drafts:victron_manual_of_style [2019-11-13 08:36] – [Units] mleeftink | drafts:victron_manual_of_style [2024-11-13 12:56] (current) – [List of words that are often written incorrectly] guy_stewart | ||
Line 27: | Line 27: | ||
* VE.Bus | * VE.Bus | ||
* VE.Can | * VE.Can | ||
+ | * VE.Smart | ||
* CAN-bus | * CAN-bus | ||
- | * CCGX/VGX - Referred | + | * GX device - collective name for CCGX, VGX, Cerbo GX, Ekrano GX and so on. |
- | * Equalisation | + | * equalisation |
+ | * Grid-connected - similar | ||
+ | * MultiPlus-II | ||
+ | * Node-RED | ||
+ | * Modbus-TCP | ||
+ | * Signal K (yes with that confusing space) | ||
+ | * run time - as in generator run time. not runtime or run-time | ||
+ | * Passthrough | ||
+ | * Victron Recommended Software Integrator Program | ||
+ | * VRM Online Portal, or VRM Portal - also fine to just be VRM, but when using Online and/or Portal capitalise them | ||
+ | * VRM Portal ID - unique GX device hexadecimal code used to register on VRM, not site id. | ||
Line 56: | Line 79: | ||
==== Style ==== | ==== Style ==== | ||
- | If in doubt //The Economist// has one of the best style guides I know of: http://www.economist.com/ | + | If in doubt //The Economist// has one of the best style guides I know of: https://shop.economist.com/ |
==== Type Faces Used ==== | ==== Type Faces Used ==== | ||
- | * MyriadPro-Bold | + | * Myriad Pro-Bold |
- | * MyriadPro-It | + | * Myriad Pro |
* Helvetica Neue regular, bold and condensed black | * Helvetica Neue regular, bold and condensed black | ||
* Arial regular and bold | * Arial regular and bold | ||
- | There should be a space between the value and the unit. Example 12 V. | + | ==== Victron Energy departments - names and definitions ==== |
- | When using a symbol | + | **Service Department** - Sometimes referred to as " |
- | ==== Victron Energy departments names and definitions ==== | + | **Repair Centre** (previously called Service Partner) - These are external companies (customers) who perform product repairs on behalf of the Victron Energy Service |
- | **Repair Centre** (previously called Service Partner) - these are external companies (customers) who perform product repairs on behalf of the Victron Energy Service | + | |
drafts/victron_manual_of_style.1573630594.txt.gz · Last modified: 2019-11-13 08:36 by mleeftink
