battery_compatibility:freedomwon
battery_compatibility:freedomwon [2021-03-20 03:04] – guystewart | battery_compatibility:freedomwon [2024-02-08 14:12] (current) – updated etower manual link warwickchapman | ||
- | ====== Victron & Freedom Won LiFePO4 | + | ====== Victron & Freedom Won LiFePO4 |
===== Installers Note ===== | ===== Installers Note ===== | ||
Line 9: | Line 9: | ||
- | Freedom Won (www.freedomwon.co.za) produces two ranges of LiFePO4 | + | Freedom Won (www.freedomwon.co.za) produces two ranges of LiFePO< |
- | * Freedom | + | * Freedom |
+ | * Freedom Won eTower: Stackable 5kWh rack-mount battery eTower which presently includes only the e5000 model, designed specifically for enabling small economical storage solutions that can be upgraded | ||
+ | conveniently and cost effectively over time. The eTower is designed primarily for systems that need to start with 5kWh initially with a view to growing the storage capacity over time in 5kWh increments up to 20kWh. The LiTE range is recommended for systems starting at 10kWh or larger than 20kWh. | ||
- | //**Note: Refer to Freedom Won website | + | This documentation makes use of values |
- | These Freedom Lite batteries are fully compatible with the Victron MultiPlus, MultiPlus II, MultiPlus II GX, and Quattro inverter/ | + | **12V systems** |
+ | * Float and Bulk Charge Voltage: 14V | ||
+ | * Cut-out Voltage: 11.5V | ||
- | The Freedom | + | **24V Systems** |
+ | * Float and Bulk Charge Voltage: 28V | ||
+ | * Cut-out Voltage: 23V | ||
+ | **Note: Refer to Freedom Won website for detailed specification sheets covering all models** | ||
+ | These Freedom Won LiTE batteries are fully compatible with the Victron MultiPlus, MultiPlus-II, | ||
+ | The Freedom | ||
+ | All Freedom Won LiTE models can be connected in parallel with other models of the same capacity, where one LiTE (Master) communicates with the GX device as well as all the other LiTE’s in the system (Slaves). | ||
- | All Freedom Lite models can be connected in parallel with other models of the same capacity, where one Lite (Master) communicates with the GX device as well as all the other Lite’s in the system (Slaves). | ||
The Victron and Freedom Won integration has been extensively developed and tested and is certified and supported by both companies. | The Victron and Freedom Won integration has been extensively developed and tested and is certified and supported by both companies. | ||
+ | The eTower can be paralleled up to 16 units. The recommended limit is 4 batteries in parallel because systems that require more than 20kWh are usually better accommodated by the Freedom Won LiTE range of high performance batteries. Systems that use a 250kbps CAN bus cannot be used with eTower, for example where they include the older VE.Can MPPTs (box-type). | ||
The system is suitable for all applications, | The system is suitable for all applications, | ||
Line 30: | Line 45: | ||
* Off Grid plant with storage and solar | * Off Grid plant with storage and solar | ||
- | __//Figure 1 Typical Installation: | + | __//Figure 1 Typical Installation: |
__ | __ | ||
- | __//Figure 2 Typical Installation: | + | __//Figure 2 Typical Installation: |
Line 40: | Line 55: | ||
===== This Manual ===== | ===== This Manual ===== | ||
- | This manual is intended to offer Victron specific guidance when designing, installing, and commissioning a Victron – Freedom | + | This manual is intended to offer Victron specific guidance when designing, installing, and commissioning a Victron – Freedom |
===== Product Compatibility ===== | ===== Product Compatibility ===== | ||
- | All new Victron equipment as follows is compatible with Freedom | + | All new Victron equipment as follows is compatible with Freedom |
* MultiPlus | * MultiPlus | ||
- | * MultiPlus II | + | * MultiPlus-II |
- | * MultiPlus GX | + | * MultiPlus-II GX |
* Quattro | * Quattro | ||
- | * Blue Solar and Smart Solar VE.Direct MPPTs | + | * Quattro-II |
+ | * Inverter RS | ||
+ | * MPPT RS | ||
+ | * Multi RS | ||
+ | * BlueSolar | ||
* VE.Can MPPT’s | * VE.Can MPPT’s | ||
- | //**NOTE**: Certain older MultiPlus and Quattro models containing the smaller microprocessor chip (numbered 19 and 20) are not able to accept the version XXXX4XX firmware and hence are not compatible with the CAN Bus communication from the Freedom | + | //**NOTE**: Certain older MultiPlus and Quattro models containing the smaller microprocessor chip (numbered 19 and 20) are not able to accept the version XXXX4XX firmware and hence are not compatible with the CAN Bus communication from the Freedom |
- | //**NOTE**: If a system includes one or more **VE.CAN MPPTs** please carefully read the section below on VE.CAN MPPTs.// | + | //**NOTE**: If a system includes one or more **VE.Can MPPTs** please carefully read the section below on VE.Can MPPTs.// |
===== GX-Device Required ===== | ===== GX-Device Required ===== | ||
Line 65: | Line 83: | ||
In all cases the latest available firmware should be installed on the Victron devices. | In all cases the latest available firmware should be installed on the Victron devices. | ||
- | The Freedom | + | The Freedom |
===== Battery Sizing ===== | ===== Battery Sizing ===== | ||
- | Further to above, the Lite should be sized so as to provide adequate energy capacity in kWh to meet the load demands of the system and to receive most of the excess solar generation each day (for self-consumption installations). | + | Further to above, the LiTE should be sized so as to provide adequate energy capacity in kWh to meet the load demands of the system and to receive most of the excess solar generation each day (for self-consumption installations). |
- | //**NOTE**: It is not permissible to install an inverter larger than stated in the Lite specification sheet regardless of whether the "Limit DC Discharge Power" ESS feature in the GX-device is used. For instances where the grid is not available this power limiting feature will not operate and the battery could thus be overloaded, causing it to trip. The Lite will also not be able to limit discharge power in the absence of a grid connection. Lastly, the Lite contains a protection circuit breaker that is only rated to handle the power-up inrush current of the inverter for up to the capacity stated in the specification sheet.// | + | //**NOTE**: It is not permissible to install an inverter larger than stated in the LiTE specification sheet regardless of whether the "Limit DC Discharge Power" ESS feature in the GX-device is used. For instances where the grid is not available this power limiting feature will not operate and the battery could thus be overloaded, causing it to trip. The LiTE will also not be able to limit discharge power in the absence of a grid connection. Lastly, the LiTE contains a protection circuit breaker that is only rated to handle the power-up inrush current of the inverter for up to the capacity stated in the specification sheet.// |
===== Victron-certified Integration ===== | ===== Victron-certified Integration ===== | ||
- | - Adaptive Maximum Charge Voltage Set-point – the value transmitted varies from 54.8V to 55.8V depending on the state of balancing on the particular | + | - **Adaptive Maximum Charge Voltage |
- | - Charge Current Limit (CCL) – this is the maximum current that the battery will accept at any given time stated in Amps. This is a secondary control feature behind the more effective maximum charge voltage control method. This value reduces as the battery approaches 100% State of Charge (SoC). The GX-device uses this value to ensure that the combined Victron system of inverter/ | + | |
- | - Discharge Current Limit (DCL) – this is the maximum discharge current that the battery is prepared to accept at any given time. This value typically decreases as the battery drops below 10% SoC. The Victron inverter cannot enforce a variable DCL unless in ESS mode were an AC input source can be used to supplement the power to the loads. If there is no AC input source the inverter will stop supplying power to the loads as soon as the DCL drops to zero. | + | - **Charge Current Limit (CCL)** – this is the maximum current that the battery will accept at any given time stated in Amps. This is a secondary control feature behind the more effective maximum charge voltage control method. This value reduces as the battery approaches 100% State of Charge (SoC). The GX-device uses this value to ensure that the combined Victron system of inverter/ |
+ | - **Discharge Current Limit (DCL)** – this is the maximum discharge current that the battery is prepared to accept at any given time. This value typically decreases as the battery drops below 10% SoC. The Victron inverter cannot enforce a variable DCL unless in ESS mode were an AC input source can be used to supplement the power to the loads. If there is no AC input source the inverter will stop supplying power to the loads as soon as the DCL drops to zero. | ||
- Additional Battery Information | - Additional Battery Information | ||
- Battery temperature | - Battery temperature | ||
Line 97: | Line 117: | ||
- Number of batteries online | - Number of batteries online | ||
- | All of the above information can be viewed in the Freedom | + | All of the above information can be viewed in the Freedom |
Specific setup of the GX-device and the MultiPlus/ | Specific setup of the GX-device and the MultiPlus/ | ||
If the CAN bus cable is removed or damaged the Victron inverters will shut down within 5 minutes. This prevents continued operation in the absence of communication from the battery. Likewise, the MPPT’s will stop producing power to the DC bus. | If the CAN bus cable is removed or damaged the Victron inverters will shut down within 5 minutes. This prevents continued operation in the absence of communication from the battery. Likewise, the MPPT’s will stop producing power to the DC bus. | ||
- | ===== DC Bus Pre-charging | + | ===== DC Bus Pre-Charging |
**Important: | **Important: | ||
Line 108: | Line 128: | ||
The inrush current when switching on the battery breaker onto the DC bus is huge. This can cause damage to the breaker over time. So it is a Freedom Won requirement that the DC bus is pre-charged before switching on the battery. This is achieved by switching on the AC input to the inverters – the inverters will use the AC power to pre-charge their capacitors. This will eliminate the huge inrush current. The MPPTs can also be used for pre-charging by switching on the solar panels supply to the MPPTs. | The inrush current when switching on the battery breaker onto the DC bus is huge. This can cause damage to the breaker over time. So it is a Freedom Won requirement that the DC bus is pre-charged before switching on the battery. This is achieved by switching on the AC input to the inverters – the inverters will use the AC power to pre-charge their capacitors. This will eliminate the huge inrush current. The MPPTs can also be used for pre-charging by switching on the solar panels supply to the MPPTs. | ||
- | ===== CAN Bus Wiring ===== | + | ===== CAN-bus Wiring ===== |
- | The connection of the Lite to the GX-device is extremely simple. A standard **straight through** CAT5e Ethernet cable is required of the desired length, with one end plugged into one of the RJ45 sockets on the Lite and the other end plugged into one of the CAN sockets on the GX-device. Note that the second RJ45 socket in each case must be fitted with an end of line 120Ω resistor. Two are supplied with each GX-device. | + | The connection of the LiTE to the GX-device is extremely simple. A standard **straight through** CAT5e Ethernet cable is required of the desired length, with one end plugged into one of the RJ45 sockets on the LiTE and the other end plugged into one of the CAN sockets on the GX-device. Note that the second RJ45 socket in each case must be fitted with an end of line 120Ω resistor. Two are supplied with each GX-device. |
- | **Note:** In the case of the Venus GX or Octo GX, if the VE.CAN ports (RJ45) | + | The eTower comes supplied with a cable labelled " |
- | **Note: | + | **Note: |
- | If multiple batteries are installed in parallel the second RJ45 socket is used to link the next battery in the line onto the CAN Bus network. The termination resistor is installed in the last battery | + | **Note:** When using a Cerbo GX use the BMS-CAN port for the battery |
- | Correct | + | For LiTE batteries in parallel, the second RJ45 socket is used to link the next battery in the line onto the CAN Bus network. The termination resistor is installed in the last battery in the CAN Bus line. Refer to [[https:// |
- | ===== Victron VE.CAN MPPTs and Freedom Won Batteries ===== | + | For eTower batteries in parallel, the first battery must be programmed as the Master by setting it to Address 01 using the DIP switches, while the rest of the eTower modules connected to the DC bus are programmed as Slaves by default when they have addresses of 02 or higher. Refer to the [[https:// |
+ | **eTower DIP Settings** | ||
+ | **eTower DIP Switch Positions for Address Numbers 0 to 15** | ||
+ | Correct CAN Bus communication can be verified by observing whether the Freedom Won LiTE battery is presented in the GX-device list under the name " | ||
+ | ===== Victron VE.Can MPPTs and Freedom Won Batteries ===== | ||
**Note:** In this section, the reference to "Color Control GX" refers only to that specific model of GX device and excludes the rest of the range. | **Note:** In this section, the reference to "Color Control GX" refers only to that specific model of GX device and excludes the rest of the range. | ||
- | The Freedom Won Battery Management System is configured by default to communicate over CAN bus at a 500kbps baud rate. For systems using a Color Control GX and Victron VE.CAN MPPTs, it is possible to change the baud rate of the battery | + | The Freedom Won Battery Management System is configured by default to communicate over CAN bus at a 500kbps baud rate. For systems using a Color Control GX and Victron VE.Can MPPTs, it is possible to change the baud rate of the BMS to 250kbps in order to accommodate the VE.Can baud rate. **However**, |
- | If there are slave batteries on a system, then there are conflicting CAN messages on the bus, and it is necessary to split the battery on the CAN Bus from the devices on Victron' | + | If there are slave batteries on a system, then there are conflicting CAN messages on the bus, and it is necessary to split the battery on the CAN Bus from the devices on Victron' |
- | Systems with both VE.CAN MPPTs and more than one Freedom | + | In such cases, MPPTs must be swapped out for VE.Direct versions and [[https:// |
+ | Systems with both VE.Can MPPTs and more than one Freedom | ||
Where batteries need to be configured with a profile accommodating 250kbps baud rate for the MPPTs on the CAN Bus (the standard is 500kbps), the change can be made either: | Where batteries need to be configured with a profile accommodating 250kbps baud rate for the MPPTs on the CAN Bus (the standard is 500kbps), the change can be made either: | ||
- | - at the time of ordering by requesting that Freedom Won dispatches the Lite from the factory with baud set to 250kbps; or | + | - at the time of ordering by requesting that Freedom Won dispatches the LiTE from the factory with baud set to 250kbps; or |
- the battery can be reconfigured remotely by Freedom Won with a local PC connected to the battery. | - the battery can be reconfigured remotely by Freedom Won with a local PC connected to the battery. | ||
Line 138: | Line 172: | ||
===== VEConfigure 3 Settings ===== | ===== VEConfigure 3 Settings ===== | ||
- | The MultiPlus or Quattro devices must be correctly configured for operation with the Freedom | + | The MultiPlus or Quattro devices must be correctly configured for operation with the Freedom |
The GX-device will use the battery monitor provided by the Freedom Won battery by default: | The GX-device will use the battery monitor provided by the Freedom Won battery by default: | ||
- | ☛ Since Venus OS 2.60, it is no longer necessary to disable the Battery Monitor. Whether it is on, or off, you can ignore it. | + | ☛ Set the Low Shut-Down, Low Restart, and Low Pre-alarm voltages. |
- | ☛ Set the Low Shut-Down, Low Restart, and Low Pre-alarm voltages. | + | |
Line 156: | Line 188: | ||
- | ☛ Set Charger Settings. | + | ☛ Set Charger Settings. |
**Note:** only adjust these values **after** selecting Lithium battery as the defaults entered by VE.Configure when selecting the Lithium battery type are not suitable to Freedom Won batteries. | **Note:** only adjust these values **after** selecting Lithium battery as the defaults entered by VE.Configure when selecting the Lithium battery type are not suitable to Freedom Won batteries. | ||
Line 167: | Line 199: | ||
- | ☛ When setting up the ESS Assistant select LiFePO4 battery and enter the Ah value for the Lite (or the combination of Lite’s | + | ☛ When setting up the ESS Assistant select LiFePO4 battery and enter the Ah value for the LiTE (or the combination of LiTE for a parallel battery system) as per the Ah rating provided in the LiTE specification sheet eg. LiTE 5/4 = 100Ah. |
+ | **Important**: | ||
Line 182: | Line 216: | ||
- | ☛ Enter Dynamic Cut-off values as below (usually the Lite will override these values, however they should be entered correctly for redundancy) | + | ☛ Enter Dynamic Cut-off values as below (usually the LiTE will override these values, however they should be entered correctly for redundancy) |
Line 189: | Line 223: | ||
- | ☛ Go back to General and disable battery monitor again. | ||
===== GX-Device Venus OS Configuration ===== | ===== GX-Device Venus OS Configuration ===== | ||
Line 196: | Line 228: | ||
NOTE: Venus OS 2.60 has important updates to the support for FreedomWon Batteries and it is strongly recommended that you make use of 2.60 or newer. | NOTE: Venus OS 2.60 has important updates to the support for FreedomWon Batteries and it is strongly recommended that you make use of 2.60 or newer. | ||
- | It is very important that the following settings are entered correctly for proper functioning of the Lite communication interface: | + | It is very important that the following settings are entered correctly for proper functioning of the LiTE communication interface: |
- | ☛ Settings → Services → VE.CAN port → CAN-bus Profile → CAN-bus BMS (500kbit/s) | + | ☛ Settings → Services → VE.Can port → CAN-bus Profile → CAN-bus BMS (500kbit/s) |
- | //**Note**: For systems with VE Can MPPT's and only one CAN-port (CCGX), select 250kbit/s and ensure | + | //**Note**: For systems with VE.Can MPPT's and only one CAN-port (CCGX), select 250kbit/s and ensure |
- | All other GX devices have dual CAN-ports or a CAN-port that only supports 500kbit/s (GX version of inverters) so on those systems BMS-CAN should be set at 500kbps// | + | All other GX devices have dual CAN-ports or a CAN-port that only supports 500kbit/s (GX version of inverters) so on those systems BMS-CAN should be set at 500kbps// |
- | ☛ Confirm that the Freedom | + | ☛ Confirm that the Freedom |
- | ☛ Freedom | + | ☛ Freedom |
+ | Note: If the battery is fully charged the CCL may be reduced. Check that the voltage target is within the range 54.8V to 55.8V (Note: below about 95% SoC the value reflected should be 55.7 or 55.8V. For a fully charged battery this value should range from 55.0V to 55.8V depending on the state of balancing of the cells in the LiTE. | ||
☛ Confirm that DVCC is forced on at: Settings → DVCC | ☛ Confirm that DVCC is forced on at: Settings → DVCC | ||
+ | ☛ Use "Keep Batteries Charged" | ||
+ | BatteryLife is mandatory for Freedom Won LiTE batteries that are being cycled. This is to prevent long durations without the battery seeing 100% charge, and this in turn eliminates SoC drift issues that creep in after several days without the battery having reached 100% SoC. | ||
===== MPPT Configuration ===== | ===== MPPT Configuration ===== | ||
- | The voltage setpoints on the MPPT's must be set to 55.8V for bulk and float with equalisation *disabled*. In order to do this on the VE.CAN MPPT's select the User Defined option 8 battery type as this allows adjustment of the charge voltage setpoints. | + | The voltage setpoints on the MPPT's must be set to 55.8V for bulk and float with equalisation *disabled*. In order to do this on the VE.Can MPPT's select the User Defined option 8 battery type as this allows adjustment of the charge voltage setpoints. |
+ | Adjust the maximum current on the MPPT's to ensure that the combined total charge power cannot exceed the maximum rated charge current for the LiTE or LiTE's in the system. | ||
+ | ===== Large Parallel Banks (>3000A Current Limits) ===== | ||
+ | The CAN Bus hexadecimal message format that the Victron GX controller uses cannot accept a number larger than 3000 for the Charge Current Limit (CCL) and the Discharge Current Limit (DCL). | ||
+ | Freedom Won LiTE batteries are designed for very high current capabilities, | ||
+ | The designer must refer to the LiTE specification sheet to determine if the total of the CCL or DCL for all the batteries connected on the system will add up to a value greater than 3000A. | ||
- | Adjust | + | If this is the case, the commissioning technician must arrange with Freedom Won technical support ([[support@freedomwon.co.za]]) |
- | ===== Troubleshooting ===== | + | Please refer to the note below regarding scheduling time with support if required. |
- | Should any difficulties arise with the Freedom Lite to Victron interface please contact [[support@freedomwon.co.za]] for assistance. | + | ===== Technical Support and Troubleshooting ===== |
+ | Should any difficulties arise with the Freedom Won LiTE to Victron interface please contact [[support@freedomwon.co.za]] for assistance. | ||
+ | Please remember that our support team may not always be immediately available. | ||
battery_compatibility/freedomwon.1616205868.txt.gz · Last modified: 2021-03-20 03:04 by guystewart
