Venus OS: Root Access
Introduction
This document explains how to access a GX device via SSH, or straight on the Serial Console, with the root user. It also covers customizing and hardening the Venus GX device.
This document is part of the Venus OS developer documentation. The main document is the Venus OS wiki on github.
Do note that, while we try to maintain to provide all mentioned functionality in this document, the used commands and functionality may change with future updates.
Warning about modifying the rootfs
1. Your changes can be lost during a firmware update Note that additions made to the rootfs are not safe during an update, as the complete rootfs is replaced during an update.
Of course it is always possible to disable automatic firmware updates. Also there is a data partition (/data), which will be left alone in the image updates. More details below.
2. It is possible to brick your GX device
For those unfamiliar with the term: Bricking means rendering it useless and unrecoverable. Chances of this are small (depending on what you do), but its certainly possible. And if not fully bricked, then at least in a state from which there is no documentation nor support on how to recover.
Note that a solution to this is to do Venus OS experiments on a RaspberryPi rather than a real GX device. The advantage of a raspberrypi is that you can always start from scratch, by re-imaging the sdcard. And the other is that it (the pi) is a low cost device. more information on that.
The factory reset procedure, as documented in the normal user manuals of the GX devices, removes everything from the data partition, except for the factory installed files. This will recover from issues caused by problems on the data partition, such as it being full or invalid settings or custom scripts.
Be careful that it is possible to make changes from which its not possible to recover. For example:
- if you accidentally remove files crucial for the boot process, then the device won’t boot anymore. And above mentioned factory reset feature depends on at least certain parts of the system booting up properly. More specifically, it depends on the linux init process.
- if you remove the files in /data/venus, then -depending on the production date- you might have to restore those manually which might require serial console access. See below. Why does this depend on the production date? Thats because somewhere in 2021 we started writing all factory data to a different place (an eeprom) so that its more robust.
Root access
Set access level to Superuser
To set the root password, first set the access level to Superuser:
- Go to Settings, General
- Set the Access Level to User and installer, the password is
ZZZ
- Highlight Access Level (don't open the select page, ie. make sure you are in the General Page, not the Access Level page)
- Press and hold the right button of the center pad until you see the Access Level change to Superuser. Note: when working from the Remote Console, you need to use the right key on your keyboard. Pressing and holding the right button with your mouse won't work.
Now you have access to the super user features.
Note that on a touchscreen, such as a Cerbo GX + GX Touch, there is no “right button”. Instead, drag the menu down and hold it down for five seconds. Or, use Remote Console.
Create a temporary root password
Go to Settings → General → Set root password. And create a temporary root password.
Note that, for firmware version v2.00 and later, the root password will be reset by a firmware update. The reason is that the passwd file is on the rootfs, which is fully replaced by an update. More info here.
Our advice is to create a complex root password. But use it to login only the first time, and then install a public ssh key(s). Thereafter login with the keys. If key authentication works, you can also
safely delete the root password afterwards (passwd –delete root
Enable sshd and log in
To login via ssh, enable SSH on LAN (Settings → General). On Venus versions before v2.40, you need to enable Remote Support, which also enables sshd. More info on Remote Support here.
To the login, enter the ip address of the GX device in a ssh client. Most Linux and Mac users will simply do this from the command line:
ssh root@192.168.1.23
And a very commonly used client for Windows is Putty. For more info, look around on the Internet, there is plenty information available.
Working with ssh keys
Using a ssh key for authentication, instead of a root password, has the advantage that it isn't lost during a firmware update. The keys are stored on the /data partition.
First set the root password (once), use that to login, and then copy a public ssh key to ~/.ssh/authorized_keys
sshd works with three authorized keys files:
← you can use this freely~/.ssh/authorized_keys2
/usr/share/support-keys/authorized_keys
The third file contains the keys we use for Remote Support login.
Play time! Start executing commands
Customizing a Venus GX device
Our recommended method to customize Venus is by making .patch
files and applying
them via either the /data/rcS.local
or the /data/rc.local
script. This
will require some maintenance, but is likely not to cost too much time and effort.
Hooks to install/run own code at boot
Everything, except for information on /data
, will be wiped after an update.
Therefore, the trick to make changes & modifications survive an update, is to put your (patch)files on /data
, make them be (re-)installed automatically on startup. This section describes how to do that.
If the files /data/rcS.local
or /data/rc.local
exists, they will be called early (rcS) and late (rc) during startup. These scripts will survive upgrades and can be used by customers to start their own custom software. Implementation details in this commit.
Also if venus-data.{tar.gz,tgz,zip}
is found on removable storage (usb stick, sd-card) when booting, it will be unpacked into /data. Implementation details in this commit. Added per Venus v2.30~28.
There is an extra feature. If the archive
contains the rc/*
files, it will extract those first and, if the file is
called rc/pre-hook.sh
it will run this before the unpacking of the archive.
If it is called rc/post-hook.sh
it will run this after the unpacking of the
archive. This is all handled in the /etc/rc5.d/S30update-data.sh
file.
The advice is to put unified patches in the venus-data.tgz
archive that
holds patches against the services in /opt/victronenergy/services/
that you
want to patch.
You can test the 'update' with
/opt/victronenergy/swupdate-scripts/check-updates.sh -update -force
which will install the same version again, but in the other rootfs.
For details of the used update mechanism, see here: https://github.com/victronenergy/venus/wiki/swupdate-project
Partitions, read-only rootfs and available disk space
On a GX Device, there are three partitions that matter:
- rootfs partition one
- rootfs partition two
- the data partition
One active rootfs at a time
Only one of the two rootfs partitions will be in use at time. During a firmware update, the new firmware is installed on the other one; and once finished the subsequent reboot will reboot the device onto that other partition.
The data partition is not touched during a firmware update, except maybe some migration scripts that run at boot.
Always prevent running out of diskspace
When doing modifications, make sure both the data partition and the rootfs do not run out of space. We don't design or test for that situation.
With regards to the size of the data partition, thats easy to check using the df
utility. But not so for the rootfs:
After logging into a GX device, and checking the free disk space on the rootfs(! thats not the data partition), you might get a bit disappointed at first. Don't worry about that, there will always be only 5% of free space, but thats not the actual free space:
The reason for this is that a firmware update replaces the full filesystem on the rootfs, as an image. And its then not expanded to the full available space of the partition reserved for the rootfs.
To expand it, run /opt/victronenergy/swupdate-scripts/resize2fs.sh
. It will expand the filesystem to use all of the available space.
Also this remounts that rootfs as read-write.
For actual available diskspace on our GX Devices, see https://github.com/victronenergy/venus/wiki/machines.
To see what resize2fs.sh
is doing, without having to log into your Venus OS, see it also here.
Note that a firmware update will replace all of the rootfs, as also explained above. Which implies that you'll need to run resize2fs.sh
again after doing a firmware update.
Adding or modifying services
Changes made to /service
will not survive a reboot. The
reason is the /etc/rcS.d/S10overlays.sh
script, which copies over the files
from /opt/victronenergy/service/*
to /run/overlay/service
and bind mounts
that under /service
. So in order to have changes survive a reboot, you need
to change the service under /opt/victronenergy/service/*
instead of under
/service
By default the root filesystem of Venus is read-only. There are three ways to change that:
- temporally: issue the command
mount -o remount,rw /
(which holds until the next reboot or issueingmount -o remount,ro /
) - semi-permanent: issue the command
/opt/victronenergy/swupdate-scripts/remount-rw.sh
(which holds until the next firmware update) - permanent: adding one of the above commands to
/data/rc.local
(which holds permanently)
Hardening a Venus GX device
Limit physical access to the device
The first thing to keep in mind is that we as Victron Energy always want an end-user with physical access to the device to be able to gain access to the device again after he has himself accidentally locked out.
So the best solution to keep people from tampering with a Venus device is to block physical access to the device. We do not give specific recommendations regarding that, but a compact server rack with key protection seems to be safe enough in most cases. You can also add an alarm on the digital input of the Cerbo that will ring as soon as the door of the rack opens.
People with enough time, knowledge and an angle grinder on their hands will always be able to get in. But you will probably be able to tell if people did get access to the device. Also keep in mind that extra physical security will also give extra hassle for the people that are allowed to get the physical access to the device. They will need to get the key from a security officer first. Once setup correctly, there is no need to physically access a GX device after installing. So the key could and should be kept off-site.
Disable touch on the attached screen
Apart for physical access restrictions, the software part of the device can
also be restricted. As soon as an intruder gains console access, he can also
startup ssh on the LAN and temporally change the root password. With the new
dbus setting /Settings/Gui/TouchEnabled
under com.victronenergy.settings
it
is possible to lock the touch part of the screen from being used. This option
is available from v3.00~15 and on wards.
Limiting digital access
When securing the device, it is also advised to disable the Wi-Fi access point, bluetooth and other non-essential services on the device. The below list should be treated as a starting point and can be extended up on:
- Disable remote touch control
- Disable bluetooth
- Disable Wi-Fi Access point
- Set Access level to User
- Disable LAN SSH
- Disable LAN remote console (VNC)
If you have multiple devices to harden, it is comfortable to automate the process in
a scriptable way. The current way of changing these settings is by using the dbus
command. For
the above settings you could script it as:
#!/bin/bash items=" Disable remote touch control;com.victronenergy.settings;/Settings/Gui/TouchEnabled;0 Disable bluetooth;com.victronenergy.settings;/Settings/Services/Bluetooth;0 Disable Wi-Fi AP;com.victronenergy.settings;/Settings/Services/AccessPoint;0 Set access level to User;com.victronenergy.settings;/Settings/System/AccessLevel;0 Disable LAN ssh;com.victronenergy.settings;/Settings/System/SSHLocal;0 Disable LAN Remote console (VNC);com.victronenergy.settings;/Settings/System/VncLocal;0 " IFS=' ' for item in ${items} do IFS=';' read -r description service path value <<< ${item} echo "# ${description}" dbus -y ${service} ${path} SetValue ${value} done
There are a lot more settings that can be adjusted this way. Easiest is using
dbus-spy
to check which ones you find interesting. Instead of disabling services,
you might want to enable some things too. Just replace the 0
with a 1
to do
that.
Installing a tamper alarm
By using the digital input(s) of the GX device, you can set the digital inputs as “Burglar alarm”, which can be used to be alerted on tampering events.
Depending on the need, you might want to switch to a silent alarm under General → Audible alarm
(service: com.victronenergy.settings
, path: /Settings/Alarm/Audible
You can decide whether the input should be treated as an alarm condition, whether the labels should be inverted, and whether the logical levels should be inverted.
- To swap the labels attached to the alarm, set Inverted to on.
- If a logical low input (0V) should be considered a positive condition, set Inverted alarm logic to on.
Hardening multiple devices
If you have a lot of Venus devices to modify, probably the easiest way is to
start with using a per-device specific password for the remote console, which
only you can can generate. Combining that with a substring from something like
/opt/victronenergy/venus-eeprom/eeprom –show serial-number | sha256sum
is a
fairly secure start.
Later replace that by something more strong and store it in your vault. Use the USB stick to put your public ssh keys on the GX device so you can gain remote access.
Connecting on the serial console
The serial console offers a straight connection from your computer. Not relying on TCP or anything else.
Its an alternative to connecting to the commandline over ssh.
Connecting to the serial console requires a USB interface, ie a USB to serial cable with proper pin-out. For example this one: https://www.adafruit.com/product/954.
The serial consoles on all GX devices are configured to 115200 baud.
Serial console on GX device
All GX Devices have a dedicated serial console, except for the CCGX. Therefor its documented on a separate page:
Serial Console on Cerbo GX
The serial console is located on the CPU board, header JP201. GND is pin 1, RX and TX are pins 4 and 5. Here is a picture showing a ADA Fruit Serial Console cable connected to it.
Make sure not to connect the red wire.
Serial Console on Venus GX
The serial console is located on the base-board, and can be accessed through the slot between that board and the Ethernet connector on the beaglebone-board.
White: TX of the Beaglebone - connect to RX on your cable Black: ground Green: RX of the Beaglebone - connect to TX on your cable
Here is a picture showing how, also using the adafruit serial console cable as referenced above:
Serial console on GX Card / Nanopi
The GX Card is the PCBA inside the MultiPlus-II GX and EasySolar-II GX product ranges. This photo shows the card, when unmounted from these inverter/chargers.
Maybe the pins are also accessible without dismantling it, maybe not. Note that all this is at your own risk, as everything on these pages is.
The serial console is the pinheader on the right of the photo. In the photo, there is an Adafruit serial console cable connected.
Serial console on Octo GX
The serial console is located on the base-board, and can be accessed with the top-board unmounted. With the serial console cable connected the top-board can be put back on again.
- Black: ground
- NC
- NC
- Green: RX of the Beaglecore - connect to TX on your cable
- White: TX of the Beaglecore - connect to RX on your cable
- NC
