ACin ignore timer using CCGX Generator auto start/stop example
Note that below functionality requires Color Control GX version v1.30 or newer. See here for update instructions.
Introduction
The CCGX internal relay can be used to start a generator. The relay can also be used to set other things. For example in combination with an assistant and the use of an AUX input it can be used as a timer to ignore ACin on set times to make use of 'off peak tarrifs'. The multi/Quattro does not have a real time clock so the time is not very exact. The ColorControl does have an internal clock. Exact switching can be done.
Enable the start/stop function
For all the information on how to enable this go to this page: https://www.victronenergy.com/live/ccgx:generator_start_stop
- Generator state: Condition that is currently keeping the generator running.
Settings
- Conditions: See Conditions
- Periodic test run
Test run condition
Allows you to program a periodical test run.
- Test run interval: Test run will be performed periodically based on this setting
- Skip test run if has been running for: The test will be skipped if during the test run interval the generator was running at least the number of hours set on this setting.
- Test interval start date: The interval count will start based on this date, this setting can be set in the future and the interval will be ignored till the set date is reached.
- Start time: Time of day in which the generator will start
- Test duration: Duration of the test
