ccgx:ccgx_wireless_ac_sensor
ccgx:ccgx_wireless_ac_sensor [2019-01-21 10:59] – [Wireless AC sensor menu] ictbeheer | ccgx:ccgx_wireless_ac_sensor [2021-03-20 03:05] (current) – guystewart | ||
====== Wireless AC Sensor manual ====== | ====== Wireless AC Sensor manual ====== | ||
+ | (discontinued product) | ||
- | The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[https:// | + | The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[https:// |
- | Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The CCGX will in such case only show the value of the last-read sensor. | + | Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The GX device |
==== Three phase ==== | ==== Three phase ==== | ||
Line 21: | Line 22: | ||
* AC adapter | * AC adapter | ||
Line 31: | Line 32: | ||
- Disconnect the AC power | - Disconnect the AC power | ||
- Connect the gateway to the Ethernet/ | - Connect the gateway to the Ethernet/ | ||
- | - Connect the AC power adapter or the USB cable from the ColorControl | + | - Connect the AC power adapter or the USB cable from the GX device |
=== Installing the sensor(s) === | === Installing the sensor(s) === | ||
Line 61: | Line 62: | ||
|Blinking red |Not yet paired to a gateway | | |Blinking red |Not yet paired to a gateway | | ||
|Both green and red on (no blinking) |Cannot find the gateway. Only shows for a few seconds, after that the led will turn off | | |Both green and red on (no blinking) |Cannot find the gateway. Only shows for a few seconds, after that the led will turn off | | ||
- | |Alternating red/green |Selected in the Color Control | + | |Alternating red/green |Selected in the GX device |
|Green on (no blinking) |Gateway found, connecting. This will show only for a few seconds | | |Green on (no blinking) |Gateway found, connecting. This will show only for a few seconds | | ||
|Off |Working OK, connected to the gateway, cannot find gateway or not powered | | |Off |Working OK, connected to the gateway, cannot find gateway or not powered | | ||
- | ===== Configuration on the Color Control | + | ===== Configuration on the GX device |
==== Wireless AC sensor menu ==== | ==== Wireless AC sensor menu ==== | ||
Line 103: | Line 104: | ||
+ | ~~DISQUS~~ | ||
ccgx/ccgx_wireless_ac_sensor.1548064758.txt.gz · Last modified: 2019-01-21 10:59 by ictbeheer
