ccgx:firmware_updating
Updating firmware for CCGX and Venus GX
1. Using the right procedure (CCGX only)
Depending on the installed firmware version, the update procedure differs.
Running firmware version v1.74 or earlier? An upgrade is needed. Follow the upgrade procedure to v2.
When the device already has software version v2.00 or later, follow instructions below.
2. Update procedure when v2.00 or later is already installed
There are two ways to update the firmware:
- Update it via the internet, either manually or let it check for new updates every day
- Update it from an microSD-card or USB-stick
2.1 Direct download from the internet
2.2 microSD-card or USB-stick
Updating with a microSD-card or USB-stick is called 'Offline updating'. Use it when updating a device that is not connected to the internet.
Step 1. Download
Get the latest swu file:
Step 2. Install on an sdcard or usb stick
Store the file in the root folder of a USB stick or microSD card.
Step 3. Insert the device
Note that you will see a warning “Not using media for storing logs”. That warning can safely be ignored.
Step 4. Initiate the update
- Navigate to Settings → Firmware → Offline updates.
- Press Check for updates
- If the firmware in the microSD card or USB stick is newer than the running one “Update available” item will appear, press it to start the update process.
DISQUS Comments
ccgx/firmware_updating.1502138120.txt.gz · Last modified: 2017-08-07 22:35 by mvader
