battery_compatibility:start
battery_compatibility:start [2023-11-15 14:29] – external edit 127.0.0.1 | battery_compatibility:start [2024-09-17 10:36] (current) – mvader | ||
Line 7: | Line 7: | ||
These are mostly connected via " | These are mostly connected via " | ||
- | ==== Specific information about batteries that have been tested | + | ==== Specific information about batteries that are known to have been tested ==== |
Line 17: | Line 17: | ||
* [[pylontech_phantom|Pylontech]] | * [[pylontech_phantom|Pylontech]] | ||
Line 28: | Line 31: | ||
- | ==== General information about batteries that have not been tested by Victron | + | ==== General information about batteries that are not on above list ==== |
Many additional 3rd party batteries are also compatible with Victron, and are recommended by local dealers. | Many additional 3rd party batteries are also compatible with Victron, and are recommended by local dealers. | ||
Line 56: | Line 61: | ||
==== Common issues we have seen from other DIY / Self-build oriented BMSes ==== | ==== Common issues we have seen from other DIY / Self-build oriented BMSes ==== | ||
- | Batteries | + | Batteries |
- | In this case the Victron | + | |
- | Another common example is Victron requires the BMS to change the Charge Voltage Limit to restrict power flowing to the battery as it gets full. If the BMS attempts restriction using the Charge Current Limit without adjusting the Charge Voltage Limit it can cause Overcharge, Overvoltage or Overcurrent warnings. | + | |
+ | For example the Victron inverter/ | ||
+ | Another common problem as a battery becomes fully charged, Victron requires the BMS to change the Charge Voltage Limit (CVL) to restrict the power flowing to the battery. If, however, the BMS attempts to restrict power using the Charge Current Limit, without adjusting the Charge Voltage Limit, this can trigger Overcharge, Overvoltage or Overcurrent warnings. | ||
==== SAFETY WARNING ==== | ==== SAFETY WARNING ==== | ||
battery_compatibility/start.1700054963.txt.gz · Last modified: 2023-11-15 14:29 by 127.0.0.1
