Pump auto start/stop with Color Control GX
Introduction
The CCGX internal relay can be used to start a pump. With this functionality you can open or close the relay based on a tank level.
Mobile/automotive overview
On this overview you can easily see all the attached tank sensors levels and control a pump. It is also posible to change Multi/Quattro AC current limit and mode when available.
Enable pump start/stop
To enable the pump start/stop functionality go to Settings→ Relay and set the function to “Tank pump”, once enabled the tank pump configuration page will be available.
Configuration
Pump start/stop configuration page is located in Settings → Tank pump.
Mode:
- Auto: Start and stop the pump based on level settings
- On: Pump always on
- Off: Pump always off
Tank sensor: Select which sensor will be monitored to start/stop the pump when the “Auto” mode is enabled.
Start level: When the tank level reaches this value the pump will be started.
Stop level: When the tank level reaches this value the pump will be stopped.
