drafts:dynamic_ess
drafts:dynamic_ess [2024-05-15 08:38] – [Step 1: System] dfaber | drafts:dynamic_ess [2024-11-09 15:16] (current) – [Q: My providers changes price at the half hour instead of the full hour] aleximb | ||
====== Dynamic ESS - manual ====== | ====== Dynamic ESS - manual ====== | ||
- | ===== What is Dynamic ESS? ===== | + | ===== Smarter energy, bigger savings with Dynamic ESS ===== |
- | Dynamic ESS is an algorithm that aims to minimise the costs made on the grid and battery: | + | With Dynamic ESS, your Victron system becomes even smarter. It optimizes your battery' |
- | * By scheduling | + | |
- | * While taking grid limitations, battery specifications | + | |
- | * When it can, it also considers the consumption and solar yield forecasts when scheduling. | + | |
- | Also check these community posts for remarks and further troubleshooting: | + | Whether you're managing a home or a larger installation, |
- | - [[https:// | + | |
- | ==== Can I use it? | Eligibility Criteria ==== | + | If you have dynamic energy rates or off-peak energy prices, start configuring now to take full advantage of your setup! |
- | Dynamic ESS is only eligible for the installations which fits the following criteria: | + | {{:drafts: |
- | * Be an ESS; | + | ==== Two modes: green or trade ==== |
- | * Not use Generator connection outside of power outages; | + | |
- | * Run Venus OS v3.30 (or newer) | + | |
- | For best results: | + | We offer two operating modes to cater to different preferences for managing |
- | * Have a variable or dynamic | + | |
- | * Use a supported | + | |
- | Note: | + | === Green Mode === |
- | * Only the dynamic energy contracts of the following countries are supported for day ahead prices: //Austria, Belgium, Bulgaria, Croatia, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Italy, Latvia, Lithuania, Luxembourg, Montenegro, Netherlands, | + | |
- | * If you have fixed prices (which may differ weekends/ | + | |
+ | Sell surplus solar power back to the grid after covering your consumption and charging the battery. | ||
+ | Reserve battery energy for your own use. | ||
+ | Charge your battery when prices are low to save more. | ||
- | ===== How can I get started? | Configuration ===== | + | === Trade Mode === |
+ | Always sell surplus solar power back to the grid. | ||
+ | Use the battery energy to take advantage of trading opportunities. | ||
+ | Charge your battery when it’s most beneficial for trading. | ||
- | {{: | + | Green Mode is ideal for those who prefer a safer, more predictable approach, while Trade Mode is perfect for those looking to maximize their gains through trading. You can always switch between modes to find what works best for you. |
- | To get started, you need to provide VRM with the necessary configuration Dynamic ESS requires. To do this, you can navigate to //Settings -> Dynamic ESS// and follow the instructions on the page. This should take 15 minutes of your time. | ||
- | From the page, you can configure the settings | + | ====== Let’s get started ====== |
+ | Setting up Dynamic ESS happens | ||
- | Also make sure that you have set the location of your device (so we can do the correct solar forecast) and have " | ||
==== Step 1: System ==== | ==== Step 1: System ==== | ||
- | First thing we need to know is whether | + | First, confirm |
- | Note that this is part is setting | + | Note: This step defines |
- | Then you need to set the operating mode: | + | {{:drafts: |
- | * Green mode: | + | ==== Step 2: Battery information ==== |
- | * Only sell surplus solar back to the grid after consumption and battery charging | + | |
- | * Energy in battery is reserved for consumption | + | |
- | * Charge battery when prices are low | + | |
- | * Trade mode: | + | |
- | * Always sells surplus solar back to the grid | + | |
- | * Energy in battery is used to trade | + | |
- | * Charge battery when it is beneficial for trading | + | |
- | You can always adjust this mode at a later stage, so pick the one that best suits your needs. | + | Next, provide key details about your battery: |
- | ==== Step 2: Battery | + | * Battery Capacity – To calculate what 1% of the battery' |
+ | * Maximum Charge and Discharge Power – This determines how much energy the battery can handle for charging or discharging in an hour. | ||
+ | * Battery | ||
- | Then we need to know information on your battery: | + | To calculate |
- | * //Battery Energy Capacity// - In order to calculate how much 1% of SOC of the battery | + | |
- | * //Battery costs// - Battery costs indicate how expensive it is to use it for charging and discharging, | + | |
- | costs for buying the battery in € / (charging | + | Battery cost (€) / (Number of charge |
- | One battery charge cycle equals full battery charged to 100% and fully used to 0%. If you only use half of the battery power, then recharge it and repeat it the following day — it will also count as one charge cycle instead of two. The number of charging cycles is a number that differs per brand. The battery costs is usually somewhere between € 0.02 and € 0.06 /kWh. | + | |
- | Some feedback of users is that they don’t care about the battery costs, as they already paid for it, so technically there’s no additional costs to charge it. In that case we still advise to put a small amount in as battery costs. E.g. 0.01 €/kWh. | + | |
- | In order to make the calculation for you, you can also fill out the invoiced | + | For example, if your battery cost €2,000, has a capacity of 10 kWh, and supports 6,000 charge |
- | * //Configure Dynamic ESS SoC// - The Minimum Dynamic ESS SOC determines when Dynamic ESS will stop selling to the grid to leave enough energy for self-consumption. By not setting the Minimum Dynamic ESS SOC separately, Dynamic ESS will use the Minimum SOC instead. | + | |
- | If you set the min soc using the slider, then save the form, it will not have been logged to lastLogData yet. Thus the old value will be used in the schedule. Installation will handle this, and the next hour the correct value will be used. | + | 2000 / (6000 * 10) = € 0.03/kWh |
- | ==== Step 3 and 4: Buy and sell prices ==== | + | * Charge/ |
- | For buying and selling you can either have dynamic (day ahead) prices or fixed prices (which can differ at different times / weekend vs weekdays). So first you need to fill out if you have fixed or dynamic pricing. | + | {{: |
- | === Dynamic prices | + | ==== Steps 3 & 4: Buying and Selling Prices ==== |
- | Each country and provider uses their own formula for pricing. As the system grows, we will have more and more pre-filled out formula' | + | For energy transactions, you can use either **dynamic** (day-ahead) prices or **fixed** prices that may vary by time of day or between weekdays and weekends. Indicate whether you're using fixed or dynamic pricing. You can find these rates in your energy contract. |
- | Unfortunately getting | + | For the UK, Spain and France, Dynamic ESS provides an out of the box connection |
- | We can give you some general rules and show you what other users have filled out as their formula. With these instructions, | + | |
- | Generalised over countries and providers a formula typically something like: // | + | === Your Dynamic Price Formula Made Easy === |
- | * p - the dynamic | + | Getting your dynamic |
- | * € 0.02 - energy | + | |
- | * € 0.13 - DSO working price + contributions/ | + | |
- | * 21% - tax | + | |
- | The sell price formula looks often identical and in common cases looks something like (// | + | When you sell energy back to the grid, you get the base rate from your energy provider. But when you buy energy, you also pay VAT and an extra charge of 11 cents per kWh. |
- | If the provider takes a 15 % percentage of the day ahead buy price and the taxes are 6%, the formula becomes: //( p * 1.15 ) * 1.06//. | + | **Selling Energy**: Your selling formula |
- | This is a bit weird, because in case of negative buy prices, the provider is going to pay you extra for all of the energy. Knowing providers, this is quite unlikely. So the more plausible formula becomes: | + | |
- | //(p + abs(p * 0.15)) * 1.06//, which makes sure that the provider takes its share, even when the prices are negative. | + | |
- | Also note that, if you don't use euro' | + | |
- | You can also get some ideas from [[https://github.com/ | + | **Buying Energy**: Your buying formula is: P * 1.21 + 0.11 |
- | === Fixed prices === | + | If you’re not sure about your rates, start with a simple P for the price. You can compare the numbers in VRM with those in your energy provider' |
- | If you have a fixed prices contract, you can still have different prices at different moments of the day. In some cases you can have different prices between weekdays and weekends. So that is the first question to answer. | + | {{: |
- | Then, you can fill out the price per hour (more granularity is currently not possible). | ||
==== Step 5: Confirmation ==== | ==== Step 5: Confirmation ==== | ||
- | In the final step you see the filled out values summarised. If you need to make adjustments, | + | In the final step, review a summary of all the settings |
- | Now navigate to the installation’s Dashboard and click the button shown below to open the Controls menu. Under the ESS section, you will find Dynamic ESS controls. | + | ===== Tracking your daily energy schedule ===== |
- | {{:drafts:controls-screen.png? | + | Once you've configured Dynamic ESS, a new section will appear at the bottom of your VRM dashboard. This section displays a graph showing today' |
- | ==== What's next? | After configuration ==== | ||
- | As the configuration flow points out, you can navigate to the // | ||
- | {{ : | + | ===== Want to know more? ===== |
- | The //Auto// (green) mode is the usual mode in which Dynamic ESS should operate. If you want to disable | + | For more information on Dynamic ESS, check out our frequently asked questions. For some countries, |
- | The state of Dynamic ESS will also show on the dashboard, just after the title. As a side note: If you run [[https:// | ||
- | ====== Operational ====== | ||
- | ==== Data Visualisations ==== | ||
- | Once operational, | + | ===== For Victron installers ===== |
- | {{ : | + | As a Victron device installer, Dynamic ESS allows you to offer enhanced value to your clients while unlocking new sales opportunities. By intelligently optimizing battery charging and discharging based on dynamic electricity prices, Dynamic ESS helps users achieve significant cost savings. |
- | On the left side of the vertical line, you see the recorded values. On the right side of the line it shows the solar forecast, the consumption forecast | + | These savings can be further amplified with larger battery capacities. As customers see the financial benefits |
- | By clicking on the legend, you can enable or disable shown data sets in the graph. | ||
- | Below you first find a summary on the totals for the day and then there are three tabs which visualise: | ||
- | * Costs and earnings made as a result of Dynamic ESS usage; | ||
- | * Schedule of battery and grid usage; | ||
- | * All energy factors which are taken into account when scheduling | ||
- | === Costs and earnings === | ||
- | This tab begins with a summary that compares the system using Dynamic ESS with the system using regular ESS. | ||
- | === Schedule === | ||
- | The prices graph is available on both this tab and the //Energy// tab. It shows the buy and sell prices per hour. | ||
- | The usage graph shows the energy usage of the grid and of the battery in kWh. | ||
- | === Energy === | ||
- | The prices and graph is the same one as on the // | ||
- | Then there is the energy graph, which summaries everything the system has done and is planning for. | ||
- | ==== Warm-up period ==== | ||
- | Dynamic ESS uses consumption and solar yield forecasts to schedule ahead, when the forecasts are available. Depending on the historical data available prior, the accuracy of these forecasts can vary. As it stands now, optimal consumption forecasts need 28 days of past consumption data and optimal solar yield forecasts need 28 days of past solar data. Thus, if there is not enough data the forecasts might be suboptimal which makes the performance of Dynamic ESS suboptimal. However, despite lower accuracy in forecasts, turning Dynamic ESS on in this period is still more cost-efficient and it gets better every day until it reaches its optimal state after 28 days of warm-up period. | ||
- | ==== Unexpected behaviour? ==== | ||
- | It is possible that you deem the behavior of Dynamic ESS to be unexpected or suboptimal. Depending on when it happens, there are two possible causes: | ||
- | * If the suboptimal scheduling is in the future plan, it is probably due to the configurations set by the user. For instance, battery costs being high leads to limited usage of the battery. | ||
- | * If the suboptimal scheduling is in the past, then it is mostly due to the inaccuracies that come from consumption or solar yield forecasts. It is important to note forecasting will always come with its inaccuracies and even with these inaccuracies at distinct hours, Dynamic ESS minimizes costs compared to Default ESS mode in the longer run. | ||
- | * Make sure you have the formula' | ||
- | You might also want to read the chapter on [[# | ||
- | If you feel like the behavior that you are observing is not explained by above points and you cannot find the answer in the [[# | ||
- | ====== Implementation ====== | ||
- | This part of the documentation is about how the system works on a technical level, as it might help troubleshooting for the more advanced users. The system works by taking all of the available data (day ahead pricing/ | ||
- | The planning is being converted into a target state of charge for the batteries per hour and whether or not the system can feed in to the grid during that hour. If the target SOC is lower than the current SOC, the batteries discharge (either to consumption or the grid; if feed-in is allowed), if the target SOC is higher than the current SOC the batteries get charged (either from solar or from grid). The upcoming four hours schedules are put into the GX device via the two-way VRM communication channel. On the dbus these schedules can be found under `com.victronenergy.settings`, | ||
- | Every few seconds the GX device will compare the target SOC with the current SOC and determine the power to use to reach that target before reaching the timestamp + duration. So it takes the full hour to reach the target SOC. | ||
- | In all cases, when the target SOC changes, it will calculate the charge current required to get there, and then distribute that over all the chargers, with the solar chargers getting priority. | ||
- | If it needs more current to get there than solar provides, it will charge from the grid for the rest, but only if the price of the grid is not too high. | ||
- | ===== Determining the target SOC ===== | ||
- | Several people want to know how the algorithm determines the target SOC. This is done by taking 4 steps for each site running Dynamic ESS on each re-calculation of the schedule. This is typically done each hour. | ||
- | - Obtain data; | ||
- | - Set boundary conditions (battery, grid and the consumption/ | ||
- | - Find the most optimal charging cycle according to the data at hand and the battery/ | ||
- | - Attempt to reach the target SOC for the current hour by the end of this hour | ||
- | We've ran a lot of simulations to check if we needed to increase the frequency of re-calculation, | ||
- | We keep the battery stable and not the grid: in our internal testing keeping the battery usage stable (basically the same as the plan) has been a lot more cost-effective than otherwise, because of the battery costs that pile up. | ||
- | Also keep in mind that, when doing a consumption forecast, the system does not known when during the hour that consumption will be done. If the forecast does not match the reality, Dynamic ESS does keep the planned battery usage stable while punishing the forecast inaccuracies on the grid (selling the excess to grid, buy the additional need from the grid). This can be less ideal, but it is an issue of the forecasts being inaccurate, nothing that the Dynamic ESS decided. | ||
- | ===== The Node-RED implementation ===== | ||
- | There exists also a [[https:// | ||
- | The Node-RED flow uses the VRM API to get the calculation for the site and inserts the hourly schedules into the GX device. If you have specific needs, the Node-RED implementation gives you a lot more options than the current VRM implementation. | ||
- | You should only be running one implementation at the same time. If you want to run the VRM version, disable the Node-RED flow. You can read on how to do that [[https:// | ||
- | ====== Country / provider specific ====== | ||
- | It turns out that some countries have specific pricing rules and regulations. Most of these quirks that affect dynamic ESS have been added below. | ||
- | ==== Czech Republic ==== | ||
- | In the Czech Republic there are dynamic transport charges work the same as Denmark, working with peak-tariff and off-peak tariff transport fees. | ||
- | ==== Denmark ==== | ||
- | In Denmark there are dynamic transport charges, depending on the time of day. At the moment there is no support for this in our system, but we will plan to add it later on. | ||
- | ==== Germany ==== | ||
- | German regulation does not allow feeding in from the battery into the grid (even if the power came from solar). From Venus OS version 3.20~17 it is possible to set certain [[https:// | ||
- | ==== Portugal ==== | ||
- | At least one provider in Portugal only allows feeding in solar to the grid during daytime. This looks a lot like the German regulation. For the near future, won't link the battery to grid feed-in to specific times, but disabling battery-to-grid completely will be the first alternative (which is the function that will be implemented soon). | ||
- | ==== UK ==== | ||
- | We are aware that the provider Octopus offers day ahead pricing, but as these are not offered via the ENTSO-E API, we are unable to process those. Eventually we will probably support these prices, but will take some time. | ||
- | Also in the UK, (fixed) prices are known to change at the half hour instead of the whole hour (where our system works with). The work-a-round is to add the average price of in the overlapping hour. So if the price changes from 40 cents to 20 pence at 16.30, fill out a price of 30 pence from 16.00 - 17.00. | ||
- | Adding better support for this will eventually be done, but as this also affects graphs and the scheduling, it might take a while. | ||
====== FAQ ====== | ====== FAQ ====== | ||
- | Missing a question? Please ask them in [[https://community.victronenergy.com/articles/232720/dynamic-ess-on-beta-vrm.html|the community forum]] with a remark that it should be added to the documentation and/or FAQ. | + | Missing a question? Please ask them in [[https://victron.discourse.group/c/products/dess/21|the community forum]] with a remark that it should be added to the documentation and/or FAQ. |
==== Q: Why can't I find dynamic ESS on VRM? ==== | ==== Q: Why can't I find dynamic ESS on VRM? ==== | ||
- | Right now (early March) | + | There are some pre-conditions a site must fulfill in order to get the “Dynamic ESS” menu option. Make sure that the site's system type is set to ESS or Hub-4. If it is not set to this, you need a different |
- | For those of you who aren’t familiar with beta VRM, you can log in through [[http:// | ||
- | ==== Q: Why can't I find dynamic ESS on Beta VRM? ==== | ||
- | There are some pre-conditions a site must fulfill in order to get the " | ||
==== Q: Which energy meters are supported? ==== | ==== Q: Which energy meters are supported? ==== | ||
Line 250: | Line 115: | ||
[[https:// | [[https:// | ||
- | Things like the Dutch P1 meter are not sampling fast enough and not supported right now. | + | ==== Q: What is the default behaviour if the VRM connection is lost longer |
- | ==== Q: What is the default behaviour if the VRM connection is lost longer | + | |
The system will run out of its schedule after 12 hours and revert to standard ESS operation. Once the connection is reestablished, | The system will run out of its schedule after 12 hours and revert to standard ESS operation. Once the connection is reestablished, | ||
As the system is partly depending on third-party services (e.g. for retrieving the day ahead price information). If we are somehow unable to fetch new pricing information, | As the system is partly depending on third-party services (e.g. for retrieving the day ahead price information). If we are somehow unable to fetch new pricing information, | ||
==== Q: Can the system handle charging my EV or other heavy loads? ==== | ==== Q: Can the system handle charging my EV or other heavy loads? ==== | ||
- | The short answer is no. The longer answer is that we are working on this, but as it is not that straight forward to come up with a solution that is user friendly and works for everyone, it can take a while before support for this will appear. | + | It will be able to in the future. |
See [[drafts: | See [[drafts: | ||
==== Q: Is there an API available? ==== | ==== Q: Is there an API available? ==== | ||
Line 309: | Line 174: | ||
Under the //Settings -> General// part of your site, you can set your currency. | Under the //Settings -> General// part of your site, you can set your currency. | ||
- | ==== Q: My providers changes price at the half hour instead of the full hour ==== | ||
- | Some (UK) providers offer fixed prices that change on the half hour instead of at the full hour. | ||
- | Unfortunately the 30 minute interval has some more implications than just allowing it to be entered into the fields. | ||
- | The calculations and forecasts are currently done on the whole hour, so that needs to be accounted for as well. And the same goes for the graphs. All not impossible to solve, but not trivial either and needs a fair bit of testing. | ||
- | So the 30 minute interval will be added eventually, but it will take some more time. | ||
==== Q: Why does (dis)charging slow down or speed up towards the end of the hour? ==== | ==== Q: Why does (dis)charging slow down or speed up towards the end of the hour? ==== |
drafts/dynamic_ess.1715755105.txt.gz · Last modified: 2024-05-15 08:38 by dfaber
