ccgx:fischer_panda
ccgx:fischer_panda [2019-07-11 08:50] – [Menu] mvader | ccgx:fischer_panda [2024-09-13 09:20] (current) – Removed and linked to its new home sloges | ||
- | Beginning with the release of [[https:// | + | The old GX - Fischer Panda generators document has been removed and is now part of the GX device manual, which can be found here: [[https:// |
- | ===== Requirements ===== | + | |
- | * CCGX or Venus GX | + | |
- | * Fischer Panda generator, xControl or iGenerator | + | |
- | * Fischer Panda SAE J1939 CAN module (part number 0006107) | + | |
- | * Fischer Panda FP-Bus to VE.Can adapter (part number 0023441) | + | |
- | Fischer Panda Firmware requirements: | ||
- | * iControl (for the iGenerator): | ||
- | * iControl panel: no minimum requirement | ||
- | * xControl (for the constant speed generators): | ||
- | * xContr panel: 4V29 | ||
- | * Fischer Panda SAE J1939 CAN module: 2V05 | ||
- | * Fischer Panda three phase module: 4V0b | ||
- | ===== Connecting ===== | ||
- | ==== xControl ==== | ||
- | The schematic below shows how to connect a Fischer Panda xControl generator. | ||
- | ==== iControl ==== | ||
- | The schematic below shows how to connect a Fischer Panda iControl generator. | ||
- | **:!: Important: Operation of the generator is only possible and allowed when the xControl or the iControl panel is switched on. ** | ||
- | ===== GX Device ===== | ||
- | In Settings -> Services, the selected canbus profile must be one that says NMEA2000. (The default). | ||
- | When all wiring is complete and the setup has been correctly carried-out, | ||
- | Entering the Fischer Panda device on the menu reveals a page like this: | ||
- | Notice that it features an on/off switch as well as displaying status information, | ||
- | Engine temperature, | ||
- | ===== Generator start/stop ===== | ||
- | In addition to the manual start/stop and monitoring, there is also an automatic start/stop feature. This has the same comprehensive range of options as the Generator start/stop feature associated with the CCGX relay. | ||
- | See [[ccgx: | ||
- | ===== Maintenance ===== | ||
- | Whenever performing maintenance on the generator, be sure to //stop// the generator from the Fischer Panda control panel. This will disable the Fischer Panda autostart feature, and ensures that the generator cannot be remotely started - by a CCGX, for example. | ||
- | When the maintenance is completed, make sure you enable the autostart feature again. You can do this on the Fischer Panda control panel in the menu '' | ||
- | ===== Troubleshooting ===== | ||
- | === I've set the mode of the genset to ' | ||
- | Make sure the Fischer Panda autostart feature is on, this allows the CCGX control the remote on/off of the genset. You can find this option on the control panel in the menu '' | ||
- | If you're manually trying to start the genset, a toast message appears with the text '' | ||
- | If the generator auto start/stop is enabled, it will show error ''# | ||
- | ~~DISQUS~~ | ||
ccgx/fischer_panda.1562827844.txt.gz · Last modified: 2019-07-11 08:50 by mvader
