ccgx:beta-testing
ccgx:beta-testing [2020-11-24 10:10] – [What not to do?] mvader | ccgx:beta-testing [2024-10-21 09:57] (current) – [Where should I post possible bug reports?] mvader | ||
Would you like to become a Beta tester? | Would you like to become a Beta tester? | ||
- | Venus OS - or //Venus// for short - is the operating software for our //Color Control | + | Venus OS - or //Venus// for short - is the operating software for our range of GX monitoring products, such as the Cerbo GX. Extensive field testing over a wide variety of installation-types and user-cases is very valuable to us ...and we're very grateful to you for your interest in joining this program, and for your help. |
==== What happens when I join the program? ==== | ==== What happens when I join the program? ==== | ||
Line 15: | Line 15: | ||
This is a note to dealers & installers: **Do not install test versions on a customer' | This is a note to dealers & installers: **Do not install test versions on a customer' | ||
- | These versions are called //test versions//, or // | + | These versions are called |
Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. | Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. | ||
Line 23: | Line 23: | ||
If the problem also exists with the official release; then contact normal support. | If the problem also exists with the official release; then contact normal support. | ||
- | If the problem only exists in the beta version, then please post a message on the relevant Venus OS beta version thread on [[https:// | + | If the problem only exists in the beta version, then please post a message on the [[https:// |
And don't forget to mention which test version you are using. | And don't forget to mention which test version you are using. | ||
==== How to join the program? ==== | ==== How to join the program? ==== | ||
- | Go to Settings -> Firmware -> Online updates -> Update | + | Go to Settings -> Firmware -> Online updates -> Update |
- | To receive the emails about the test versions, make sure you register the device on the VRM Portal, and change the setting so that you have admin rights on the product. | + | |
==== How can I install the latest beta firmware? ==== | ==== How can I install the latest beta firmware? ==== | ||
Line 38: | Line 35: | ||
...or alternatively, | ...or alternatively, | ||
- | http:// | + | https:// |
+ | Which directory to use depends on the GX Device you have: | ||
- | You will find the Venus GX images in the directory titled: //beaglebone///. | + | * Venus GX: beaglebone |
+ | * Cerbo GX: einstein | ||
+ | * Cerbo-S GX: cerbosgx | ||
+ | * Ekrano GX: ekrano | ||
+ | * MultiPlus-II GX, or EasySolar-II GX: nanopi | ||
ccgx/beta-testing.1606209029.txt.gz · Last modified: 2020-11-24 10:10 by mvader
