ||
+ | LYNK ACCESS software for 64-bit Windows 10 / 11 is required to configure the LYNK II settings for closed-loop CAN communication with Victron Energy devices. | ||
- Download the current version of LYNK ACCESS software from the Discover Energy Systems website to get the most up-to-date suite of available protocol configurations. | - Download the current version of LYNK ACCESS software from the Discover Energy Systems website to get the most up-to-date suite of available protocol configurations. | ||
- | - Using a USB cable with a Type-B mini-plug, connect the 64-bit Windows 10/11 device with the LYNK ACCESS software to the USB port on the LYNK II communication gateway. Ensure the LYNK II is powered and connected to the | + | - Using a USB cable with a Type-B mini-plug, connect the 64-bit Windows 10/11 device with the LYNK ACCESS software to the USB port on the LYNK II communication gateway. Ensure the LYNK II is powered and connected to the correct Victron COM port (VE.Can). |
- | correct Victron COM port (VE.Can). | + | |
- Open LYNK ACCESS and confirm that only one LYNK device is connected to the computer. | - Open LYNK ACCESS and confirm that only one LYNK device is connected to the computer. | ||
- Select the LYNK tab for optional configuration and settings. Select the blue gear icon in the upper right area of the CAN Settings tile. | - Select the LYNK tab for optional configuration and settings. Select the blue gear icon in the upper right area of the CAN Settings tile. | ||
Line 213: | Line 236: | ||
**NOTE:** In most cases, the communication speed for the Victron protocol should be 250 kbps to match the networked Victron devices. However, if communication cannot be established at that speed, the Victron device may require a communication speed of 500 kbps. | **NOTE:** In most cases, the communication speed for the Victron protocol should be 250 kbps to match the networked Victron devices. However, if communication cannot be established at that speed, the Victron device may require a communication speed of 500 kbps. | ||
==== 4.2 Connecting LYNK II to the VE.CAN Network ==== | ==== 4.2 Connecting LYNK II to the VE.CAN Network ==== | ||
Line 218: | Line 242: | ||
**Setting up the Battery** | **Setting up the Battery** | ||
- | Refer to the LYNK II Installation and Operation Manual (805-0033) | + | For instructions on network layouts and connections, |
* Connect at least one battery to the LYNK Port on the LYNK II. | * Connect at least one battery to the LYNK Port on the LYNK II. | ||
* A network of batteries will communicate as one battery. | * A network of batteries will communicate as one battery. | ||
- | * May connect no more than one network of batteries to the LYNK II. | + | * No more than one network of batteries |
* Proper system function requires network termination – some batteries and devices may auto-terminate. | * Proper system function requires network termination – some batteries and devices may auto-terminate. | ||
* LYNK II requires power from one of three possible sources (13-90 VDC power supply, a USB device, or AEbus Port or LYNK Port enabled Discover Lithium battery). | * LYNK II requires power from one of three possible sources (13-90 VDC power supply, a USB device, or AEbus Port or LYNK Port enabled Discover Lithium battery). | ||
- | * BLOOM Lithium batteries must be set to ON to supply power and communicate with LYNK II. | + | * Discover |
- | <image of AES RACKMOUNT battery module> | + | {{: |
LYNK II and AES RACKMOUNT battery modules are both internally terminated. No external termination is required when installing LYNK II with AES RACKMOUNT battery modules. | LYNK II and AES RACKMOUNT battery modules are both internally terminated. No external termination is required when installing LYNK II with AES RACKMOUNT battery modules. | ||
Line 233: | Line 257: | ||
Insert one end of a CAT5e or higher communication cable into the LYNK II CAN out port and the other end into one of the two VE.Can ports (A-B) on the back of the Victron device. As the LYNK II is internally terminated, the external terminator provided with the GX is not required. | Insert one end of a CAT5e or higher communication cable into the LYNK II CAN out port and the other end into one of the two VE.Can ports (A-B) on the back of the Victron device. As the LYNK II is internally terminated, the external terminator provided with the GX is not required. | ||
+ | - VE.Bus: RJ45 socket for connecting to the Victron inverter. | ||
+ | - VE.Can: RJ45 socket for connection to LYNK II CAN Out. | ||
+ | * Insert a terminator in the other VE.Can port to terminate the CAN network. | ||
===== 5 Configuring Victron Products ===== | ===== 5 Configuring Victron Products ===== | ||
- | When the LYNK II is in a closed-loop network using the CANopen protocol, LYNK II will transmit real-time parameters from the BLOOM Lithium battery, including voltage, current, temperature, | + | When the LYNK II is in a closed-loop network using the CANopen protocol, LYNK II will transmit real-time parameters from the Discover |
If there is a break in communication between the Victron Energy device and the LYNK II, the Victron device stops charging. Charging only resumes after communication between the Victron device and the LYNK II communication gateway is restored. If communication cannot be restored, you may have to set the system to open loop until an installation professional is available. | If there is a break in communication between the Victron Energy device and the LYNK II, the Victron device stops charging. Charging only resumes after communication between the Victron device and the LYNK II communication gateway is restored. If communication cannot be restored, you may have to set the system to open loop until an installation professional is available. | ||
Line 250: | Line 280: | ||
In such cases, you may have to set the system to open loop until the issue is resolved. The following describes how to set up open-loop on Victron devices. | In such cases, you may have to set the system to open loop until the issue is resolved. The following describes how to set up open-loop on Victron devices. | ||
You will need the latest firmware on all connected devices. The following presumes familiarity with VE Configure software. After setting the voltage-based open-loop parameters using the VE Configure 3 software, ‘send’ all parameters to the inverter-charger and GX device and then restart the GX device. | You will need the latest firmware on all connected devices. The following presumes familiarity with VE Configure software. After setting the voltage-based open-loop parameters using the VE Configure 3 software, ‘send’ all parameters to the inverter-charger and GX device and then restart the GX device. | ||
Line 255: | Line 286: | ||
**Procedure** | **Procedure** | ||
- | - Set the Discover Lithium batteries to ON and set the inverter to ON. | + | - Set the Discover Lithium batteries to ON and the inverter to ON. |
- Connect your computer to the Victron GX device or inverter. | - Connect your computer to the Victron GX device or inverter. | ||
- On the computer, start the VE Configure 3 software configuration tool. | - On the computer, start the VE Configure 3 software configuration tool. | ||
Line 262: | Line 293: | ||
- Toggle the On/ | - Toggle the On/ | ||
- | VE Configure 3 > General Tab | ||
- | ^ General Tab ^ 48-48-5120 / 48-48-5120-H ^ | ||
- | ^ [AC1] Overruled by remote < | ||
- | ^ [AC2] Overruled by remote < | ||
- | ^ Dynamic current limiter | Enable | | ||
- | ^ External current sensor connected | Disable | | ||
- | ^ Enable battery monitor | Enable | | ||
- | ^ State of charge when Bulk finished < | ||
- | ^ Battery capacity | Number of batteries x 100 Ah| | ||
- | ^ Charge efficiency < | ||
Line 289: | Line 306: | ||
^ Battery capacity | Number of batteries x 100 Ah| | ^ Battery capacity | Number of batteries x 100 Ah| | ||
^ Charge efficiency < | ^ Charge efficiency < | ||
- | <sup>1</ | + | <sup>2</ |
Line 308: | Line 325: | ||
Line 342: | Line 359: | ||
* Select **VE.Can & CAN-bus BMS (250 kbit/s)** | * Select **VE.Can & CAN-bus BMS (250 kbit/s)** | ||
- | (Select Victron solar inverters may operate with CAN-bus BMS 500 kbit/s) | + | * Return to the Device List, and the Discover Lithium Battery should now appear as one of the devices. |
- | 3. Return to the Device List, and the Discover Lithium Battery should now appear as one of the devices. | ||
**Device List** | **Device List** | ||
- | **NOTE:** If Discover does not appear on the Device List, confirm that the CAT5e or higher communication cable is a normal patch type, not a cross-over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor connection. | ||
- | 5.1.1 Configurable Closed-Loop Settings | + | {{: |
+ | **NOTE:** If **Discover AES** does not appear on the Device List, confirm that the CAT5e or higher communication cable is a normal patch type, not a cross-over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor connection. | ||
+ | === 5.1.1 Configurable Closed-Loop Settings | ||
During regular operation, the BMS sets the battery’s charge parameter limits, which the Victron GX device communicates to the inverter-charger and MPPT. | During regular operation, the BMS sets the battery’s charge parameter limits, which the Victron GX device communicates to the inverter-charger and MPPT. | ||
Line 359: | Line 383: | ||
**Device List > Settings > DVCC** | **Device List > Settings > DVCC** | ||
^ DVCC Menu ^ Setting ^ | ^ DVCC Menu ^ Setting ^ | ||
^ DVCC (Distributed Voltage and Current Control | Forced on | | ^ DVCC (Distributed Voltage and Current Control | Forced on | | ||
^ Limit charge current | ON < | ^ Limit charge current | ON < | ||
- | ^ Maximum charge current < | + | ^ Maximum charge current < |
^ Limit managed battery charge voltage | Disabled | | ^ Limit managed battery charge voltage | Disabled | | ||
^ SVS - Shared voltage sense | Forced off < | ^ SVS - Shared voltage sense | Forced off < | ||
Line 376: | Line 403: | ||
+ | === 5.1.2 Saving the Configurable Closed-Loop Settings === | ||
- | ===== 6.0 Powering Up Equipment ===== | + | **Device List > Settings > General > Reboot?** |
- | * Make sure none of the BLOOM communication cables are attached. | + | After the DVCC menu items have been set, reboot |
- | * Connect MultiPlus/ | + | |
- | * Connect all Victron communication cables at this time. | + | |
- | * Turn ON the Discover AES Battery press and hold switch on the battery/ | + | |
- | * Turn on Multi/ | + | |
- | If this is the initial set up of the MultiPlus or Quattro apply power to Victron Equipment and update firmware | + | |
- | * MultiPlus / Quattro - version 459 or later. | + | |
- | * GX device (Cerbo GX, Venus GX, etc) to include version 2.40 or later. | + | |
- | * VE.Direct MPPT - version 1.42 or later. | + | |
- | This will also presume the VE Bus has already set up if required, such as: | + | {{:battery_compatibility: |
- | * Dual Phase/Split Phase 180 degrees out | + | |
- | * 3 Phase | + | |
+ | **NOTE:** To avoid conflicting network information and data, do not use a Victron BMV battery monitor when using the LYNK II Communication Gateway. | ||
- | ==== 4.2 VE.Configure Settings ==== | ||
- | This section presumes familiarity with VEConfigure software. These settings are for an off-grid application. These parameters once set will become the default values used if communication with the AES battery is interrupted for some reason. During normal operation the charge characteristics are governed automatically by the GX device via DVCC, with instructions from the connected AES battery. However it is necessary to set the discharging parameters for DC input low shut-down found under the Inverter Tab. After setting the parameters, ‘send’ all parameters to the inverter and GX device. Restart the GX device after completion. | + | ===== 6.0 Powering Up Equipment |
- | Also keep in mind the settings below are for 1 unit only. If the system is a multiple inverter/ | + | |
- | ^ General Tab ^44-24-2800 ^42-48-6650^ | + | |
- | ^ Overruled by remote (1) |Enable| Enable| | + | |
- | ^ Enable battery monitor |Enable |Enable| | + | |
- | ^ SoC when Bulk finished (2) |95% |95%| | + | |
- | ^ Total battery capacity (per battery installed) |installed x 110 Ah |installed x 130 Ah| | + | |
- | Charge efficiency (2)| 95% |95%| | + | |
- | ^ Inverter Tab ^ 44-24-2800 ^ 42-48-6650^ | + | |
- | ^ DC input low shut-down (3) |24.0 V |48.0 V| | + | |
- | ^ DC Input low restart (4) |26.0 V |52.0 V| | + | |
- | ^ DC input low pre-alarm (5) |25.5 V |51.0 V| | + | |
- | ^ Enable AES (6) |Disable| Disable| | + | |
- | ^ Charger Tab ^ 44-24-2800 ^ 42-48-6650^ | + | |
- | ^ Enable charger |Enable |Enable| | + | |
- | ^ Battery Type (2) |Blank| Blank| | + | |
- | ^ Lithium batteries (2) |Enable |Enable| | + | |
- | ^ Charge curve (2) |Select: Fixed| Select: Fixed| | + | |
- | ^ Absorption voltage |(2) 27.2 V |54.4 V| | + | |
- | ^ Float voltage (2)| 26.8 V| 53.6 V| | + | |
- | ^ Charge current per battery installed (Recommended < Maximum) |installed x (78 A < 110 A)|installed x (92 A < 130 A)| | + | |
- | ^ Repeated absorption time (2) (7) |1.0 < 3.0 Hr| 1.0 < 3.0 Hr| | + | |
- | ^ Repeated absorption interval (2) |7.0 Days |7.0 Days| | + | |
- | ^ Absorption time (2) (7) |1.0 < 3.0 Hr |1.0 < 3.0 Hr| | + | |
- | (1) Enabled is recommended. | + | |
- | (2) Precautionary setting as they are ignored during normal operation and communication with AES Battery. | + | |
- | (3) The lowest operating voltage allowed, increase voltage as required. | + | |
- | (4) Restart voltage after DC input low shut-down, recommended to be set to the minimum value (minimum varies according to the DC Input low shut-down value). | + | |
- | (5) 51.0 V value (approximately 15% SoC) will trigger low battery warning, increase or decrease as preferred. | + | |
- | (6) ‘Enable AES’ has no relation to the AES Battery, refer to Victron manuals for information on setting and function. | + | |
- | (7) The recommended minimum is 1.0 hour. A longer period of time may be required to compensate for multiple batteries to achieve a smooth completion of charge. | + | |
- | **NOTE:** Confirm the Float Voltage after completing the installation of any Victron ‘Assistants’, | + | |
- | ==== 4.3 VE.Direct MPPT Settings | + | |
- | During normal operation the MPPT charge characteristics are governed by the GX device via DVCC, with instructions from the connected AES battery. | + | |
- | The settings below are precautionary. This section presumes familiarity with VictronConnect (Bluetooth App) used to configure, monitor and diagnose Victron MPPT products which feature Blue-tooth, or are equipped with a VE.Direct Port. | + | |
- | **NOTE:** VE.Can MPPTs cannot be used and are not yet supported | + | |
- | The max charge current is dictated by the size of MPPTs installed. If multiple MPPTs are installed verify all combined controllers would not exceed the battery limit. | + | |
- | ^MPPT Charge Controller Settings ^44-24-2800 ^42-48-6650^ | + | |
- | ^Battery voltage|24 V|48 V| | + | |
- | ^Max current per battery installed (Recommended < Maximum) (9)|installed x (78 A < 110 A)|installed x (92 A < 130 A)| | + | |
- | ^Charger enabled|Enabled|Enabled| | + | |
- | ^Battery preset |User Defined|User Defined| | + | |
- | ^Absorption voltage |27.2 V|54.8 V| | + | |
- | ^Maximum absorption time (10)|v 1.0 < 3.0 Hr|1.0 < 3.0 Hr| | + | |
- | ^Float voltage|26.8 V|54.0 V| | + | |
- | ^Equalization voltage|26.8 V|54.0 V| | + | |
- | ^Auto equalization|Disabled|Disabled| | + | |
- | ^Temperature compensation |Disabled |Disabled| | + | |
- | ^Low temperature cut off |5 C|5 C| | + | |
- | (9) May be set to lower value if necessitated by charger controller size. | + | |
- | (10) Duration of absorption period after the bulk charge interval. The recommended minimum is 1.0 hour. A longer | + | |
- | period of time may be required to compensate for multiple batteries to achieve a smooth completion of charge. | + | |
- | Turn OFF all Victron equipment. Turn OFF the Discover AES Battery press and hold switch on the battery/ | + | |
- | ===== 5. Installing LYNK and Connecting LYNK to the Victron Network ===== | + | |
- | ==== 5.1 Installing the LYNK Edge Card ==== | + | |
- | The LYNK Edge Card for Victron is a Slot 0 Type which only inserts into the left side slot on the bottom of the LYNK Communication Gateway. | + | |
- | **NOTE:** The LYNK Edge Card type to be used is determine by the brand of power conversion equipment. | + | |
- | * If LYNK Edge Card is in the wrong slot, it will not function. | + | |
- | * If LYNK Edge Card is not firmly seated, it will not function. | + | |
- | Choose a clean, dry, easily accessible indoor location. All the communication ports on the LYNK are accessible from the bottom of the device when mounted on a wall or DIN rail. Clearance of at least 50 mm (2 inches) below the device is needed to allow for the bend radius of cables connected to LYNK. | + | |
- | With LYNK disconnected from all devices remove cover and insert the LYNK Edge Card in the correct slot. This card has a RJ45 terminal built into the card. Ensure it is firmly seated into the internal connecting slot. Replace with provided slotted Edge Card cover after mounting LYNK Edge Card. | + | |
- | Install and network the AES LiFePO4 batteries as described in the 805-0015 AES LiFePO4 Battery Manual. Connect the AES LYNK Communication Gateway to the AES LIFePO4 Battery and power up as described in the 805-0017 LYNK Communication Gateway Users Manual. | + | |
- | **CAUTION: HAZARD OF EQUIPMENT DAMAGE** | + | |
- | * Do not plug the AEBus RJ-45 cable terminator into the 10/100 Ethernet port of the LYNK. | + | |
- | * Do not connect a CAT5 cable from the 10/100 Ethernet port of the LYNK to the WAN or MODEM port of a network router. | + | |
- | * Turn OFF all devices before connecting cables or inserting an Edge Card. | + | |
- | **Failure to follow these instructions can damage equipment.** | + | |
- | **NOTE:** Power electronics are not AEBus devices and should not be connected | + | |
- | to AEBus. | + | |
- | ==== 5.2 Connecting LYNK to the Victron Network ==== | + | |
- | Before connecting LYNK to the Victron Network ensure that the firmware for all Victron devices is up to date. | + | |
- | Insert one end of a CAT5 communication cable into the LYNK Edge Card port and the other end into one of the two VE.Can ports on the back of the GX device (Cerbo GX). Use the terminator provided with the GX device to terminate the network by plugging it into the second VE.Can port. See diagram below. | + | |
- | **NOTE:** Discover DC Power Converter and Lynk Gateway are internally terminated | + | |
- | ===== 6. System Set Up ===== | + | |
- | ==== 6.1 Synchronizing the Victron System with the AES Battery ==== | + | |
- | * Turn the Discover AES battery to ON press and hold switch on the battery/ | + | |
- | * Turn on all Victron equipment. | + | |
- | Through the VRM or a physical GX device access the System Setup menu in the Remote Console. Scroll down to select each item and then set as indicated. | + | |
- | * **Select “CAN-bus (1)”** | + | |
- | *** Select “CAN-bus Profile” to edit** | + | |
- | *** Within the “CAN-bus Profile” choose “VE CAN & CAN-bus”** | + | |
- | ** * “VE CAN-bus & CAN-bus BMS (250 kbit/s)” should appear on the “CAN-bus(1) menu** | + | |
- | Return to the Device List and the GX device should display Discover AES as one of the devices along with the battery SoC, Voltage and Amps. If you have multiple batteries a single entry will show up, which represents all batteries. | + | |
- | **NOTE:** If Discover does not appear on the Device List, confirm that the CAT5 communication cable is a normal patch type and not a cross over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor | + | |
- | connection. | + | |
- | The parameters option within the battery page shows the actual battery charge limits. If you have multiple batteries a single entry will show up, which represents all batteries. | + | |
- | **NOTE:** Battery Low Voltage value displayed is the BMS value, the actual discharge voltage limit is governed by the DC input low shut-down setting. | + | |
- | Once the VE.Can and CAN-bus bit rate is set, communication of the AES battery parameters will be automatic. | + | |
- | During normal operation, the charge parameter limits are set by the BMS of the AES battery and communicated through the system by the GX device to the inverter/ | + | |
- | Navigate from the Device List screen > Settings > System Setup> | + | |
- | From the System Setup menu scroll down to select each item and verify the system automatically updated in the DVCC. Note this was accomplished by the v2.40 Venus OS firmware upgrade to include. | + | |
- | * DVCC - Distributed Voltage and Current Control is forced “ON” | + | |
- | Within the DVCC menu verify: | + | |
- | * Limit Charge Current is “ON” **Note** If off-grid or have a generator you might want to turn “ON” | + | |
- | * Max charge current: Installed number of AES batteries x (42-48-6650: | + | |
- | * SVS - Shared voltage sense: Forced “OFF” | + | |
- | * STS - Shared temperature sense: Forced “OFF” | + | |
- | * SCS - Shared Current Sense: ' | + | |
- | * SCS Status - Should show " | + | |
- | (8) Limit charge current works across the whole system. MPPTs are automatically prioritized over the mains. In case the AES BMS requests a maximum charge current that is different from the user-configurable setting, the lower of the two will be used. | + | |
- | **NOTE:** To avoid conflicting network information and data, do not use a Victron BMV battery monitor when using AES LYNK Communication Gateway. | + | |
- | * Reboot the GX device after completion of all steps | + | |
- | ====== Victron Energy and Discover AES Batteries ====== | + | |
- | The Discover AES range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | + | |
- | These instructions are intended to be used in conjunction with the product manual(s) supplied by Discover Battery. | + | |
- | For the latest product details, installation and operation manuals, visit the Discover Battery website [[https:// | + | |
- | The Discover AES LiFePO4 Battery includes a Battery Management System (BMS) within each battery pack. The BMS interfaces with the Victron GX device and can support multiple batteries connected in parallel. | + | |
- | These instructions provide information about the integration of Discover AES Lithium batteries with Victron Energy devices in a Closed Loop configuration using the AES LYNK Communication Gateway with installed AES LYNK Edge Card for Victron. AES batteries can be use in an Energy Storage System (ESS) for self consumption, | + | |
- | **NOTE:** In a Victron networked system the charging variables will be managed automatically by the AES battery BMS and the GX device. Discharging variables are managed by the set up of the Victron inverter. | + | |
- | ===== 2. Documentation ===== | + | |
- | Victron Energy Reference Documents: | + | |
- | * Quattro Inverter Charge Manual | + | |
- | * MultiPlus Inverter Charge Manual | + | |
- | * SmartSolar / BlueSolar Charge Controller Manual | + | |
- | * GX device (Cerbo GX) Manual | + | |
- | Discover Reference Documents: | + | |
- | * Discover Energy 808-0004 42-48-6650 Data Sheet | + | |
- | * Discover Energy 808-0005 44-24-2800 Data Sheet | + | |
- | * Discover Energy 805-0015 AES LiFePO4 Battery 44-24-2800 42-48-6650 Manual | + | |
- | * Discover Energy 805-0017 AES LYNK Communication Gateway User Manual | + | |
- | * Discover Energy 805-0020 LYNK Edge Card Victron User Manual | + | |
- | Certain configuration, | + | |
- | * Installing electrical equipment | + | |
- | * Applying applicable installation codes | + | |
- | * Analyzing and reducing hazards involved in performing electrical work | + | |
- | * Installing and configuring batteries | + | |
- | **//No responsibility is assumed by Discover for any consequences arising out of the use of this material. | + | |
- | Read AES Battery Manual and Safety instructions before installing the battery. | + | |
- | Read Victron manuals for guidance on product features, functions, parameters and how to use the product safely.// | + | |
- | **WARNING: HAZARD OF ELECTRICAL SHOCK AND FIRE** | + | |
- | * Connect LYNK to only Safety Extra Low Voltage (SELV) circuits and power sources. | + | |
- | * All wiring must be completed by qualified personnel to ensure compliance with applicable installation codes and regulations. | + | |
- | **Failure to follow these instructions can result in death or serious injury.** | + | |
- | * Do not install LYNK outdoors. | + | |
- | * Do not connect any port of the LYNK to a network with power over Ethernet (POE) or to a public telecommunication network. | + | |
- | * Do not run CAT5 cables or other cables connected to LYNK through conduit that could be exposed to lightning strikes. | + | |
- | **Failure to follow these instructions can damage equipment** | + | |
- | ===== 3. Overview ===== | + | |
- | ==== 3.1 System Overview ==== | + | |
- | The AES LYNK Communication Gateway unlocks the full potential of a Discover AES LiFePO4 Battery by enabling the internal Battery Management System (BMS) to optimize the charge and discharge configurations of the world’s best inverter chargers and solar charge controller systems in a closed loop configuration. | + | |
- | **AES LiFePO4 batteries must be set up to work with Power Conversion and Monitoring devices in either an Open Loop or Closed Loop configuration.** | + | |
- | AES LiFePO4 battery charge and discharge settings in a Open Loop configuration are set up manually through the controller for the Power Conversion device at the time of installation. This is commonly referred to as a ‘lead acid drop-in replacement’ configuration. For information on Open Loop set up with Victron devices please visit the Discover Battery web site [[www.discoverbattery.com]] >> Solutions >> Solar >> Resources >> Application Note >>> | + | |
- | In a Closed Loop configuration the battery charge and discharge rates and settings are dynamically controlled by the BMS of the AES LiFePO4 Battery over a connection with the power conversion devices in the network. These instructions are for a Closed Loop configuration. | + | |
- | To connect with the communication network of a specific brand of inverter charger or solar charge controller, the LYNK Communication Gateway requires an AES LYNK Edge Card with the appropriate communication port. | + | |
- | ==== 3.2 Minimum Battery Capacity ==== | + | |
- | Battery charge and discharge rates are managed automatically by the AES LiFePO4 Battery and Victron GX device (Cerbo GX). Using very large solar arrays with battery banks that are too small can exceed the operating limits of the battery to charge and possibly lead to the BMS triggering over-current protection. Battery capacity must be sized to accept the maximum charge current of the system, or the the charging devices must be curtailed to charge below the operating limit of the installed batteries. This value is derived by adding together the charge capacities of all inverter/ | + | |
- | ^ Model^ Inverter Peak* ^ Charger ^ 1-Phase Min 42-48-6650 ^ 3-Phase Min 42-48-6650 ^ | + | |
- | ^ MultiPlus 48/3000/35 | 136 Adc | 35 Adc |1 |2| | + | |
- | ^ MultiPlus / Quattro 48/5000/70| 226 Adc|70 Adc |1 |3| | + | |
- | ^ Quattro 48/8000/110 |362 Adc| 110 Adc |2 |4| | + | |
- | ^ Quattro 48/ | + | |
- | *92% Efficiency at 48V | + | |
- | ^ Model^ Inverter Peak* ^ Charger ^ 1-Phase Min 44-44-2800 ^ | + | |
- | ^ MultiPlus / Quattro 24/3000/70| 271 Adc |70 Adc |1| | + | |
- | ^ MultiPlus / Quattro 24/ | + | |
- | *92% Efficiency at 24V | + | |
- | ===== 4 Configuring Victron Products ===== | + | |
- | ==== 4.1 Powering Up Equipment ==== | + | |
- | * Make sure none of the Discover | + | * Make sure none of the Discover communication cables are attached. |
- | * Connect | + | * Safely connect |
* Connect all Victron communication cables at this time. | * Connect all Victron communication cables at this time. | ||
- | * Turn ON the Discover | + | * Turn ON the AES RACKMOUNT |
* Turn on Multi/ | * Turn on Multi/ | ||
If this is the initial set up of the MultiPlus or Quattro apply power to Victron Equipment and update firmware to the devices listed to: | If this is the initial set up of the MultiPlus or Quattro apply power to Victron Equipment and update firmware to the devices listed to: | ||
* MultiPlus / Quattro - version 459 or later. | * MultiPlus / Quattro - version 459 or later. | ||
* GX device (Cerbo GX, Venus GX, etc) to include version 2.40 or later. | * GX device (Cerbo GX, Venus GX, etc) to include version 2.40 or later. | ||
* VE.Direct MPPT - version 1.42 or later. | * VE.Direct MPPT - version 1.42 or later. | ||
- | This will also presume the VE Bus has already set up if required, such as: | ||
- | * Dual Phase/Split Phase 180 degrees out | ||
- | * 3 Phase | ||
- | This section presumes familiarity with VEConfigure software. These settings are for an off-grid application. These parameters once set will become the default values used if communication with the AES battery is interrupted for some reason. During normal operation the charge characteristics are governed automatically by the GX device via DVCC, with instructions from the connected AES battery. However it is necessary to set the discharging parameters for DC input low shut-down found under the Inverter Tab. After setting the parameters, ‘send’ all parameters to the inverter and GX device. Restart the GX device after completion. | ||
- | Also keep in mind the settings below are for 1 unit only. If the system is a multiple inverter/ | ||
- | ^ General Tab ^44-24-2800 ^42-48-6650^ | ||
- | ^ Overruled by remote (1) |Enable| Enable| | ||
- | ^ Enable battery monitor |Enable |Enable| | ||
- | ^ SoC when Bulk finished (2) |95% |95%| | ||
- | ^ Total battery capacity (per battery installed) |installed x 110 Ah |installed x 130 Ah| | ||
- | Charge efficiency (2)| 95% |95%| | ||
- | ^ Inverter Tab ^ 44-24-2800 ^ 42-48-6650^ | ||
- | ^ DC input low shut-down (3) |24.0 V |48.0 V| | ||
- | ^ DC Input low restart (4) |26.0 V |52.0 V| | ||
- | ^ DC input low pre-alarm (5) |25.5 V |51.0 V| | ||
- | ^ Enable AES (6) |Disable| Disable| | ||
- | ^ Charger Tab ^ 44-24-2800 ^ 42-48-6650^ | ||
- | ^ Enable charger |Enable |Enable| | ||
- | ^ Battery Type (2) |Blank| Blank| | ||
- | ^ Lithium batteries (2) |Enable |Enable| | ||
- | ^ Charge curve (2) |Select: Fixed| Select: Fixed| | ||
- | ^ Absorption voltage |(2) 27.2 V |54.4 V| | ||
- | ^ Float voltage (2)| 26.8 V| 53.6 V| | ||
- | ^ Charge current per battery installed (Recommended < Maximum) |installed x (78 A < 110 A)|installed x (92 A < 130 A)| | ||
- | ^ Repeated absorption time (2) (7) |1.0 < 3.0 Hr| 1.0 < 3.0 Hr| | ||
- | ^ Repeated absorption interval (2) |7.0 Days |7.0 Days| | ||
- | ^ Absorption time (2) (7) |1.0 < 3.0 Hr |1.0 < 3.0 Hr| | ||
- | (1) Enabled is recommended. | ||
- | (2) Precautionary setting as they are ignored during normal operation and communication with AES Battery. | ||
- | (3) The lowest operating voltage allowed, increase voltage as required. | ||
- | (4) Restart voltage after DC input low shut-down, recommended to be set to the minimum value (minimum varies according to the DC Input low shut-down value). | ||
- | (5) 51.0 V value (approximately 15% SoC) will trigger low battery warning, increase or decrease as preferred. | ||
- | (6) ‘Enable AES’ has no relation to the AES Battery, refer to Victron manuals for information on setting and function. | ||
- | (7) The recommended minimum is 1.0 hour. A longer period of time may be required to compensate for multiple batteries to achieve a smooth completion of charge. | ||
- | **NOTE:** Confirm the Float Voltage after completing the installation of any Victron ‘Assistants’, | ||
- | ==== 4.3 VE.Direct MPPT Settings ==== | ||
- | During normal operation the MPPT charge characteristics are governed by the GX device via DVCC, with instructions from the connected AES battery. | ||
- | The settings below are precautionary. This section presumes familiarity with VictronConnect (Bluetooth App) used to configure, monitor and diagnose Victron MPPT products which feature Blue-tooth, or are equipped with a VE.Direct Port. | ||
- | **NOTE:** VE.Can MPPTs cannot be used and are not yet supported | ||
- | The max charge current is dictated by the size of MPPTs installed. If multiple MPPTs are installed verify all combined controllers would not exceed the battery limit. | ||
- | ^MPPT Charge Controller Settings ^44-24-2800 ^42-48-6650^ | ||
- | ^Battery voltage|24 V|48 V| | ||
- | ^Max current per battery installed (Recommended < Maximum) (9)|installed x (78 A < 110 A)|installed x (92 A < 130 A)| | ||
- | ^Charger enabled|Enabled|Enabled| | ||
- | ^Battery preset |User Defined|User Defined| | ||
- | ^Absorption voltage |27.2 V|54.8 V| | ||
- | ^Maximum absorption time (10)|v 1.0 < 3.0 Hr|1.0 < 3.0 Hr| | ||
- | ^Float voltage|26.8 V|54.0 V| | ||
- | ^Equalization voltage|26.8 V|54.0 V| | ||
- | ^Auto equalization|Disabled|Disabled| | ||
- | ^Temperature compensation |Disabled |Disabled| | ||
- | ^Low temperature cut off |5 C|5 C| | ||
- | (9) May be set to lower value if necessitated by charger controller size. | ||
- | (10) Duration of absorption period after the bulk charge interval. The recommended minimum is 1.0 hour. A longer | ||
- | period of time may be required to compensate for multiple batteries to achieve a smooth completion of charge. | ||
- | Turn OFF all Victron equipment. Turn OFF the Discover AES Battery press and hold switch on the battery/ | ||
- | ===== 5. Installing LYNK and Connecting LYNK to the Victron Network ===== | ||
- | ==== 5.1 Installing the LYNK Edge Card ==== | ||
- | The LYNK Edge Card for Victron is a Slot 0 Type which only inserts into the left side slot on the bottom of the LYNK Communication Gateway. | ||
- | **NOTE:** The LYNK Edge Card type to be used is determine by the brand of power conversion equipment. | ||
- | * If LYNK Edge Card is in the wrong slot, it will not function. | ||
- | * If LYNK Edge Card is not firmly seated, it will not function. | ||
- | Choose a clean, dry, easily accessible indoor location. All the communication ports on the LYNK are accessible from the bottom of the device when mounted on a wall or DIN rail. Clearance of at least 50 mm (2 inches) below the device is needed to allow for the bend radius of cables connected to LYNK. | ||
- | With LYNK disconnected from all devices remove cover and insert the LYNK Edge Card in the correct slot. This card has a RJ45 terminal built into the card. Ensure it is firmly seated into the internal connecting slot. Replace with provided slotted Edge Card cover after mounting LYNK Edge Card. | ||
- | Install and network the AES LiFePO4 batteries as described in the 805-0015 AES LiFePO4 Battery Manual. Connect the AES LYNK Communication Gateway to the AES LIFePO4 Battery and power up as described in the 805-0017 LYNK Communication Gateway Users Manual. | ||
- | **CAUTION: HAZARD OF EQUIPMENT DAMAGE** | ||
- | * Do not plug the AEBus RJ-45 cable terminator into the 10/100 Ethernet port of the LYNK. | ||
- | * Do not connect a CAT5 cable from the 10/100 Ethernet port of the LYNK to the WAN or MODEM port of a network router. | ||
- | * Turn OFF all devices before connecting cables or inserting an Edge Card. | ||
- | **Failure to follow these instructions can damage equipment.** | ||
- | **NOTE:** Power electronics are not AEBus devices and should not be connected | ||
- | to AEBus. | ||
- | ==== 5.2 Connecting LYNK to the Victron Network ==== | ||
- | Before connecting LYNK to the Victron Network ensure that the firmware for all Victron devices is up to date. | ||
- | Insert one end of a CAT5 communication cable into the LYNK Edge Card port and the other end into one of the two VE.Can ports on the back of the GX device (Cerbo GX). Use the terminator provided with the GX device to terminate the network by plugging it into the second VE.Can port. See diagram below. | ||
- | **NOTE:** Discover DC Power Converter and Lynk Gateway are internally terminated | ||
- | ===== 6. System Set Up ===== | ||
- | ==== 6.1 Synchronizing the Victron System with the AES Battery ==== | ||
- | * Turn the Discover AES battery to ON press and hold switch on the battery/ | ||
- | * Turn on all Victron equipment. | ||
- | Through the VRM or a physical GX device access the System Setup menu in the Remote Console. Scroll down to select each item and then set as indicated. | ||
- | * **Select “CAN-bus (1)”** | ||
- | *** Select “CAN-bus Profile” to edit** | ||
- | *** Within the “CAN-bus Profile” choose “VE CAN & CAN-bus”** | ||
- | ** * “VE CAN-bus & CAN-bus BMS (250 kbit/s)” should appear on the “CAN-bus(1) menu** | ||
- | Return to the Device List and the GX device should display Discover AES as one of the devices along with the battery SoC, Voltage and Amps. If you have multiple batteries a single entry will show up, which represents all batteries. | ||
- | **NOTE:** If Discover does not appear on the Device List, confirm that the CAT5 communication cable is a normal patch type and not a cross over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor | ||
- | connection. | ||
- | The parameters option within the battery page shows the actual battery charge limits. If you have multiple batteries a single entry will show up, which represents all batteries. | ||
- | **NOTE:** Battery Low Voltage value displayed is the BMS value, the actual discharge voltage limit is governed by the DC input low shut-down setting. | ||
- | Once the VE.Can and CAN-bus bit rate is set, communication of the AES battery parameters will be automatic. | ||
- | During normal operation, the charge parameter limits are set by the BMS of the AES battery and communicated through the system by the GX device to the inverter/ | ||
- | Navigate from the Device List screen > Settings > System Setup> | ||
- | From the System Setup menu scroll down to select each item and verify the system automatically updated in the DVCC. Note this was accomplished by the v2.40 Venus OS firmware upgrade to include. | ||
- | * DVCC - Distributed Voltage and Current Control is forced “ON” | ||
- | Within the DVCC menu verify: | ||
- | * Limit Charge Current is “ON” **Note** If off-grid or have a generator you might want to turn “ON” | ||
- | * Max charge current: Installed number of AES batteries x (42-48-6650: | ||
- | * SVS - Shared voltage sense: Forced “OFF” | ||
- | * STS - Shared temperature sense: Forced “OFF” | ||
- | * SCS - Shared Current Sense: ' | ||
- | * SCS Status - Should show " | ||
- | (8) Limit charge current works across the whole system. MPPTs are automatically prioritized over the mains. In case the AES BMS requests a maximum charge current that is different from the user-configurable setting, the lower of the two will be used. | ||
- | **NOTE:** To avoid conflicting network information and data, do not use a Victron BMV battery monitor when using AES LYNK Communication Gateway. | ||
- | * Reboot the GX device after completion of all steps | ||
battery_compatibility/discover.1730485248.txt.gz · Last modified: 2024-11-01 19:20 by dettingale
