Lynx DC distribution system
The lynx system is a modular DC bus bar system used to connect batteries, DC equipment and provide fusing and battery monitoring. It consists of the following modules:
- Lynx Power In
- Lynx Shunt
- Lynx Distributor
Lynx Power in
The lynx power in module is used to connect batteries. It contains a negative and positive DC bus-bar with M8 bolts to connect batteries cables to.
Lynx shunt
The Lynx shunt contains a fuse in the positive bus-bar and a shunt in the negative bus-bar. It also contains a battery monitor electronics. The Lynx shunt can send via the VE.CAN bus battery motoring information to a CCGX or VGX or to a third party can bus monitoring system, such as a NMEA2000 (check with Johannes).
The Lynx shunt is available in two models:
- VE.CAN
- VE.NET (depreciated)
CIP140325000 - Fuse CNN 325A/80V for Lynx shunt
cNN fuses by Little fuse see:
Lynx Distributor
uses MEGA fuses (please note that the MEGA fuse is only rated to 36Volt
===== Lynx Distributor =====
Contain Mega Fuses and a led for each fuse to indicate if fuse is blown green led = fuse is okay red led = blown fuse
Lynx info
MEGA Fuse
Mega fuse info
