ccgx:root_access
ccgx:root_access [2024-01-09 14:09] – consmetic jhofsteeccgx:root_access [2024-12-03 11:17] (current) – [3.1 Set access level to Superuser] mvader
Line 33: Line 33:
 ==== 3.1 Set access level to Superuser ==== ==== 3.1 Set access level to Superuser ====
-To set the root password, first set the access level to Superuser:+To set the root password, first set the access level to Superuser
   - Go to Settings, General   - Go to Settings, General
   - Set the Access Level to User and installer, the password is ''ZZZ''   - Set the Access Level to User and installer, the password is ''ZZZ''
   - Highlight Access Level (don't open the select page, ie. make sure you are in the General Page, not the Access Level page)   - Highlight Access Level (don't open the select page, ie. make sure you are in the General Page, not the Access Level page)
-  - Press and hold the right button of the center pad until you see the Access Level change to Superuser. Note: when working from the Remote Console, you need to use the right key on your keyboard. Pressing and holding the right button with your mouse won't work.+  - Press and hold the right button of the center pad until you see the Access Level change to Superuser. Note: when working from the Remote Console using the Classic UI, you need to use the right key on your keyboard. Pressing and holding the right button with your mouse won't work. When using the New UI, select, drag down and hold down the entire list of General menu entries for five seconds, and until you see the Access level change to super user
 Now you have access to the super user features. Now you have access to the super user features.
Line 90: Line 91:
 If the files ''/data/rcS.local'' or ''/data/rc.local'' exists, they will be called early (rcS) and late (rc) during startup. These scripts will survive upgrades and can be used by customers to start their own custom software. Implementation details in [[https://github.com/victronenergy/meta-victronenergy/commit/2dbd16c560ff7cdf70b1d676c0616013169c7484|this commit]]. If the files ''/data/rcS.local'' or ''/data/rc.local'' exists, they will be called early (rcS) and late (rc) during startup. These scripts will survive upgrades and can be used by customers to start their own custom software. Implementation details in [[https://github.com/victronenergy/meta-victronenergy/commit/2dbd16c560ff7cdf70b1d676c0616013169c7484|this commit]].
-Also if ''venus-data.{tar.gz,tgz,zip}'' is found on removable storage (usb stick, sd-card) when booting, it will be unpacked into /data. Implementation details in [[https://github.com/victronenergy/meta-victronenergy/commit/469760fef4ed2ee977f482c997ac24c2678222c5|this commit]]. Added per Venus v2.30~28. Use this to for example make a USB stick that installs the modifications.+Also if ''venus-data.*.{tar.gz,tgz,zip}'' is found on removable storage (usb stick, sd-card) when booting, it will be unpacked into /data. Implementation details in [[https://github.com/victronenergy/meta-victronenergy/commit/469760fef4ed2ee977f482c997ac24c2678222c5|this commit]]. Added per Venus v2.30~28. Use this to for example make a USB stick that installs the modifications. You can combine multiple files on the device; they will be run in alphabetical order.
 That venus-data file has one extra feature: if the archive contains ''rc/*'' files, it will extract those first. And if there is a file called ''rc/pre-hook.sh'' it will run this before unpacking the rest of the archive. Similarly, if there is a file called ''rc/post-hook.sh'', then that file will run this after the unpacking of the archive. For details, read the code in the ''/etc/rc5.d/S30update-data.sh'' file. That venus-data file has one extra feature: if the archive contains ''rc/*'' files, it will extract those first. And if there is a file called ''rc/pre-hook.sh'' it will run this before unpacking the rest of the archive. Similarly, if there is a file called ''rc/post-hook.sh'', then that file will run this after the unpacking of the archive. For details, read the code in the ''/etc/rc5.d/S30update-data.sh'' file.
 +You can draw further inspiration from [[https://github.com/victronenergy/meta-victronenergy/tree/master/meta-venus/scripts|here]], where the code resides to generate files for making backups of the ''/data'' partition, resetting Node-RED and SignalK and more scripts.
 You can test the 'update' with  You can test the 'update' with
Line 117: Line 120:
 === 4.2.2 Read-only rootfs === === 4.2.2 Read-only rootfs ===
-By default, the rootfs is mounted read only. Also, by default, it only has 5% of free space.+By default, the rootfs is mounted read only. Also, by default, it only has 5% of free space, while the partition in which its installed is actually larger.
-The solution is to run ''/opt/victronenergy/swupdate-scripts/resize2fs.sh''.+The recommended method to **(a)** mount it as read/write, and **(b)** expand it to use all of the available space in its partition, is by running ''/opt/victronenergy/swupdate-scripts/resize2fs.sh''.
-Further details in the next section.+Here is a short overview of the three ways mount the rootfs as read/write:
 +  * //temporally//: issue the command ''mount -o remount,rw /'' (which holds until the next reboot or issueing ''mount -o remount,ro /''
 +  * //semi-permanent//: issue the command ''/opt/victronenergy/swupdate-scripts/remount-rw.sh'' (which holds until the next firmware update)
 +  * //permanent//: adding one of the above commands to ''/data/rc.local'' (which holds permanently)
 === 4.2.3 Always prevent running out of diskspace === === 4.2.3 Always prevent running out of diskspace ===
Line 156: Line 163:
 For more advanced features please check the manual page of [[https://man7.org/linux/man-pages/man1/diff.1.html|diff]] and [[https://man7.org/linux/man-pages/man1/patch.1.html|patch]]. For more advanced features please check the manual page of [[https://man7.org/linux/man-pages/man1/diff.1.html|diff]] and [[https://man7.org/linux/man-pages/man1/patch.1.html|patch]].
 +In this thread, there is an example of how to make a patch file to change a certain setting in the GX, and how to apply that at boot. To make it survive a firmware update:
 +https://community.victronenergy.com/idea/201826/lets-define-a-local-ntp-server.html
 ==== 4.4 Adding or modifying services ==== ==== 4.4 Adding or modifying services ====
Line 166: Line 176:
 ''/service''. ''/service''.
-By default the root filesystem of Venus is read-only. There are three ways to change that: +Further details herehttps://github.com/victronenergy/venus/wiki/howto-add-a-driver-to-Venus#installing-a-driver-that-doesnt-depend-on-a-serial-port
-  * //temporally//issue the command ''mount -o remount,rw /'' (which holds until the next reboot or issueing ''mount -o remount,ro /''+
-  * //semi-permanent//: issue the command ''/opt/victronenergy/swupdate-scripts/remount-rw.sh'' (which holds until the next firmware update) +
-  * //permanent//: adding one of the above commands to ''/data/rc.local'' (which holds permanently)+
 ===== 5. Hardening a GX device ===== ===== 5. Hardening a GX device =====
Line 349: Line 355:
 Getting to console on the Ekrano GX is not that easy. The pins are located between the network and USB connector on the back of the device. Getting to console on the Ekrano GX is not that easy. The pins are located between the network and USB connector on the back of the device.
-  - 1: Black: ground  +  - Black: ground
-  - 2: NC +  - NC
-  - 3: NC +  - NC
-  - 4: Green: RX of the Ekrano GX - connect to TX on your cable +  - Green: RX of the Ekrano GX - connect to TX on your cable
-  - 5: White: TX of the Ekrano GX - connect to RX on your cable +  - White: TX of the Ekrano GX - connect to RX on your cable
-  - 6: NC+  - NC
 {{ :ccgx:ekrano-console.jpg?300 |}} {{ :ccgx:ekrano-console.jpg?300 |}}
ccgx/root_access.1704805798.txt.gz · Last modified: 2024-01-09 14:09 by jhofstee
