ccgx:ccgx_wireless_ac_sensor
Wireless AC Sensor manual
DRAFT
Introduction
The Wireless AC sensors can measure current (A) and power (W) and energy (kWh) from a PV Inverter, to show PV Inverter data on a Color Control GX. An installation will have one gateway, and one sensor per phase. The gateway connects to the Color Control via Ethernet, and is the DECT hub for the sensors.
Required hardware
- TIM000100100 - Wireless AC sensor 25A (one for each phase)
- TIM000100000 - Wireless Sensor gateway (one for every system)
- RJ45 cable 30cm (included with the gateway)
- AC adapter (included with the Wireless Sensor gateway)
Note that instead of powering the Wireless Sensor gateway with the AC adapter, it is also possible to power it from one of the USB ports in the Color Control GX. Purchase a separate male Micro-USB to male USB cable, not available from Victron. (note, it is not yet sure if the CCGX can supply enough power, we are currently testing this.
[ plaatje micro usb ]
Installation
Installing the gateway
- Disconnect the AC power
- Connect the gateway to the network using the supplied RJ45 cable.
- Connect the AC power adapter to the gateway
Installing the sensor(s)
- Connect the AC sensor according to the schematic below.Neutral on top side. Line on bottom side. Make sure the direction of the current is correct.
Configuration
ccgx/ccgx_wireless_ac_sensor.1414657123.txt.gz · Last modified: 2014-10-30 09:18 by mvader
