drafts:mppt_faq
MPPT Frequently asked questions
75/15 and 100/15 cannot be controlled by a BMS, what now?
The reason is that the RX pin is already used to the battery life on/off selection with the jumper. So therefore it is unfortunately not possible to control these two models with the VE.Direct .. remote on/off cable [link]. The solutions is buy the next model in line: the MPPT 100/30.
Can the output of the MPPT be used as a power supply, thus without batteries?
Yes, but very, very, limited: it might temporarily switch off after a load is switched on.
drafts/mppt_faq.1414098532.txt.gz · Last modified: 2014-10-23 23:08 by mvader
