ccgx:fischer_panda
ccgx:fischer_panda [2017-11-14 16:14] – [Requirements] mvader | ccgx:fischer_panda [2024-09-13 09:20] (current) – Removed and linked to its new home sloges | ||
- | As of [[https:// | + | The old GX - Fischer Panda generators document has been removed and is now part of the GX device manual, which can be found here: [[https:// |
- | ===== Requirements ===== | ||
- | * CCGX or Venus GX | ||
- | * Fischer Panda generator, xControl or iGenerator | ||
- | * Fischer Panda SAE J1939 CAN module (part number 0006107) | ||
- | * Fischer Panda FP-Bus to VE.Can adapter (part number 0023441) | ||
- | Fischer Panda Firmware requirements: | ||
- | * iControl (for the iGenerator): | ||
- | * iControl panel: no minimum requirement | ||
- | * xControl (for the constant speed generators): | ||
- | * xContr panel: 4V29 | ||
- | * Fischer Panda SAE J1939 CAN module: 2V05 | ||
- | * Fischer Panda three phase module: 4V0b | ||
- | ===== Connecting ===== | ||
- | ==== xControl ==== | ||
- | The schematic below shows how to connect a Fischer Panda xControl generator. | ||
- | ==== iControl ==== | ||
- | The schematic below shows how to connect a Fischer Panda iControl generator. | ||
- | ===== Menu ===== | ||
- | Once all wiring and setup has been correctly done, the Fischer Panda shows up in the device list: | ||
- | Entering that menu shows the details, like this: | ||
- | It features an on/off switch, as well as the status and the main AC parameters: voltage, current and power. Temperature, | ||
- | ===== Generator start/stop ===== | ||
- | Besides manual start/stop and monitoring, there is also an automatic start/stop menu. Which has the same wide range of options as the Generator start/stop mechanism that has been available with the relay. | ||
- | See [[ccgx: | ||
- | ===== Maintenance ===== | ||
- | To perform maintenance to the generator, stop the generator from the Fischer Panda control panel. This disables the Fischer Panda autostart feature, which ensures that the generator cannot be remotely started, e.g. by a CCGX. | ||
- | When the maintenance is completed, make sure to enable the autostart feature again. You can do this on the Fischer Panda control panel in the menu '' | ||
- | ===== Troubleshooting ===== | ||
- | === I've set the mode of the genset to ' | ||
- | Make sure the Fischer Panda autostart feature is on, this allows the CCGX control the remote on/off of the genset. You can find this option on the control panel in the menu '' | ||
- | If you're manually trying to start the genset, a toast message appears with the text '' | ||
- | If the generator auto start/stop is enabled, it will show error ''# | ||
- | ===== Disqus ===== | ||
ccgx/fischer_panda.1510672487.txt.gz · Last modified: 2017-11-14 16:14 by mvader
