battery_compatibility:redflow_zcell
Victron & Redflow ZCell
Note that the ZCell is currently only available in Australia.
Compatible Victron products
- All 48V Multis and Quattros.
- All 48V solar chargers
- Adding a Color Control GX is recommended but not required
Charge profile
- Charge voltage 57.6V (up to 50 Amps per battery, and current per battery self-limits if you limit the voltage)
- Linear charge all the way from empty to full (all charge phases are the same - same ‘flat’ voltage).
- No need for any sort of battery ‘conditioning’ cycling at all
Charger settings:
- Set both absorption and float voltage to 57.6V
- disable storage mode.
- disable bulk protection(?? Simon?)
- using Assistants, such as the Hub-4 Assistant, is possible but not required.
Color Control GX
Follow this procedure to show the ZCell SOC on the Color Control GX.
Also see this other FAQ item on the ZCell website: https://faq.zcell.com/content/10/54/en-us/automatic-start-for-a-multiplus-connected-to-a-powered_down-ccgx.html
The Color Control GX does not yet have the option to read and show any other ZCell parameters.
Disqus
battery_compatibility/redflow_zcell.1465595832.txt.gz · Last modified: 2016-06-10 23:57 by mvader
